Suspension Tie rod needed
Results 1 to 9 of 9
Thread: Tie rod needed
    Thanked: 165
    Default Tie rod needed
    Hi guys,
    Has anyone got a oem tie rod laying around ? I need one for me isuzu please. I don't really need the ends just the rod.
    Please let me know. Thanks a mill
    2010 Toyota Fortuner 2 4x4.
    2001 Isuzu KB320 Frontier 4x4.
    2012 Polo GT White with community sticker.
    Dec 2006
    Thanked: 862
    Default Re: Tie rod needed
    Garreth, go buy yourself a couple of 2007 4x4 Ford Ranger tie rods, at Ford. Dirt cheap (vs GM) Identical threads, just shorter, thus sturdier.
    Then you'll need a 14mm threaded sleeve, and the threaded part of a 14mm capscrew. I've got a pic of the assembly somewhere. I'll see if I can find it.
    Sakkie Coetzee
    Some people say I have a "short temper"....I see it as swift and assertive reaction to Bull!
    Thanked: 165
    Quote Originally Posted by Sakkie View Post
    Thanks, let me know if you get that pic please.
    Dec 2006
    Thanked: 862
    Garreth, here's the whole thing all laid out, just for you
ID:	463032   Click image for larger version.
ID:	463033   Click image for larger version.
ID:	463034   Click image for larger version.
ID:	463035   Click image for larger version.
    Sakkie Coetzee
    Dec 2006
    Thanked: 862
    That sleeve is 22mm dia, 50mm long. Inside threaded straight through 14mm std. metric. Just about any metal will do. If you want an overkill that will outlast 100 Isuzus, Bohler v155, no heat treatment required.
    The stud is 25-30mm 14mm std thread, cut from a 14mm 12.9 grade capscrew. This you can green Loctite halfway into the sleeve (12-15mm to protrude for locking into the rod end.
    The rest is normal assembly and wheel alignment adjustment.
    Sakkie Coetzee
    The Wall
    Thanked: 1671
    Sakkie, wys hom hoe om een te maak met square tubing en clamps....
    Ek het steeds myne....
    "Everything has its limit - iron ore cannot be educated into gold."
    Dec 2006
    Thanked: 862
    In nood is daar baie planne, , net bietjie van 'n blikskottel om die wheel alignment te skat.
    Sakkie Coetzee
    Thanked: 165
    Thanks Sakkie, I ordered two from Ford. Cost now is R145 for a tie rod... I'm going to get more.
    I'm hard at work on the isuzu. Next year we will kick some ass at the Bridgestone Challenge
    Dec 2006
    Thanked: 862
    R145.....not bad for an OEM part that is off the shelf, and quick and easy to replace.
    Get that Frontier sorted!!!
    Sakkie Coetzee
