Stainless steel braai pans
Results 1 to 20 of 20
    Default Stainless steel braai pans
    600 x 420 = R999
    390 x 320 = R655
    I saw this at Mens Woolies (Builders)
  2. The Following User Says Thank You to Therackermann For This Useful Post:
    Default Re: Stainless steel braai pans
    Gaborone, Botswana
    Thanked: 951
    Want vs Need
    Kobus
    Nissan
  5. The Following User Says Thank You to KobusDJ For This Useful Post:
    Klipriver
    Thanked: 231
    I have got 2 similar ones that we bought from Fielies on the forum, use them predominantly on the gas braai under the rotisserie to do the veggies and potatoes. Bit of a schlep to clean but otherwise awesome
    PS of late we line it with foil first
    Alan
    _________________
    Range Rover P38
    Series 3 109 SW (Tortoise)
    Wartburg
    Thanked: 1111
    Quote Originally Posted by All -in -one View Post
    ..... Bit of a schlep to clean but otherwise awesome
    Stainless will last forever, but is not great to fry on. Stuff sticks. With uncoated steel, mild steel is much better, but will rust away.
    All my kitchen pots are stainless steel.
    Maybe it depends on the grade of stainless steel.
    Wartburg
    Thanked: 1111
    Quote Originally Posted by Therackermann View Post
    Same. Except for some Teflon frying pans and ceramic pots
    The Stainless pan is not used unless everything else is unwashed. Frying eggs in it is impossible without anything sticking.
    My BIL owned a business manufacturing commercial kitchen appliances in Durban many moons back. I was still studying back then and asked him why they do not use stainless for the frying sections, and his answer was because of the sticking. I believe they are still manufactured from mild steel.
    Same for stainless grids - meat sticks to these on braais if cleaned too well.
    Klipriver
    Thanked: 231
    Got to agree, not great for frying. I have been contemplating having them non stick coated, or at least one of them
    Alan
    _________________
    Range Rover P38
    Where can one get them coated? Id be interested in doing that.
    Mar 2011
    Walker Bay
    Thanked: 1021
    My stainless receives the double treatment for eggs - olive oil plus Spray and Cook.
    Would not try to fry in it otherwise...
  13. #11
    Klipriver
    Thanked: 231
    If memory serves me right, it's a place called Tornado coating/ cookware. It's somewhere in Boksburg, heard about it via Sarel and Elise
    Alan
    _________________
    Range Rover P38
  14. #12
    Jun 2012
    Thanked: 12
    More likely Volcano coating
  15. #13
    Klipriver
    Thanked: 231
    Quote Originally Posted by hend View Post
    My bad, ( old age) Thanks for the correction
    Alan
    _________________
    Range Rover P38
  16. The Following User Says Thank You to All -in -one For This Useful Post:
  17. #14
    Thanked: 1061
    I disliked the Mpo and Mpojana eggs in a Cadac skottel. Some of you may remember those names being siamese twins attached at their heads, hence the Cadac egg pattern's name. I decided to have a stainles skottel made with an almost flat bottom. 3 mm thick. What a waste of money. That thing burns stuff in no time. I suppose it is because stainless is a poor conductor of heat, resulting in very uneven heat distribution. Hellish hot immediately under the flame, but cool towards the outside. I subsequently got a similar size cast iron "skottel" which is fantastic. I use it on a three burner Alva stand.
  18. #15
    Feb 2019
    Hi guys, while we are on the topic of non stick coating I would just like to add that ceramic coating is a real thing now and has the benefit of being non reactive which means you can cook acidic foods etc with out worrying about leaching anything into your food. Still requires a small amount of fat or oil to prevent sticking but then again everything does. Not so sure on where to get a coating like that in SA but if you are looking to buy camping cookware etc I do recommend buying ceramic. You can get them on Yuppie chef and a few other places.
  19. #16
    Feb 2019
    There are two companies in the East Rand that will add a Teflon coating to the pan for you. It will last well over 10 years and will be easy peasy to clean. The price is around R300, which seems like a lot until you realise what you are actually getting. You are getting the surface treatment of a R1k pot/pan.
    The companies are Controlled Surface Treatments in Boksburg and Aluminium Trading in Edenvale.
    A mate of mine got Aluminium Trading to make him a simple custom pan from scratch with food grade Stainless Steel then coated it with Teflon, that was over 11 years ago.
  20. The Following User Says Thank You to Shaytorn For This Useful Post:
  21. #17
    Ruimsig
    Thanked: 3284
    From Makro: R219.00
    Bought a set of 3 on their R100.00 specials dotted around their store. Not as deep and the 2 smaller ones are half the size of the larger and nest within the larger one.
    2010 Hummer H3 5.3lt V8, 300 HP, FDL, RDL, CDL, TC and 4:1 Low Range
    Discovery and Range Rovers: SOLD: enough is enough
  22. The Following User Says Thank You to Estee For This Useful Post:
  23. #18
    Senekal
    Thanked: 90
    Quote Originally Posted by Shaytorn View Post
    We had a few items coated by Controlled Surface Treatment (Volcano cookware) about six years ago.
    The Cadac skottel braai is just a pleasure to use, specially with the cleaning , nearly about just a wipe to clean it .
    The same apply with the potjie and other pans. .................real pleasure with the cleaning .
    The only "disappointment" though is the hard steel wok, it doesn't get that flaming hot as before because of the coating, the teflon can take heat of about 300 degrees but it seems I can't get the wok that high temperatures anymore for effective wok-cooking.
  24. #19
    Klipriver
    Thanked: 231
    Thanks for the info guys, at the moment mine are used mainly as a drip tray under the spit/ rotisserie. We only do potato wedgies and roast veg in it, so we just "line" it with tin foil. When done it is basically whip off the foil and toss it in the bin, at worst there is sometimes a bit of oil to clean, but a LOT less stress to clean
    Alan
    _________________
    Range Rover P38
  25. #20
    Richardsbay, KZN
    Thanked: 6892
    Hhhmm. Maybe I must pull out my old homemade stainless pan for It are time tonight. My uncle made it many many years ago, the corners have nuts welded on where threaded car engine valves screw in - making it free standing if needed. It went "missing" many years ago whenever he ask me where it was
    Reckon I have made at least a ton of fish and seafood on it over the last 25 years.
    Walker Evans, Photographer
  26. The Following User Says Thank You to Riaan van Wyk For This Useful Post:
