RRC V8 to 300tdi conversion - Page 4
Page 4 of 4 FirstFirst 1 2 3 4
Results 61 to 69 of 69
  1. #61
    Thanked: 15049
    Default Re: RRC V8 to 300tdi conversion
    Quote Originally Posted by whosthejman View Post
    I think this forum served its purpose!
    i thank all for the input
    I would like to close this thread
    I am starting a new post
    project ROVERINE (RRC overland preperation) focusing on preparing and repairing the car for a namibian botswana trip and hopefully engine conversion in the new year- after pink foot has arrived
    I think if you don't have R1k for a new MAF then you should reconsider a conversion.
    Jakes Louw
  2. #62
    Sep 2014
    Thanked: 160
    Ha ha ha im trying my luck and trying not to spend bucks in the wring area
    Wolverine : 93' Range Rover Classic 3.9L EFI
  3. #63
    Sep 2014
    Thanked: 160
    I spoke to phillip at rangies
    I would like to confirm
    Did the 300tdi come in the zf auto box or was it a R380? Auto
  4. #64
    Tzaneen
    Thanked: 314
    R380 is manual box.The RR and D1 used the same outo box.
    2012 RR TDV8 4.4
    2006 TDV6 SE A/T(Sold)
    2008 FL2 TD4 SE A/T
    1968 Renault 8 Gordini
  5. The Following User Says Thank You to DiscoFrans For This Useful Post:
  6. #65
    Thanked: 15049
    Quote Originally Posted by DiscoFrans View Post
    precisely
    and the 300TDI came with either auto or manual
    Jakes Louw
  7. The Following User Says Thank You to jelo For This Useful Post:
  8. #66
    Sep 2014
    Thanked: 160
    precisely
    Ok makes more sence as philip from rangies said i need a diffrent bellhousing and flexplate ect
    But i think its due to the fact its a R380 manual compared to an auto zf
  9. #67
    Thanked: 15049
    Yes basically what I said a week ago
    Jakes Louw
  10. The Following User Says Thank You to jelo For This Useful Post:
  11. #68
    Sep 2014
    Thanked: 160
    However if i only manage to find a 300tdi manual
    Wont i be able to use the flex plate from the rangie on the 300tdi engine to connect my zf box i have
  12. #69
    Tzaneen
    Thanked: 314
    You will need the Tdi bellhousing for the a/t.Doubt if the v8 flexplate will fit the Tdi crank but you can compare the partnrs.
    2012 RR TDV8 4.4
    2008 FL2 TD4 SE A/T
  13. The Following User Says Thank You to DiscoFrans For This Useful Post:
