Making bellows
Results 1 to 15 of 15
Thread: Making bellows
    Thanked: 1194
    Default Making bellows
    I thought it was a good idea to quickly make a few bellows for my friends. I kind of misjudged the time and cost of materials . Maybe using marine ply was overkill.... Anyway, I'm happy to see the end of that project after making 7 in total.....
ID:	470327   Click image for larger version.
ID:	470328   Click image for larger version.
ID:	470329   Click image for larger version.
    Toyota FJ Cruiser
    BMW F800GS
    When in doubt, paint it black
  2. The Following 3 Users Say Thank You to Kooskop For This Useful Post:
    Mar 2012
    Thanked: 1276
    Default Re: Making bellows
    Baie nice
    GaryG
    Honda Civic Type R
    - Daily Drive
    Isuzu KB 250 Xrider - Swambo
  4. The Following User Says Thank You to ViperR For This Useful Post:
  5. #3
    Dec 2014
    Thanked: 1980
    Very neat! Well done.
    Cheers,
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  6. The Following User Says Thank You to JohnnoK For This Useful Post:
  7. #4
    Harties
    Thanked: 535
    That is so smart.
    Well done!
    If you make a noise or need music in the bush or on the beach, you’re missing the point.
  8. The Following User Says Thank You to PRA For This Useful Post:
  9. #5
    Feb 2015
    Noordhoek, Cape Town
    Thanked: 2454
    Ek is stomgeslaan. Dis nou netjies!
  10. The Following User Says Thank You to Chris Stoffel For This Useful Post:
  11. #6
    Jul 2016
    Pringle Bay
    Thanked: 764
    Excellent job they look very very nice well done
    Audi A6 Avant Quattro V6 tdi ( Sold )
    VW Touareg V6 tdi ( sadly written off )
    2 x Toyota Celica GT4 Gen 6 (Sold) sadly missed
    2 x Toyota Celica Gen. 5 ( Sold ) not missed as much as the above.
  12. The Following User Says Thank You to meh For This Useful Post:
  13. #7
    Thanked: 1194
    Thanks guys
    Toyota FJ Cruiser
    BMW F800GS
  14. #8
    durban
    Thanked: 1178
    It would be nice to tell us more about this. What material do you use to make the bellows and how do you attach it to the wood. Very nice.
  15. #9
    May 2016
    Thanked: 3102
    Also tell us about the one-way valve.
    I can appreciate good workmanship!
    2006 VW Touareg V10 TDi
  16. #10
    Thanked: 1194
    Deciding on a shape and cutting your templates for the wood and vinyl is I suppose the only tricky part. As I mentioned the 15mm marine ply was probably overkill. You get a thinner (13mm I think) pine ply that can also be used. I bought the leather look vinyl and carpentry nails from Kehl's in Maitland.
    You cut the bat looking shapes out of the plywood with a hand held jigsaw. You also need a 3rd small piece that is glued in between the 2 "bats". I then sanded all around the edges as well as shaped the tip in the front using a belt sander. I suppose there are better tools for this job but the belt sander is all I have. The hole in the tip for the 15mm copper pipe can be drilled at this point.
    I then glue and clamp the handles by placing a piece of off-cut plywood between the 2 bats. Once that is done I cut the breather hole on the one bat and then saw off the one bat and fit the hinge. Once the 2 bats are separated I add 2 screws on the inside for both handles for extra strength. The handles are made out of meranti. A small vinyl flap is fixed on the inside over the breather hole. The vinyl flap is only fixed on the one side with glue (Genkem) and 3 small screws. Drill a hole on the end of each handle to fit the riempie right at the end.
    Then it is varnished. Paint a thin layer of Genkem all around the edges as well as the edges of the vinyl cover. Fix the vinyl to the wood and remove any overlap with a sharp cutting knife. Then the tedious job of hammering in all those carpentry nails. Last this is the short length of copper pipe that is glued into the hole in the tip.
    The above is not necessarily the process I followed with the 1st ones but this is what worked best in the end...
ID:	470648   Click image for larger version.
ID:	470649   Click image for larger version.
ID:	470650   Click image for larger version.
ID:	470651   Click image for larger version.
    Toyota FJ Cruiser
    BMW F800GS
  17. The Following User Says Thank You to Kooskop For This Useful Post:
  18. #11
    Thanked: 1194
    Last time I said never again but some pressure from friends pulled my out of my bellow "retirement" for one more batch of 8 bellows. This time I used lighter pine ply instead of the heavy marine ply on the 1st batch. I stuck to meranti for the handles. Anyway, 5 down with 3 at about 90% complete.
    Now I'm throwing away the templates......or maybe I'll keep them. I might just have a change of heart when I actually retire in 6 years....
ID:	520405   Click image for larger version.
ID:	520406   Click image for larger version.
ID:	520407   Click image for larger version.
ID:	520408   Click image for larger version.
ID:	520409   Click image for larger version.
    Toyota FJ Cruiser
    BMW F800GS
  19. #12
    Thanked: 394
    I would like to be your friend.
    Pajero GLS Exceed 2014 LWB &
    Jeep Cherokee 2001 2.5 Diesel, Gone to Jeep Heaven
    Toyota Hilux, plaas bakkie
    Platkar Swambo's MB
  20. #13
    Thanked: 1194
    Quote Originally Posted by stevan View Post
    Maybe if I was a true friend I would tell them to stop buying @%& braai wood . I have a bellow at home and it is still brand new. No need for a bellow if you have good wood .
    The one in my Bush Lapa however gets used very often. Good wood is not always readily available when you are travelling and camping... plus the bellow works well to blow off excess dust before opening any doors on the van...
    Toyota FJ Cruiser
    BMW F800GS
  21. #14
    Thanked: 83
    Nice, do you use a spring inside to keep it expanded?
  22. #15
    Thanked: 1194
    Quote Originally Posted by emileheyns View Post
    No spring...manually operated.... It would be too bulky to pack away if it remains expanded.
    Toyota FJ Cruiser
    BMW F800GS
