Oil leak new Navara
Results 1 to 20 of 115
    Nov 2012
    Ovamboland
    Thanked: 1214
    Default Oil leak new Navara
    Gents,
    I have noticed a small dry oil puddle on my garage floor where the Navara usually sleeps. I climbed underneath and saw an oil trial coming from the top. I opened the bonnet and saw this:
    It just has done about 400km. What the hell can be the cause
    From another angle:
    I havent done any long trips yet. Just town driving. I have not let the revs go above 4000rpm and always let the car idle to let the turbos cool down. Always.
    Please please please someone give me some insight as to what the problem can be. The earliest I will be able to take it to Nissan is on monday. Until then, I will not drive it.
    Thanks and cheers.
    Thanked: 3673
    Default Re: Oil leak new Navara
    Neem bietjie van verder af. Kan nie sien nie
    VW Touareg V6 Tdi Escape
    Bush Lapa Boskriek 816
    Nov 2012
    Ovamboland
    Thanked: 1214
    Kyk regs bo onder die drie swart pypies. Dit le 'n poel onder die pypies.
    Thanked: 3673
    Quote Originally Posted by Ricoffy View Post
    Ek sien die olie. Wil sien waar dit le. Kry nie die volle prentjie nie
    Nov 2012
    Ovamboland
    Thanked: 1214
    Onder die pyp waarop die rooi lighter le.
    Nov 2012
    Ovamboland
    Thanked: 1214
    Its not the pipe with the lighter on that leaks.
    Thanked: 3673
    Nee my maat. Sorry. Kom ons wag vir iemand meer tegnies georienteerd. Daai lyk soos die turbo pyp so kon verstaan as hy lek ja.
  8. The Following User Says Thank You to Nys For This Useful Post:
    Nov 2012
    Ovamboland
    Thanked: 1214
    Bump.
    Robertson/ Larissa, Greece
    Thanked: 3324
    Ek het die prentjie nou mooi bekyk, dit lyk vir my of die ringe gaan le het en nou stoot die olie by die breather uit na die turbo toe!
    Diagnose? Enjin is moertoe. Moes Amarok gekoop het!
  11. The Following User Says Thank You to Francois Theron For This Useful Post:
    Nov 2012
    Ovamboland
    Thanked: 1214
    Onder normale omstandighede sou ek saam gelag het. Ek het 530k redes om nie te lag nie...
  13. #11
    Nov 2012
    Ovamboland
    Thanked: 1214
    Marius, Jelo, Reenen, Grips & kie... enige iemand
  14. #12
    Thanked: 3673
    Dink die manne kyk rugby of werk!!!!
    Maar ja my maat. Vat terug en kry n nuwe een
  15. #13
    Thanked: 3324
    Jammer kon nie die versoeking weerstaan nie!
    Ek dink nie dis 'n groot issue nie. Baie moeilik om van die fotos 'n afleiding te maak. My raaiskoot is 'n o ring of gasket wat lek. Die ding is so nuut as dit ernstig is sal hulle net eenvoudig vervang.
  16. #14
    Kathu
    Thanked: 2842
    Het probeer kyk op die foto maar kan nie n afleiding maak nie. Stem saam met François glo nie dit is erstig nie.
  17. #15
    Nov 2012
    Ovamboland
    Thanked: 1214
    Geen probleem.
    Ek deel dit gereeld uit, moet dit so af en toe kan vat ook.
    Sal maar maandag hoor wat die mechs van Nissan seg.
  18. #16
    Nov 2012
    Ovamboland
    Thanked: 1214
    Ek waardeer nogtans die kyk grips. Groete
  19. #17
    Nov 2012
    Ovamboland
    Thanked: 1214
    Bump.
  20. #18
    Bellville
    Vat terug agente toe, hoe moeilik kan dit tog wees.
  21. #19
    Oct 2008
    Thanked: 278
    Nee wat, as hy so vinnig olie lek moes dit seker n FORD gewees het...
    Vat maar terug en gaan kry n Mitshubishi!!!
    PS - Boonste comments is bedoel as n grap.
    Dink ook dalk dis net n klein O-ring wat iewers nie meer lekker is nie en hulle behoort jou vinnig te help
    Mitsubishi Triton 3.2 DI-D 4x4
    BL925 - Ratel 4
  22. #20
    Mar 2012
    Pierre van Ryneveld
    Thanked: 3922
    Dink dit dalk net n “assembly” fout. Seël dalk skeef ingesit of iets nie mooi vas nie. Glo dit sal vinnige fix wees.
