Cracked head or Injector O-rings
Results 1 to 17 of 17
    Jun 2016
    Cape town
    Default Cracked head or Injector O-rings
    Hi Everyone!
    Hope your weekend has been good so far.
    I was hoping to get some advice, I recently bought a 1999 Defender 90 td5 (10p head) with 330 000km on the clock!!
    Got it for a really good price and it's in pretty decent condition for it's age.
    So after buying it I realised I never had a look at the oil level! :/ yeah, I know, rookie mistake!
    The level was really high up on the dipstick but the oil didn't smell like diesel and wasn't watered down. Thought previous owner might have overfilled with oil.
    Yesterday I drained the oil and did all the filters and new oil! Drained just over 8 liters of oil.
    Took the car for a drive round the block to check for any leaks and all was okay.
    This morning I checked the oil after the car has been standing all night and the level again was sky high on the dipstick. No obvious smell of diesel and oil feels fine between my fingers.
    I know the 10p heads are prone to cracking. Hoping its not that.
    Think I might do the injector washers and o rings first to see if it helps. I really hope it's not the head, who has that kind of money!?
    Any advice would be appreciated.
    Mar 2013
    Thanked: 332
    Default Re: Cracked head or Injector O-rings
    Oil rising s typically o-rings and washers, I would start there. It can be done diy if you have a torque wrench, injector puller and a few basic tools. If that does not work have the head pressure tested.
    Do you know if the head has been done? A 10p head on 330 000km that is still original would be pretty impressive.
    Pieter Greyling
    ONE LIFE, LIVE IT!
    ORRA: Z85
    -Land Rover Defender 110 Td5
    -BMW G650 xChallenge
    Fish Hoek
    Thanked: 9
    Hi Theo,
    PM sent.
    Cheers,
    Bill.
    Jun 2016
    Cape town
    Thanks. I thought it might be a good idea to do the washers and o rings first to see if it might be that.
    I have no idea if the head has been done. But agree that a 10p head with 330 000km on and still be original is probably to good to be true.
    Will report back after I have done the washers and o rings!
    Fish Hoek
    Thanked: 9
    The TD5 cylinder head gasket normally tend to start leaking before that amount of kilos.
    Bill.
    Thanked: 9651
    Quote Originally Posted by Bills View Post
    What's left of the TD5 cylinder head gasket normally tend to start leaking before that amount of kilos.
    Bill.
    fixed that for you
    Dec 2014
    Thanked: 1520
    Quote Originally Posted by Theo Botha View Post
    It may be overkill, but I heated my washers red hot and quenched them to anneal them prior to fitting them.
    Admittedly, it was a new head, so I wasn't expecting a leak, but decided that it wouldn't do any harm.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Jun 2016
    Cape town
    I did the washers on my other td5 a while back, used tdi washers and also heated them up before fitting. It's been more than a year and no problems at all.
    So do you guys think I should go down the injector seals route first?
    When I drained the oil and replaced the tappet cover gasket I didn't see any white/milky sludge. Oil was just black! So is that a good indication that it's not water filling my sump?
    Dec 2014
    Thanked: 1520
    I would do that first. A LOT cheaper than a new head.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Oct 2015
    Romania/Hungary
    Thanked: 113
    To keep things accurate, fuel can get into the oil only through the O-rings or a crack in the head, the copper washers have nothing to do with fuel in oil only with combustion gas in fuel which leads to hard starting and missfire though off course that if o-rings or washers are the problem they must be changed both
    to see if it's o-ring issue remove the rocker cover and turn ignition to II(dont crank it) then the pump will pressurise the system and if fuel is leaking near the o-rings you'll see it bubbling there or where the crack is if that's the case, here is a cross section of the head to be clear what's happening there
    2000 Discovery Td5 ES manual, tuned
    Hawkeye v.6, Nanocom EVO,
    VDM UCANDAS, oscilloscope
    i DON'T ANSWER TO TECHNICAL QUESTIONS IN PM'S
    ALL MY ADVICES ARE BASED ON MY OWN EXPERIENCE AND MY WAY OF UNDERSTANDING THE DESCRIPTION AND OPERATION OF SYSTEMS... I'M NOT A LAND ROVER SPECIALIST JUST AN ADDICTED ENTHUSIAST
    Mar 2013
    Thanked: 332
    Just a tip when doing o-rings, make sure they are seated properly i.e not twisted.
    Pieter Greyling
    ONE LIFE, LIVE IT!
    ORRA: Z85
    Melkbosstrand
    Thanked: 335
    Quote Originally Posted by pjf110 View Post
    To pop TD5 injectors out, you just put the short end of a 5mm allen key under the "bridge" and lever them
    As already mentioned, annealed TDi washers are the way to go
    Rob
    V8 Defender 90 pickup. Lexus, Spitronics, 33" KL71, beadlocks, +2" Terrafirma, ATB's, 3.75 CW&P, 1.21 TC.
    Series IIA 88" pickup
    Disco 2 ES TD5
    Disco 1 ES 300TDi
    Subaru impreza WRX
    Porsche Boxster S
    Shamrock Cobra 350
    MG TF160 VVC ZandF remapped
    Buell XB12R
    Jun 2016
    Cape town
    Hi Everyone. Sorry for only getting back to now. I did the injector O-rings and washers and did the fuel pressure regulator while I was at it.
    It seems to have solved my problem. Oil level looks better for now. Haven't been driving with the car a lot lately so wil check again in about a week or so.
    Now on to the next problem. The aircon compressor is so noisy I can't even hear the glorious TD5 rumble.
    Took the belt off and spun all the pulleys. And it seem to be just the aircon pulley.
    Is there a way to dismantle this thing and replace the bearing?
    Fish Hoek
    Thanked: 9
    Hi Theo,
    It is quite easy to strip.
    I have a new bearing lying in my garage. It is not a standard bearing.
    Cheers,
    Bill.
    Jun 2016
    Cape town
    Hi Bill thanks for the reply, do I have to take the unit off to strip it? I only see one bolt on the front of the pulley, took it of and tried getting the pulley of but to no avail.
    Fish Hoek
    Thanked: 9
    Theo,
    You dont have to take the unit off. I seem to remember that once you have the bolt out there is a washer and then a circlip.
    after you remove the circlip the pulley will slide off.
    Jun 2016
    Cape town
    Thanks Bill. Will have a look a bit later. Don't remember seeing any washers or circlips.
    Will get back to you.
