Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 52
    Canberra, Australia
    Thanked: 762
    Default DIY Dual Battery Box - My ultimate box built !
    Hi,
    So for some time I wanted to build a mobile dual battery system which can be removed from the vehicle... I got quotes for Alu boxes and even considered building my own Alu box...
    I then discovered that Bushpower sells the National Luna box as a "Box only"... No electronics...
    I wanted to make use of a CTek D250S (DC-DC) charger instead of the old solenoid method...
    So I picked up the empty box and so the design started...
    I had it laser cut and powder coated...
    Then the fitting (and test fitting) of plugs started....
    Each and every connection was crimped, the soldered, then closed with heat shrink:
    And then the final product:
    Red Brad Harrison is for Solar panel input,
    Grey Brad Harrison is for input from main battery/altenator
    Each output plug is individually fused
    It has a dual battery monitor, 2 x usb ports, 2 x Hella plugs, 1 x normal lighter socket... The 2 x switches is to switch on (and off) the battery monitor, so that it could be switched of when the unit is in storage, and the same goes for the USB ports which has a blue LED which would eventually drain the battery...
    Also fitted fit a 100Ah Lead Crystal battery...
ID:	468850   Click image for larger version.
ID:	468851   Click image for larger version.
ID:	468852   Click image for larger version.
ID:	468853   Click image for larger version.
ID:	468854   Click image for larger version.
ID:	468855   Click image for larger version.
ID:	468856   Click image for larger version.
ID:	468858   Click image for larger version.
ID:	468859   Click image for larger version.
ID:	468860   Click image for larger version.
ID:	468861   Click image for larger version.
ID:	468862   Click image for larger version.
ID:	468863   Click image for larger version.
ID:	468864   Click image for larger version.
  2. The Following 19 Users Say Thank You to SinWolf For This Useful Post:
    Pretoria North, Patryshoek
    Thanked: 3233
    Default Re: DIY Dual Battery Box - My ultimate box built !
    Very nice. Congrats
    +27 zero eight 2 four 95 9252
    Garsfontein
    Thanked: 7525
    That looks very, very good. Well done.
    I've got the NL box. My biggest gripe with mine is that the connectors are on the side - and my packing set-up has that side pointing at the wall of the boot. Which means it's a permanent battle to connect / disconnect anything... Should perhaps revisit my set up....
    Jan 2009
    Thanked: 390
    This is very well made and super neat!
    I believe this is a significant improvement on the standard boxes!
    Canberra, Australia
    Thanked: 762
    This will NOT work for me either... Hence my specific design
    Krugersdorp
    Thanked: 64
    Very nice where did you get it lasercut?
    FORD Ranger
    Conqueror Courage
    Canberra, Australia
    Thanked: 762
    Quote Originally Posted by blind View Post
    I use Kare Sheet Metal in Pta.
    Jul 2013
    Sundowner
    Thanked: 40
    Welgedaan! You can start selling these..... Nice!
    Thanked: 192
    Well done very smart, add some silk screening or labelled lexan then you have sell-able product.
    very smart!!!
    Hilux 2700i s/c 4X4 with a few extras ...............
    Nov 2006
    Thanked: 951
    Very smart, what battery are we looking at?
    Canberra, Australia
    Thanked: 762
    Quote Originally Posted by ismail View Post
    very smart!!!
    I thought about the label idea... But not worth the effort for a once of
    Canberra, Australia
    Thanked: 762
    Quote Originally Posted by sinwolf View Post
    also fitted fit a 100ah lead crystal battery...
    Quote Originally Posted by damdan View Post
    very smart, what battery are we looking at?
    ;d ;d
    Cape Town - RSA
    Thanked: 1164
    Very nice what was the total cost for the box without battery?
    2017 Venter Savuti + Tentco Jnr, Dometic CF50 Fridge + Ecoflow River Pro and 120W solar panel.
    Ex - 2005 Cherokee CRD
  15. #14
    Mar 2015
    Thanked: 261
    Great work... i did a similar set up but with a plastic box...
    the laser cut plate really finished of the project nicely!
    Current: RRS SDV8
    Current: Touareg 3.0Tdi R-Line
    Current: G6 GTi DSG
    Ex:Ford Ranger 3.2 Auto 4x4 XLT (illegally redistributed)
    Ex:Paj DiD SWB Auto
    Ex:E92 335i 430kw Monster
  16. #15
    Hillcrest
    Thanked: 21493
    Quote Originally Posted by SinWolf View Post
    You have done such a fantastic job, don't stop now. Put your name on it and be proud - I would.
    NAGOF
    HAM Callsign - ZS5KAD
  17. #16
    Canberra, Australia
    Thanked: 762
    I will have to go an look... not sure...
    Battery box - R450
    Laser cut, bend, powder coat - R300
    Ctek D250S - R5500
    Brad Harison - R70 x 2 = R140
    Hella - R99 x 2 - R200
    Fuse holders - R35 x 4 - R140
    12V Socket - R100
    USB ports - R170
    Switches x 2 = R50
    NL Dual battery monitor - R460
    Lugs, cabling, bolts and nuts, heat shrink, solder - R
    Labour - R
  18. The Following User Says Thank You to SinWolf For This Useful Post:
  19. #17
    Aug 2015
    Thanked: 49
    Really well done. Very net and well thought out.
    May I ask where you bought those fuse holders? I am busy with my own dual battery and no fuse holder boxy thing seem to work for me since I would like all the wires and workings hidden like yours.
  20. #18
    Canberra, Australia
    Thanked: 762
    Quote Originally Posted by Tijmen van der Steenhoven View Post
    Communica in Samrand or Mantech in JHB also have them...
    Most of the other stuff I got from www.bushpower.co.za
  21. #19
    Apr 2017
    Joburg
    Thanked: 951
    Thumbs up Re: DIY Dual Battery Box - My ultimate box built !
    Nice job. Well done!!
    Always great to see people take pride in their work and pay attention to detail.
  22. #20
    Jun 2013
    Thanked: 5940
    Great job that, it is really cool.
    Stranger
    GOF Club
    BMW R1200R
