Wat is die Engelse term vir 'n vlakplaat?
Results 1 to 18 of 18
    Robertson/ Larissa, Greece
    Thanked: 3377
    Default Wat is die Engelse term vir 'n vlakplaat?
    Ek hoop daar is nog ouens wat weet waarvan ek praat! El wil weet wat is die Engelse term vir 'n vlakplaat en waar koop mens dit?
    Jul 2013
    cape town
    Thanked: 630
    Default Re: Wat is die Engelse term vir 'n vlakplaat?
    are you talking about surface plates?
    Metgran sells them
  3. The Following User Says Thank You to Ocin For This Useful Post:
    Modderfontein, naby Rysmierbult
    Thanked: 605
    ? Surface plate ?.. weet nie waar dit te koop is nie.
    Johan Mitchell, .... r.i.v. Swambo Marthie
    My beste kennis is dié oor my eie onkunde
    '96 Colt DC V8 ... Safari Camper ... '88 Fleetline L
    '88 Ballade 150 ... sold
    "The rule here is that there is no rule" .. MikeAG
    Thanked: 3377
    Thanks surface plate it seems to be. Ocin anymore info on Metgran perhaps?
    Edit. Seems Metgran is into granite. I'm looking for a heavy metal one
    Dec 2014
    Thanked: 1914
    A Huster machine tools out in Voertsekker Road, Goodwood.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  7. The Following User Says Thank You to JohnnoK For This Useful Post:
    Jul 2013
    cape town
    Thanked: 630
    I had no idea what a "vlakplaat" is so I googled the word and said translate to English.
    then I google "surface plate south Africa" and it gave me metgran.
    all this took 30 seconds.
    now you mission, if you choose to accept, is to google the following " metal surface plate south Africa"
    Jun 2008
    Hillrise, Kempton Park
    Thanked: 1380
    Waar werk so'n plaat?
    Dan sal ek ook weet waaroor julle gesels
    Isuzu 300 d-tec
    MB Gwagen G350 Bluetec
    Nissan NP300 2.4 4x4
    BMW R1200GS & GSA
    Worcester
    Thanked: 1339
    Was Vlakplaats nie daar waar die ou regime skandes loop maak het nie....?
    Work. It's a wealthy man's privilege, and a poor man' fate....
    André Opperman
    "Boerbok" - 98 Jeep XJ 4lit auto
    "Gloria" - 04 Ranger D/C 4lit auto
    Kloof
    Thanked: 340
    Quote Originally Posted by Ocin View Post
    Thanks for the laugh
    Amarok milk bottle
    "So really , you are not so smart , you are a old Oomie that has to much time on his hands" - Christo Meisenheimer
    Thanked: 3377
    Why should I go through all the trouble if I can ask on the Forum. QED
  13. #11
    Thanked: 3377
    Johan daar is baie toepassings. 'n Vlakplaat is 'n baie akkurate en uiters stewige plat oppervlak waarop akkurate instrumente ge yk kan word. Of as jy iets baie presies wil afwerk op 'n horisontale vlak kan jy dit op 'n vlakplaat skuur met natuurlik die geskikte skuurpapier daaronder wat oor die vlakplaat gespan is. Dis sommer so uit die vuis. Daar is ook ander toepassings.
  14. The Following User Says Thank You to Francois Theron For This Useful Post:
  15. #12
    Thanked: 40
    Gerhard Beukes
    Mr Big
    2015 Navara 4x4
    4x4 Com Radio: 1033
  16. #13
    durban
    Thanked: 1119
    Why would you want to use a metal surface plate? The granite ones dont rust,dont pick up burrs. They are more accurate and stable.
    Best of all if they dont have to be calibrated,a cut out of a granite kitchen top works well and is free.
  17. The Following 3 Users Say Thank You to plunger For This Useful Post:
  18. #14
    Feb 2018
    Middelburg
    Thanked: 34
    Have you come right? If not, an option is to buy a piece of heavy plate, 30 - 50mm and have it surface ground at an engineering shop.
  19. The Following User Says Thank You to GreigD For This Useful Post:
  20. #15
    durban
    Thanked: 1119
    Quote Originally Posted by GreigD View Post
    I guess its what the OP needs it for. But I suspect a free piece of cut out granite would do a better job. Surface grinders dont make things truelly flat. The metal you choose would play a big role in this too.Cast iron would be better as it doesnt have to be stress relieved. The magnet on the surface grinder ,if the metal is not thick enough would distort the piece.
    Another option is to surface grind it,bang it on an accurate surface plate after blueing it in and then scraping it flat. You will be shocked how out of true a surface ground piece of metal is.Off course for us mere mortals it would seem very flat.
  21. #16
    durban
    Thanked: 1119
    What do you do to need a surface plate?
  22. #17
    Thanked: 3377
    Plunger, to be very honest I can't remember what it was I needed it for! I know I wanted to face grind something at the time and thought of a surface plate (something I last used as an appy) but only had the Afrikaans name. But the thread responses did put me onto some interesting searches, so not all is lost!
  23. #18
    Dec 2014
    Thanked: 1914
    In a push, a piece of thick glass will do. I think anything over 10 or 15 mm is float glass and it is perfectly flat and suitable if properly supported for a basic surface plate.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
