Results 1 to 16 of 16
    Thanked: 181
    Default 3.2 T6 Serpentine belt diagram
    My bakkie chewed up the serpentine belt. Eventually got home and have the new belt waiting.
    Now I just need the routing diagram to fit the thing. Google is useless or I am just too tired to see what I am looking for. Can anyone help please?
    While we are at it, any tips, tricks or wisdom worth sharing?
    Thanked: 181
    Default Re: 3.2 T6 Serpentine belt diagram
    OK I found it.
    I also succeeded in getting the belt replaced. Again greatest respect for people who work on cars for a living. I either have too few hands or my hands are too big to fit into spaces, especially at angles. Anyway, job's done.
    However a little concerned as to the cause for the failure. I see the new belt is running a little off position on the tensioner pulley. Should I be worried?
    Aug 2017
    Durban or Centurion
    Thanked: 1273
    Did the previous belt break, or dit it jump off and got lost?
    Aug 2017
    Durban or Centurion
    Thanked: 1273
    Are the bearings in the tensioner still okay? How many km's do you have on the engine?
    Fish Hoek
    Hi Waldo,
    Do you happen to have a picture for the 2.2l engine, I need to change mine soon.
    Or where can I get a copy of the manual that you printed the picture from.
    Cheers,
    Bill.
    Brits
    Thanked: 468
    Quote Originally Posted by Bills View Post
    Hi Waldo,
    Cheers,
    Bill.
    The 2.2 looks exactly the same
    Renault Duster 1.5Dci 4WD
    Thanked: 181
    Have no idea what happened to the old one, but it was shredded and wound around the fan shaft. Sitting on around 110k km.
    Aug 2017
    Durban or Centurion
    Thanked: 1273
    Hi Waldo,
    Cheers,
    Bill.
    Have you tried looking at these?
    http://www.4x4community.co.za/forum/...ation-*STICKY*
    Fish Hoek
    Thanks JuanB
    Bill.
    Brits
    Thanked: 468
    Thanks JuanB
    Bill.
    It takes less than 5 min to do the 2.2.
    Start at the crank pulley and then work towards the aircon pump and the water pump. Next will be the power steering pump and the tensioner pulley. The last piece will the over the alternator.
    So the sequence will be as per waldo's pic: 7-3-6-5-4 then 9-8-9-1. 9 is the tensioner pully and have two pulleys.
    Use a strong arm bar with extension as you will need the leverage. There is a place on the tensioner where is fits and needs to be pushed to the battery side. Now slowly force it over the alternator pulley.
    Dec 2013
    Maputo
    Quote Originally Posted by waldo_g View Post
    OK I found it.
    hi,
    replace the tensioner ASAP. the bearings for both pulleys are gone. that belt wont last long. I had the same. usually the tensioner last 100k to 120000 km
  12. The Following 2 Users Say Thank You to mzmf For This Useful Post:
    Jan 2017
    Quote Originally Posted by mzmf View Post
    hi,
    Middag, ek wil net by se... Help nie jy verander net Belt nie, hy gaan weer ###..!! As jy mooi kyk sal you sien tensioner pulleys is ge ware, dan hardloop belt skeef, selfde met my bakkie gebeur. Nuwe belt op gesit, toe eet hy hom ommidelik weer op. Ek het die hele tensioner vervang. Ford vrae R2300 vir hom, dit by spares shop in Opherton, JHB gekry vir R650.
    Doen jouslef die guns en vervang die tensioner ook.
  14. The Following User Says Thank You to CRC4x4 For This Useful Post:
  15. #13
    Thanked: 181
    Done. Tensioner was replaced shortly after the new belt. This was just a temporary fix to be going again.
  16. #14
    Jun 2021
    Kathu
    I recently changed my tensioner pully on the 3.2 belt still running off center should I be worried?
  17. #15
    Jun 2021
    Kathu
    Changed the tensioner 2 days ago not OMEName:  20210608_194328.jpg
  18. #16
    Aug 2010
    walvis bay
    Thanked: 16
    Mine chewed up the fan and the fan cowling at idle speed.New tensioner unit should show belt running 3 to 5 mm from front edge of pulley . When it reaches edge of pulley REPLACE ASAP. Dont use anythingbut genuine Ford product
