Amarok fuel filler flap stuck
Results 1 to 5 of 5
    Jul 2013
    Thanked: 295
    Default Amarok fuel filler flap stuck
    My amarok fuel filler flap is stuck.I did gravel travel this weekend now the flap will not open.
    Please help with how to open it without breaking the bstard open.
    Has anyone perhaps fitted a lock that opens with a key.
    Much appreciated.
    Coenie
    Jun 2012
    Meyerton
    Thanked: 271
    Default Re: Amarok fuel filler flap stuck
    Your amarok is so light on fuel you won't have to worry about it for a while stil
    I know the VW sedans have manual release from inside the boot. What does the manual say?
    Jul 2013
    Thanked: 295
    I will touch base with dealer today.
    But it is now working again.left it open just in case.The pin is clean and no dust on it.So it is not dirt jamming it.
    When I stand by the flap and lock and unlock th car ,I hear the destinct locking and unlocking of the pin.Testing it by depressing the pin it works perfect.
    Thus I surmize that there is some malfunction of the ecu.Will have dealer check for me.
    Harrismith
    My previous 2010 Amarok also did that, specially if they try to open the flap without me unlocking is. What I did was lock the doors, wait a few seconds and then unlocked again
    Jul 2013
    Thanked: 295
    Ok the mechanic at Zimmermanns advised me that if the car is locked and the flap gets closed after locking the freezing issue starts as in my case.
    I refueled on Thursday and locked the car to go pay before the flap was closed.
    I am considering disconnecting the switch locking power supply to leave it in an unlocked position .
