Trailblazer 2.5 smoking
Results 1 to 2 of 2
    Jun 2016
    Richards Bay
    Default Trailblazer 2.5 smoking
    Hi All
    Swambo's 2012 Trailblazer 2.5 smokes black smoke on start up for about 2 seconds.
    It also does not start immediately
    Compared to my Ranger 2.2 it has very little low down torque. I have to rev it quite a bit to get up my driveway, whereas my Ranger idles up easily
    The TB recently got a service at 70kkm
    Is this normal, should I be worried?
  2. The Following User Says Thank You to Baberaas For This Useful Post:
    May 2013
    Stutterheim
    Thanked: 12
    Default Re: Trailblazer 2.5 smoking
    Im no expert but not starting immediately I would look first at battery. Its very possible that it is a bit tired.
    Black smoke at start for a second or two as far as I understand can be common. The engine starts rich and bkack smoke is a sign of overfueling.
    The poor start may just be adding to the problem with "flooding" cause of the delay in turning over.
    If it gets worse get injectors checked out. But I very much doubt it, unless you got dirty fuel.
    But ja, start with battery and take it from there
    Hyundai ix35 2.0 crdi 4wd (Current, untill i get a proper 4x4 again )
    The Firetruck: Isuzu KB360 V6 4x4 (Sold)
  4. The Following User Says Thank You to Kershmeister For This Useful Post:
