AC to DC welder conversion.
Results 1 to 14 of 14
    Thanked: 15181
    Default AC to DC welder conversion.
    I have an old AC welder, and while I have a nifty new DC inverter welder, I don't want to just chuck the old 230v AC oil bath welder away.
    We also have crappy voltage on the farm: 360v 3Phase and around 200-210v AC 1Ph. Tshwane doesn't want to replace the pole transformer unless it's totally broken.
    So DC makes more sense so that I can get a decent arc from a rectified consistent voltage.
    I did some Youtube "research": apparently a nice single phase bridge-rectifier will convert the AC welder to a DC welder?
    I doubt if my old oil bath can push more than 50A: will a 72A single phase bridge rectifier do the job?
    http://za.rs-online.com/web/p/bridge...fiers/0192865/
    Jakes Louw
    Robertson/ Larissa, Greece
    Thanked: 3558
    Default Re: AC to DC welder conversion.
    I'd love to hear what the experts say since I'm in the same boat. Have an old oil bath which has done very little work.
    Thanked: 15181
    I had more of a look and it seems a 150A / 1600V bridge rectifier would be safer.
    The problem is that it seems nobody in ZA sells these things.
    What I'm planning on doing is running the + and - from the oil bath to the B-R, which I will mount either on the oil bath casing or on a wheeled trolley frame, using a wooden insulator and an aluminium plate heat-sink , and then to a plastic hobby box which will have female connections for the new style Dinse quick-connect system.
    That oil bath welder is bloody heavy: probably around 50kgs. So I'd have to put it on a wheeled trolley anyway.
    I have an old wheeled trolley that used to be a braai, I'd just need to put some angle-iron floor in it and then work out where to put the connector box.
    Jakes Louw
    Dec 2014
    Vanderbijlpark
    Thanked: 41
    You can add multiple bridge rectifiers in parallel to split the current.
    Audi A4 B6 1.8T 2002
    VW Touareg R5 2.5TDI 2005 (SWAMBO)
    There is nothing like can't. Only don't want to try.
    Thanked: 15181
    Quote Originally Posted by Tracer87ZA View Post
    beyond my electrical capability
    A 140A oil bath welder, and assuming then a 150A bridge rectifier is sufficient:
    2 x 75A bridge rectifiers? What voltage?
    3 x 50A? Again, what voltage?
    It will make the whole thing very untidy.
    Jakes Louw
    Thanked: 3558
    OK Jelo you do this and tell me if it works!
    Oct 2008
    Thanked: 8
    The rectifier is going to convert the AC cycles into rectified cycles at the output - The signal is not pure DC, at the positive terminal the output will look like a sine wave where the negative cycles are inverted (vice versa for negative terminal) . If the input is a varying AC, the rectified output is also going to vary. The rectifier is the first step in an AC to DC conversion. What is needed next is very large capacitors to "filter out" the AC components ...
    I am not familiar with what you guys want to achieve, but to my mind the rectifier on its own will not do the job ...
    Dec 2014
    Vanderbijlpark
    Thanked: 41
    An ac welder is a stepdown transformer, thus you should have a voltage well below 100V. The rectifier might be able to handle 150Amp, but don't think the connections can. Cable should be at least 25mm square to cope with the current.
    Oct 2008
    Thanked: 8
    Here is the waveform that I tried to explain:
    http://www.electronics-tutorials.ws/diode/diode_6.html
    Quote Originally Posted by Jaco Versfeld View Post
    Thanked: 15181
    well the AC welder provides full current then zero then full current then zero then full current then zero...........
    Yes, I've seen you need capacitors if you want to smooth the flow, but I'd be happy with a sine wave that fluctuates between 70% and 100% : that's already better than the AC supply.
    Jakes Louw
    Jul 2017
    Louis Trichardt
    Thanked: 209
    I have done this with my AC welder. Yes it does spark a bit easier and I can weld thinner plate without burning holes as quickly but the overall effect was not what I expected. The biggest problem with the diodes that you use is not the forward current over them, Allthough you do need to keep this in mind. The major problem is the peak reverse voltage for the times that you tap the rod to the item. That spark can cause havoc up the line. You think that you are just sitting with 70V, as in my case, when you can easily have spikes going back into the rectifier of 500V. I will take a picture of my setup and list what diodes I used later this afternoon, The diodes came out of a UPS that we had at work that was thrown out.
    My Life Loving It
    Jul 2017
    Louis Trichardt
    Thanked: 209
    Sorry forgot to post. I cant make out what the top diodes are as I have been spray painting in my garage and they got a bit of overspray on them
    My Life Loving It
    King Williams Town
    Thanked: 1188
    I would guess a person that has to buy all parts out of pocket would find it cheaper and.more economical to buy an inverter welder.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
    Nov 2017
    Thanked: 214
    Don't know if this will work but try and find an older forklift charger and use the diodes and heatsinks from it. Or keep the oil bath welder for gouging.
