Nissan D21 torsion bar
Results 1 to 4 of 4
    Klerksdorp
    Default Nissan D21 torsion bar
    Greetings to all
    Yesterday the left torsion bar on my 1998 Nissan Hardbody 2.7 4x4 snapped. Now I need to know if the 4x4 and 4x2 uses the same torsion bar as I can find some 4x2's at scrapyards.
    I need to source one today.
    Blerrie speedbumps!
    Niel
    Niel Bierman
    Ford Ranger SupCab 4X4 3.0 XLT
    Nissan Hardbody 2.7D 4X4 SC
    Honda XR400R
    ORRA Call sign: B192
    Amateur Radio Call sign: ZS6NEB
    Oct 2015
    Marble Hall
    Default Re: Nissan D21 torsion bar
    You don't only replace one it's like shocks replace bought. I replaced it on may bakkie a years or so it was like R2700 for OME at 4x4 mega world
    Thanked: 9652
    Yes if one broke, it means the other one is probably very close as well.
    Jun 2012
    Capetown
    Thanked: 32
    2x4s are much longer than 4x4 tortion bars the 4x4 LCA is mounter in 2 places making them wide and making the need for shorter TB. 2x4 have thin single mounting point LCA so needing the longer TB. what you can do is remover the broken bar and take it with to the scrapp yard and see IF the 2x4 TB from the later model HIGHRIDEr and 4x4 can work .these models all have the same LCA ( NOT THE NORMAL / lower ride hight BAKKIES ) i have a 2006 3.3 V6 2x4 double cab highrider and these have the wide LCA. also make sure the adjusting arm fits over the later model TB . make sure you use both sides from the same vehicle and make sure you make wich one is driver side and which is pasenger side im pretty sure there is a difference
    hope this helps
