Halflinger herstel poging
Results 1 to 8 of 8
    Langs die rivier, op n berg
    Thanked: 2387
    Default Halflinger herstel poging
    Ek het hierdie Halflinger op my werf ontdek na my vakansie. (Dankie Stadler).
    Engine is geseize, wiele is gelock, kan nie beweeg al is voertuig in neutral.
    So, nou om dit weer aan gang te kry.
    As iemand weet wasr mens begin soek vir parte, help asb met kontak nommer.
  2. The Following User Says Thank You to Reenen For This Useful Post:
  3. #2
    Botriver
    Thanked: 82
    Default Re: Halflinger herstel poging
    Sal bietjie rondvra....
    '65 Jeep Wagoneer
    SOA conversion
    Work in progress....
    https://www.facebook.com/Honingklip-...6324709414350/
  4. The Following User Says Thank You to RichardMiddelmann For This Useful Post:
  5. #3
    Robertson/ Larissa, Greece
    Thanked: 2341
    Reenen, tussen Stanford en Hermanus is 'n plaas met die naam Walshacres of so iets, daar het nie lank terug nie 'n Halflinger onder die bome op die werf gele
  6. The Following 2 Users Say Thank You to Francois Theron For This Useful Post:
  7. #4
    cape town
    Thanked: 54
    http://www.wilddog.za.net/forum/inde...topic=144978.0
    a rebuild story from a motorbike site (Wilddogs)
  8. #5
    Sep 2017
    Witbank
    Naand ek het ook n halflinger ek is opsoek na n engine en n gearbox as julle van een weet
  9. #6
    Bethlehem
    Thanked: 2881
    Any progress on the rebuild/restoration??
    "Everything You See, I Owe to Spaghetti" (Sophia Loren)
  10. #7
    Bellville
    Talking Re: Halflinger herstel poging
    Quote Originally Posted by dieterf View Post
    Hey! Dis my l˘rrie daai!
  11. #8
    Thanked: 1192
    Asks for password.
    1999 Discovery 1, 300 Tdi - "Tink Tanky"
    2004 Discovery 2 Td5 - "Blink Tanky"
    "...it is abundantly clear that you are an arrogant C-nut." - Estee. (I was overwhelmed. It was the nicest thing someone has said to me in a week!)
