Kobus maak Mes - Page 3
Page 3 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 41 to 60 of 102
Thread: Kobus maak Mes
  1. #41
    Gaborone, Botswana
    Thanked: 960
    Default Re: Kobus maak Mes
    Gister begin ek met die skede.
    Uitgesny en patroon opgestempel
    Naaldwerk
    Ek vorder
    Klaar. Nou moet ek nog die leer kleur en polish.
ID:	476928   Click image for larger version.
ID:	476929   Click image for larger version.
ID:	476926   Click image for larger version.
    Kobus
    Nissan
  2. #42
    Gaborone, Botswana
    Thanked: 960
    Klaar.
    Mes en skede.
    Mes in skede.
ID:	476930   Click image for larger version.
ID:	476931   Click image for larger version.
    Kobus
    Nissan
  3. The Following User Says Thank You to KobusDJ For This Useful Post:
  4. #43
    May 2016
    Thanked: 2769
    Ek is beindruk!! (inbedruk, soos my pl George sal s).
    Geen kritiek, maar daar is een item wat my OCD natuur bietjie pla.
    Alles is 'handgemaak', behalwe die skedes se klinknaels.
    Het jy dit oorweeg om hulle ook self te maak, uit bv brons staaf?
    2006 VW Touareg V10 TDi
  5. #44
    Gaborone, Botswana
    Thanked: 960
    Ek is beindruk!! (inbedruk, soos my pl George sal s).....
    Dankie.
    ......Alles is 'handgemaak', behalwe die skedes se klinknaels.
    Nognie, maar dit is 'n idee.
    Kobus
    Nissan
  6. #45
    Gaborone, Botswana
    Thanked: 960
    Nommer 1 en nommer 2
ID:	476934   Click image for larger version.
    Kobus
    Nissan
  7. The Following 2 Users Say Thank You to KobusDJ For This Useful Post:
  8. #46
    Feb 2015
    Noordhoek, Cape Town
    Thanked: 2450
    Baie netjies. Baie baie netjies.
  9. #47
    Gaborone, Botswana
    Thanked: 960
    My mes kan biltong sny.
    (kyk daai lekker geel vetjie)
    Kobus
    Nissan
  10. The Following 6 Users Say Thank You to KobusDJ For This Useful Post:
  11. #48
    Feb 2018
    Middelburg
    Thanked: 34
    Very nicely done. Something that I am wanting to attempt when I am big.
    Regarding the angle to which you sharpen, the Kershaw knives are sharpened to an internal angle of 23 degrees, if that is any help.
  12. #49
    Thanked: 217
    Baie neties Kobus !! Dit wil gedoen word !!
    2004 Defender TD5
    1992 Defender 3.5V8
    PROJECT OVERHAUL http://4x4community.co.za/forum/show...oject+overhaul
  13. #50
    Gaborone, Botswana
    Thanked: 960
    Thanks for the compliments.
    Quote Originally Posted by GreigD View Post
    ......... Regarding the angle to which you sharpen, the Kershaw knives are sharpened to an internal angle of 23 degrees, if that is any help.
    I did one at 25 and the other at 30.
    This is the angles according to Lansky
    • 17 Angle: The 17 angle should be used when an extremely sharp but delicate edge is needed. This angle is perfect for razor blades, scalpels, and similar tools.
    • 20 Angle: The 20 angle provides an excellent edge for kitchen cutlery and filet knives. It is a commonly used angle for higher quality blades, and possibly the most often used.
    • 25 Angle: The 25 angle is the recommended angle for most knives that need a durable, sharp edge. This angle is ideal for hunting and outdoor knives.
    • 30 Angle: The 30 Angle is an excellent angle for knives that see a lot of heavy use. This could include cutting cardboard, wire, or carpets.
    Kobus
    Nissan
  14. #51
    Thanked: 148
    Hats off, Kobus, that is fantastic. Well done.
    What I find most impressive is that you made those beautiful knives after making your own sander, sharpener and the most basic of tools.
    Only thing I don't understand is the difference between the quench and the temper?
    Can you please explain the two a bit more?
    4x4 less.
  15. #52
    Gaborone, Botswana
    Thanked: 960
    Quote Originally Posted by Brian1 View Post
    .......Only thing I don't understand is the difference between the quench and the temper?
    I'm no Metallurgical Engineer but here it goes.
    To quench harden is the heating of the steel to the appropriate temperature (doesn't stick to a magnet any more) and then rapidly cooling it in oil. This makes the steel very hard but brittle. When you pull a file over, it just glides off, barely making a mark. To reduce the brittleness it needs to be tempered. You heat up until at least 204 C. It will become a light straw color. Let it cool down slowly.
    Kobus
    Nissan
  16. The Following User Says Thank You to KobusDJ For This Useful Post:
  17. #53
    Roodekrans
    Thanked: 140
    Baie netjies gedoen Kobus, eks heel jaloers op jou werk!!!
    Vraag? Hoe / met wat het jy die patroon op die leer gemaak?
  18. #54
    Gaborone, Botswana
    Thanked: 960
    Quote Originally Posted by 0000ms View Post
    ........... Vraag? Hoe / met wat het jy die patroon op die leer gemaak?
    Dit is stempels. Mens koop by 'n leer winkel.
    Die kleintjies tik jy maar met 'n hammer op nat leer.
    Hierdie grootter stempels druk ek op die nat leer in die Bank Skroef (is dit die regte woord vir Bench Vice ?) Ek sit dit tussen plankies sodat niks beskadig nie.
    Dan is daar ook hierdie wielletjie wat die vrou iewers uit haar argiewe gehaal het. Dit gebruik ek om die kante.
    Die resultaat van naby.
ID:	481932   Click image for larger version.
ID:	481933   Click image for larger version.
ID:	481934   Click image for larger version.
    Kobus
    Nissan
  19. #55
    Roodekrans
    Thanked: 140
    Ahaaa...baie eenvoudig dankie.....nou werk my brein oortyd
  20. #56
    Gaborone, Botswana
    Thanked: 960
    Coming Soon
    Kobus
    Nissan
  21. #57
    Gaborone, Botswana
    Thanked: 960
    Dit was tyd om 'n Byl te maak. Eintlik meer verander as maak.
    Koop 'n nuwe byl en trek sy steel uit.
    Dit is omtrent hoe dit gaan lyk.
    Kobus
    Nissan
  22. #58
    Gaborone, Botswana
    Thanked: 960
    Sny met Angle Grinder.
    Eet maar klein stukkies op 'n slag.
    Dit is tot waar ek kon sny.
ID:	484282   Click image for larger version.
ID:	484283   Click image for larger version.
    Kobus
    Nissan
  23. #59
    Gaborone, Botswana
    Thanked: 960
    Ek begin skuur met Belt Skuurder.
    Vorder maar stadig. Byl is baie hard. Ek het nie voor die tyd Anneal nie.
    Blink geskuur tot #240
    Nog 'n foto.
ID:	484285   Click image for larger version.
ID:	484286   Click image for larger version.
ID:	484287   Click image for larger version.
    Kobus
    Nissan
  24. The Following User Says Thank You to KobusDJ For This Useful Post:
  25. #60
    Thanked: 983
    baie mooi. Jy maak my jaloers, al die masjiene staan by die huis
    [email protected]
    +27824453301
