Suzuki Samurai/SJ410/SJ413 lift kits
Results 1 to 5 of 5
    Nov 2014
    Bryanston
    Default Suzuki Samurai/SJ410/SJ413 lift kits
    Hi everyone.
    I no longer have my Samurai, and still have the Lift Kits brand new in the boxes from the USA that I imported.
    There are 2 kits.
    Kit #1
    Low Range Off Road SPOA lift kit.
    This kit comes with the over Axle spring perches that mount into the standard under axle perches for a very snug fit.
    the rest of the kit includes:
    - 2 x front heavy duty spring perches Laser cut
    - 2 x Rear heavy duty spring perches laser Cut
    - 2 Drive Shaft spacers
    - Extended Brake lines
    - All mounting hardware (Nuts and Bolts)
    Kit #2
    Trail Tough YJ Spring conversion w/Front Missing Link
    This Kit is the famous Trail tough Laser Cut conversion kit to fit Jeep YJ leaf springs to the Samurai. This kit can be used with Kit #1. Or on its own with the Standard Spring Under axle Samurai set up.
    This kit includes:
    - 2 x Front Missing Link shackles including bushes
    - 2 x Rear extended shackles
    - 4 x Spring Plates
    - 4 x under body spring mounts
    - All mounting hardware (Nuts & Bolts)
    - Springs not included.
    YJ springs are 2.5" wider than Samurai springs, and much longer. Giving a softer rider. And lots of articulation.
    I have attached photos of the kits below.
    hope it's clear enough.
    I imported both kits for R15 000. And hoping to just make my money back.
    But it is negotiable.
    Kit #1 - R7000
    Kit #2 - R6000
    Offers welcome.
    I am in Fourways. But willing to post at buyers expense.
    Thank you for looking.
    Justin Dunn
    0820548988
ID:	462316   Click image for larger version.
ID:	462317   Click image for larger version.
ID:	462318   Click image for larger version.
ID:	462319   Click image for larger version.
ID:	462320   Click image for larger version.
ID:	462321   Click image for larger version.
    Feb 2013
    Matsapha
    Default Re: Suzuki Samurai/SJ410/SJ413 lift kits
    Good morning
    are the lifts kits for the SJ413 still available?
    Kind
    Wayne Sparham
    It will be best to call Justin he is not online that much anymore
    Suzuki Jimny - BS Dueler AT - Wizerd Steel Undies, Wizerd Rock sliders. Tough Dog Suspension, Front Runner Roofrack
    Suzuki SJ410 '84 - SOLD
    Nissan X-Trail 2009 (Lekker Kar Die)
    Jun 2020
    Hermanus
    Hi
    Any of these still available?
    Sep 2016
    Thanked: 30
    Quote Originally Posted by talktopeter View Post
    Hi
    DIY
    Call or WhatsApp me, also welcome to join our SJ 4X4frica WhatsApp group (self invite link below).
    https://chat.whatsapp.com/DcBP4YvDyFFJdsCmbhVNR5
    Theuns
    07to7nin7nin455
