300 tdi vacuum pump replacement- bad to worse - Page 2
Results 21 to 35 of 35
    Thanked: 451
    Default Re: 300 tdi vacuum pump replacement- bad to worse
    Quote Originally Posted by AR155 View Post
    Yeah, took me quite some time to figure this out
    During my install I tried a few different sources for ignition on signal. I first tried tapping into the glowplug relay, but this caused the glowplugs to stop working... Checked the fuse, nope fuse is fine.
    And so started days of searching for the possible fault. Before I gave up completely, I decided to remove ALL fuses and check EACH one with tester. So wragtig, one of the fuses had like a hairline crack through the little wire. I missed this when eye balling it... Et voila!
    Hi Derik
    why haven't you fitted the Allisport expansion tank yet? Do that asap, when that bottle cracks open, you risk loosing the engine, with or without Madman!!!
    and you need to clean up that engine bay
    This is what looked like when it was still mine
ID:	474662   Click image for larger version.
    George Bosch
    Distributor for:
    New Germany
    Thanked: 480
    It is time for an update.
    Wingate in Johannesburg sells a vacuum pump kit for about R4600.
    I fitted the electric pump in December. The kit has everything you need included, and the pump is tested by Wingate before selling it.
    I added one relay as peace of mind.
    The electric pump is noisy for a few seconds until the desired vacuum is reached.
    The best part is the engine is running A LOT quieter than before.
    Happy days!
    what is it like driving any problems so far and can it cope with on off on off repetibly on the brakes, and you not loosing cacuum, once you use brakes how long does it run before cutting off again and how noisy is it once you driving and it starts up can you hear it over the engine
    i just bought another unipump will see how that holds up if not will go the way you did,
    maybe you could try sell that pump to some one as a spare
    clive
    2005 Defender TD5
    Thanked: 9
    Hi Derik
    Genade oom George! Dis 'n fo by fo ekse!
    I have meant to fit it a thousand times... something always comes up. It does ride with me on longer trips though.
    Thanked: 9
    clive
    I actually only used it for a few short trips to test and then borrowed the car to my dad while his car is in for repairs.
    From my experience the brakes just function as they always did. The electric pump is a beast and favored by offroad junkies according to the seller. It did not switch on every time that I used the brakes... Maybe every 2nd time? Perhaps a function of how long you use the pedal. Leaks will also make it switch on more often.
    I could not hear it while driving. Sitting in the car with doors closed at idle, you can hear it faintly. Standing outside you can not miss it :-)
  5. The Following User Says Thank You to AR155 For This Useful Post:
  6. #25
    Langebaanweg
    Thanked: 1124
    Resurrecting an old thread.
    Just a quick question.
    Look at the following clip and in the first 2&1/2 minutes he explains a function of the vacuum pump.
    Here's the question: the air that the pump pushes into the crank case, is it important?
    Does it have a purpose? Crankcase pressure?
    This is just for when I, one day convert mine to electric.
    '07 Land Rover Defender 110 TDI 300 Kalahari (Meisiekind²)
  7. #26
    Thanked: 13548
    most 4-stroke engines rely on positive crankcase pressure to remove unwanted gases and moisture from the inside of the block
    I would guess this is part of that system.
  8. #27
    Langebaanweg
    Thanked: 1124
    So, I plumb the electrical pump exhaust back into the crankcase?
  9. #28
    Thanked: 13548
    why not? install an oil catch can while you're busy
  10. #29
    Langebaanweg
    Thanked: 1124
    On the other hand, the electrical pump switches off when it has reached the desired pressure.
  11. #30
    Langebaanweg
    Thanked: 1124
    Some pics:
    Size wrt A4 page
    Attachment 474619
    Installation notes
    Attachment 474620
    The kit
    Attachment 474621
    Installed
    Attachment 474622
    Happy days!
    Hi AR155
    Did you notice any difference with the change to electric?
  12. #31
    Thanked: 19
    I wouldn't, it serves no purpose, vac pump is merely removing the small amount of air in the servo unit until the desired vacuum is obtained for satisfactory brake assist
    30 years experience and knowledge certainly out weighs a 5min keyboard bashing on google
    Love's electrickery stuff and problems related to it as long as it dont go bang cos then its f......
    NO REPLACEMENT FOR DISPLACEMENT
    A V8 is where thunder is made
    100%WEE
  13. #32
    Langebaanweg
    Thanked: 1124
    But why does the original pump dump it in the crankcase?
    If it's not important, cool but I just wanted to understand the logic behind it.
    It looks like most people who did go electric just blanked off the hole.
    I'm just curious if it might have some sort of effect, negative or positive.
  14. #33
    Thanked: 87
    My original vacuum pump on the 300tdi doesnt dump anything into the crankcase or anywhere else
  15. #34
    Langebaanweg
    Thanked: 1124
    I refer to the video in post 25, there he describes it.
  16. #35
    Modjadjiskloof
    Thanked: 145
    jfh, I've been thinking about this post quite a lot as I work on my 300 Tdi engine.
    Logically speaking, the vacuum pump has got to "dump" the excess air somewhere. Since it doesn't have a vent to atmosphere, it makes sense that it goes into the crankcase.
    However, I think it's a bit optimistic to expect it to greatly affect crankcase pressure. Remember that the pump "sucks" to provide a vacuum for the brake booster only. Once the vacuum is achieved, there should be little to no air flow at all.
    I would imagine that the combined effects of blowby and a bit of "sucking" from the air intake contributes much more to the eventual purging of gases from the crankcase.
    So in my considered and definitely non-expert opinion, there would be no need to make another plan for crankcase pressure when removing the vacuum pump.
    When I rebuild my engine, I'm not going back to mechanical pumps. Both vacuum and lift pumps are going to be electric, with the vacuum pump working on demand. I'll put blanking plates on the holes. I'll carry a spare electric fuel pump.
    (thinking of going for electric cooling fans too, but that's another story).
