Transmission overheating warning TDV3 SE
Results 1 to 5 of 5
    Nov 2011
    Thanked: 13
    Default Transmission overheating warning TDV3 SE
    Good evening all,
    Had a message come up on the car on the way home tonight "TRANSMISSION OVERHEATING".
    No great distance was travelled, 10km possibly.
    Not hot, raining probably around 18/20deg (East Rand)
    Going to check radiator levels tomorrow morning when it has cooled down.
    Anything else that I need to check?
    Clive
    Jul 2015
    Meadowdale - Edenvale
    Thanked: 103
    Default Re: Transmission overheating warning TDV3 SE
    Hi Clive
    I Agree, the first step will be to check the water levels and quality to assure everything is OK.
    I had before were the transmission cooler failed (its part of the engine radiator) and allowed coolant into the transmission and the vehicle also brought up overheating on the cluster, but then you will normally feel harsh gear changes.
    The other thing that it can be is the temp sensor that failed on the mechatronic control unit, inside the transmission. The only way to test that sensor is to connect a Diagnostic tester when the vehicle is cold and to compare the transmission temperature with ambient temperature.
    If you need any assistance with a diagnostic tester, feel free to give me a call or to bring the vehicle in to ZF.
    Nico
    ZF Services South Africa (Pty) Ltd.
    170 Herman Street, Meadowdale, Ext. 3, Germiston
    P.O.Box 2098, Kempton Park, 1620
    Nico Eksteen
    Supervisor - Passenger Vehicles
    Phone:011 457 0005
    Cell: 082 776 2757
    Email: [email protected]
    http://www.zf.com/za
  3. The Following User Says Thank You to ZF Services South Africa For This Useful Post:
    Thanked: 119
    You need to get to ZF asap...transmissions need to be well looked after.
    When last did you have an oil flush ?
    Sorry to OP for the Hijack of your Thread
    Nico, when are you guys having a flush special again for us loyal customers on the forum ?
    2009 D3 V8 SE - Family car, holiday and weekends
    2009 Mahindra Scorpio 2.6 GLX - Mom's Taxi
    2001 Ford Ranger 2.5 D/C - My Car
    2007 D3 TDV6 S - Family car, holiday and weekends ( RELUCTANTLY SOLD )
    Nov 2011
    Thanked: 13
    Quote Originally Posted by AllOutdoors View Post
    Had all of that done recently, I think it's the sensor.
    Even when starting from cold I get the message.
    Going to have it checked out today.
    Nov 2011
    Thanked: 13
    Stopped in at Landy Tech (Gearbox Doctor) Randburg, and Carlos sorted me out. It was the temp sensor in the rear diff that had decided to stop playing nice.
    Thanks for sorting me out.
