300 tdi vacuum pump replacement- bad to worse
Results 1 to 20 of 35
    Thanked: 9
    Default 300 tdi vacuum pump replacement- bad to worse
    Hi all
    I finally got round to fitting the new vacuum pump. The old one has been noisy since I got the car, though I suspected noisy tappets.
    I ran into a problem though.
    Old pump
    Cam
    What the pump plunger surface should look like:
    I hope the photos get added. If not I will link it on the laptop tomorrow.
    Any opinions on what to do with the cam lobe? Leaving it as is will simply destroy the new pump in no time.
    Is it time for a new cam? Weld this cam up and resurface (taking into account this original cam has worked for the past 400000km)?
    Get a nice hot cam to assist the vgt turbo with breathing? Hehehe...
    Derik
    Mar 2015
    New Germany
    Thanked: 490
    Default Re: 300 tdi vacuum pump replacement- bad to worse
    That looks like a new cam the lobe is to damaged,
    and then you can have a look at the rollers which run on the cam for lifters, when take cam out, but means head off and front casings to change cam
    i think there is also a oil squirted nozzle that directs oil onto that lobe as well check that out
    2005 Defender TD5
    Thanked: 13606
    Hot cams are not appropriate for turbo diesels as the exhaust and inlet timing overlap is very precise.
  4. The Following User Says Thank You to jelo For This Useful Post:
    Aug 2016
    Thanked: 16
    I suspect you will be replacing cam followers as well. As Jelo said be careful with longer duration cams on a diesel. Less is often more on them. You can likely go for higher lift but I'm not sure you will be able to on the 300. I'm just afraid that you will lose even more during the boost threshold range if you mess with the cam.
    Thanked: 9
    Thanks for the advice!
    Nah I agree on the cam issue. I do not need a racing car :-)
    Darn, I did not realise it is a head off operation to change the cam I would not like to open the motor. Usually when I do things like this I end up replacing anything looking remotely worn
    But yes, if it gets a new cam it will get new followers. No use running worn stuff on new surfaces.
    Mar 2015
    New Germany
    Thanked: 490
    If your cam followers for lifters are still good use them as the aftermarket ones are not upto spec as Original, and the roller lifter and guide are paired don’t muddle them up when taking apart, you can keep the guide it just remove lifter and roller, they all might be ok just the pump lobe that got damaged, if the rest are damaged then could be due to low oil pressure if all are pitted
    2005 Defender TD5
  8. The Following User Says Thank You to clivemd For This Useful Post:
    Thanked: 451
    Quote Originally Posted by AR155 View Post
    Hi Derik
    that looks to me that the metal hardness of the vacuum pump plunger was incorrect. The picture shows most definitely the result of excessive wear due to incorrect rockwell grade hardness of the pump plunger.
    Those vacuum pumps have become an absolute nitemare. Take the vehicle to Walter at LRXtreme, he knows that vehicle well. Let him fit the vacuum pump from the IH Powerstroke motor. It entails a new alternator/vacuum pump assembly. That way you save yourself the trouble of having to open that motor.
    I hope that you continued to run the motor on Delo400 as I advised you to, when you bought it from me.
    That motor never overheated, so the head should still be in good condition.
    Good luck!
    George Bosch
    Distributor for:
    Thanked: 9
    Hi George
    I already bought a new vacuum pump in April, but fitting it like this is of no use. I need to work out costs of fitting new cam.
    However, as these pumps are crappy quality nowadays, I thought about fitting an electric vacuum pump.
    Converting to an alternator mounted vacuum pump will mean oil feed also. An extra source of leaks :-)
    I only use Delo400 :-) But honestly, I change oil based on time not kilos LOL
    Uhm... it did overheat once coming from Durbs with the 101FC on a trailer The viscous fan went kaput. Madman showed 119degC within seconds (obviously the standard needle had JUST started to move from the middle). That was 1.5 years ago and she is as strong as ever so I reckon no damage had been done. These motors are really tougher than what they are being given credit for!
