Defender headlight wiring upgrade
Results 1 to 10 of 10
    Mar 2013
    Thanked: 342
    Default headlight wiring upgrade
    My defenders headlights still are not what Id like. I have already fitted clear lenses and aftermarket bulbs which improved things but still not by a large margin. I have changed the coils so the headlights also need adjustment, does anyone have a manual for this or know where i can have this done?
    The next step is to upgrade the wiring harness to get some more juice to the globes.
    Has anyone done this or used this harness from 4x4 direct http://www.4x4direct.co.za/headspot-light-harness/6170-h4-headlight-booster-harness.html .
    Pieter Greyling
    ONE LIFE, LIVE IT!
    ORRA: Z85
    -Land Rover Defender 110 Td5
    -BMW G650 xChallenge
    Thanked: 155
    Default Re: headlight wiring upgrade
    Quote Originally Posted by pjf110 View Post
    Upgrading the wiring will sort your problem. 4x4 direct harass would be perfect. I would as an extra put in a thicker FUSED cable from the battery to the 4x4direct harass relays in the engine bay. The less volt drop the better.
    Edwin
    Defender '99 TD5 Pick Up
    Rock sliders, Spare wheel carrier, Roof Rack, Aluminium canopy, Tentco RTT, Tentco Awning, 280Ah Dual batteries, 3 x Sliding Drawers, Water tank, Hot Shower, Kitchen
  3. The Following User Says Thank You to Defender TAZ For This Useful Post:
    Nigel
    Thanked: 2078
    Just use led bulbs.
    Uniglide
    +27 zero eight 2 four 95 9252
    Mar 2013
    Thanked: 342
    Thanks Henri but I have already bought replacement bulbs a while ago. It is a blue type of light which I absolutely hate and the only LED lights I could find where also blue type. Hope that makes some sense
    Pieter Greyling
    ONE LIFE, LIVE IT!
    ORRA: Z85
    Nigel
    Thanked: 2078
    The 80 suffered from the same problem. I did the whole wiring upgrade. Forever a dog breakfast of wires behind the grill. LED's is just an easier route and they are not voltage critical.
    Uniglide
  7. The Following User Says Thank You to Henris For This Useful Post:
    Jun 2007
    Thanked: 53
    There are decent LED Head Light Bulb kits out there - with the correct 6000 K colour and quality LED's which throw good light patterns - just need to know where to look
    Apr 2014
    Richards Bay
    Thanked: 75
    Order a pair of kensun HIDs with 4300k color. If you have the clear lenses then this will be an excellent upgrade. Kensun is highly rated, not some Chinese fly by night product.
    Makes a huge difference!!!
    1985 Land Rover 110 - 300tdi conversion
    It's always more fun on the road less travelled
    Apr 2014
    Richards Bay
    Thanked: 75
    https://www.amazon.com/gp/aw/d/B004Z...EMM&psc=1&th=1
    Apr 2014
    Richards Bay
    Thanked: 75
    Just make sure to adjust your beam correctly
  12. The Following User Says Thank You to iLandy For This Useful Post:
  13. #10
    Apr 2014
    Richards Bay
    Thanked: 75
  14. The Following User Says Thank You to iLandy For This Useful Post:
