Upgrade my car carrier - Page 9
Page 9 of 9 FirstFirst 1 2 3 4 5 6 7 8 9
Results 161 to 168 of 168
  1. #161
    Thanked: 2376
    Default Re: Upgrade my car carrier
    I miss some pics of the Cruiser and a very heavy Tractor.
    Really the guys bragging about tow vehicles should spend so time and see what Henri hauls. Then the difference most of these recoveries are done on some bad dirt roads.
    Welldone Henri bringing them home every time.
  2. #162
    Nigel
    Thanked: 2075
    I use these heavy short hauls to find any weak spots in my rig. Then I can concentrate in getting those "soft spots" strengthened.
    LC 78 Troopie 1HD-FTE
    Uniglide
    +27 zero eight 2 four 95 9252
  3. The Following User Says Thank You to Henris For This Useful Post:
  4. #163
    Nigel
    Thanked: 2075
    While loading the tractor I noticed some cracks in the a-frame. They were def not new as they had rust in them.
    So yesterday I pulled out the A-frame and strengthened it.
ID:	541330Click image for larger version.
ID:	541331Click image for larger version.
    This how I find any weak spots.
    Uniglide
  5. The Following 2 Users Say Thank You to Henris For This Useful Post:
  6. #164
    Nigel
    Thanked: 2075
    Also added 2 jacking points. Can use either the highlift or the other ones.
    Got 2 of these jacks.Click image for larger version.
ID:	541553Click image for larger version.
ID:	541554Click image for larger version.
    Uniglide
  7. #165
    Wartburg.
    Thanked: 491
    Well done for picking up the cracks.
    Imagine breaking down out of the with a vehicle on the back in the middle of no where ..... no Henris to come fetch you
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
  8. #166
    Nigel
    Thanked: 2075
    I regularly "kick the tyres". Check bearings. Check brakes. Look for cracks, actively. It is an item that takes the brunt of the punishment. Needs to stay reliable.
    Quote Originally Posted by Chris8d View Post
    Uniglide
  9. #167
    Thanked: 830
    I am no Mech eng, but those that know modal analysis can tell you that sometimes making a trailer weaker (less stiff) can move your natural frequency outside a mode excited by the vehicle and increasing stiffness can move you smack into a mode likely to be excited by your driving.
    This is why the Mech eng dudes have matric and design to optimize both performance and cost.
    Not sure how this would help but sometimes making it stronger may be the wrong move. Again, I know the physics, but donít know enough Mech Eng to offer any useful suggestions.
    Good luck either way and I greatful for the service you offer to those in need.
  10. #168
    Nigel
    Thanked: 2075
    Yes, I understand where you are going with this. But I did not add rigidity on the the trailer. Just strength.
    The whole trailer is actually very flexible.
    Uniglide