    Madman for the win! I would not even have known that I was cooking the motor if I only had the standard gauge
    Thanked: 451
    Hi George
    Hi Derik
    yes electric vacuum pump is an alternative. Easy and effective. You just need to make sure that the battery is always properly charged
    George Bosch
    Distributor for:
    Mar 2015
    New Germany
    Thanked: 490
    Hi AR155
    What make was that pump that you took out, as I removed mine due to leak and the plunger has started to pit and that in less then 15000 Km, cam lobe is still ok lucky
    Was give a replacement will have to see what make replacement one is
    Here is pic of one taken out and has Unipumps stamped in it
ID:	474186   Click image for larger version.
    2005 Defender TD5
  13. #11
    Springs
    Thanked: 280
    Hi George
    investigated the option of fitting an alternator with vacuum pump and not feasible. the alternator is simply too close to the turbo.
    looking at the belt driven Puma vacuum pump as an option.
  14. The Following User Says Thank You to Landyluvver For This Useful Post:
  15. #12
    Nov 2011
    Langebaanweg
    Thanked: 1131
    When the time comes I will be fitting an electric vacuum pump.
    On one of the Oz forums a guy fitted one fron an Audi A4.
    Seems like a easy fix.
    '07 Land Rover Defender 110 TDI 300 Kalahari (Meisiekind²)
  16. #13
    Mar 2015
    New Germany
    Thanked: 490
    Will also need vacuum switch and relay also was looking at something like this
    2005 Defender TD5
  17. #14
    Thanked: 451
    Hi George
    Hi Derik
    I would go for an electric vacuum pump. The pump that was in the vehicle when you got it was a Unipump. If the vehicle runs properly, i.e. no loss of power or misfire, then that means that only the vacuum pump lobe was damaged. So there would be no need to fit a new cam. The motor has never been opened, by the time you took it over from me.
    The speed control has its own vacuum pump, which sits below the jack tray behind LHD front headlight. So no sweat there.
    George Bosch
    Distributor for:
  18. #15
    Thanked: 9
    Hi AR155
    Hi Clive
    Indeed mine was also a unipump :-(
    I do have a brand new pump for you that I purchased and did not fit due to the cam lobe being worn out.
    Derik
  19. #16
    Thanked: 451
    Hi Derik
    as I said before, fit an electric pump. Just go to a VW/Audi scrap yard and look for a pump and its wiring harness. Then you can make up you own.
    On your rig, the EGR has been removed, so it is only the brake booster that needs vacuum. And for that you don't need a relay, as the old style mechanical vacuum pumps are also connected directly to the booster. You can however fit a relay set up in such a way, that the pump only works, when the engine is running.
    The product quality of those Wabco pumps for the 300Tdi have become a real liability due to shocking quality control (reminds me of D4 cranks ).
    When I fitted the Unipump, which I sourced from LP4A in Pinetown, they were the only ones with a somewhat decent quality. By that time I was already on pump #4 .
    George Bosch
    Distributor for:
  20. The Following User Says Thank You to hgbosch For This Useful Post:
  21. #17
    Nov 2011
    Langebaanweg
    Thanked: 1131
    Here is a picture of one guy's setup.
    I must admit it's bigger than I thought it will be but it works.
  22. #18
    Thanked: 9
    It is time for an update.
    Wingate in Johannesburg sells a vacuum pump kit for about R4600.
    I fitted the electric pump in December. The kit has everything you need included, and the pump is tested by Wingate before selling it.
    I added one relay as peace of mind.
    The electric pump is noisy for a few seconds until the desired vacuum is reached.
    The best part is the engine is running A LOT quieter than before.
    Some pics:
    Size wrt A4 page
    Installation notes
    The kit
    Installed
    Happy days!
  23. #19
    Thanked: 9
    LOL SNAP!! While I was resizing jpg's you beat me to it.
  24. #20
    Thanked: 9
    Yeah, took me quite some time to figure this out
    During my install I tried a few different sources for ignition on signal. I first tried tapping into the glowplug relay, but this caused the glowplugs to stop working... Checked the fuse, nope fuse is fine.
    And so started days of searching for the possible fault. Before I gave up completely, I decided to remove ALL fuses and check EACH one with tester. So wragtig, one of the fuses had like a hairline crack through the little wire. I missed this when eye balling it... Et voila!
