Halflinger herstel poging
Results 1 to 8 of 8
    Langs die rivier, op n berg
    Default Halflinger herstel poging
    Ek het hierdie Halflinger op my werf ontdek na my vakansie. (Dankie Stadler).
    Engine is geseize, wiele is gelock, kan nie beweeg al is voertuig in neutral.
    So, nou om dit weer aan gang te kry.
    As iemand weet wasr mens begin soek vir parte, help asb met kontak nommer.
    Botriver
    Default Re: Halflinger herstel poging
    Sal bietjie rondvra....
    '65 Jeep Wagoneer
    SOA conversion
    Work in progress....
    https://www.facebook.com/Honingklip-...6324709414350/
    Robertson/ Larissa, Greece
    Reenen, tussen Stanford en Hermanus is 'n plaas met die naam Walshacres of so iets, daar het nie lank terug nie 'n Halflinger onder die bome op die werf gele
    cape town
    http://www.wilddog.za.net/forum/inde...topic=144978.0
    a rebuild story from a motorbike site (Wilddogs)
    Sep 2017
    Witbank
    Naand ek het ook n halflinger ek is opsoek na n engine en n gearbox as julle van een weet
    Bethlehem
    Any progress on the rebuild/restoration??
    Of COURSE I have a Bad Habit. I take Tea at Three (Mick Jagger)
    Bellville
    Talking Re: Halflinger herstel poging
    Quote Originally Posted by dieterf View Post
    Hey! Dis my l˘rrie daai!
    Asks for password.
    1999 Discovery 1, 300 Tdi - "Tink Tanky"
    2004 Discovery 2 Td5 - "Blink Tanky"
    "Logic is a systematic method of coming to the wrong conclusion with confidence."
    "A technician will let a system degenerate to the level of his understanding and maintain it there."
    "...it is abundantly clear that you are an arrogant C-nut." - Estee. (I was overwhelmed. It was the nicest thing someone has said to me in a week!)
