Page 12 of 13 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 LastLast
Results 221 to 240 of 241
  1. #221
    Midvaal
    Thanked: 2842
    Default Re: Upgrade my car carrier
    Henri, any reason why you could not just fit a new dizzy and drive it out?
    Closest dizzy is 300km away and it was around lunch time, on Saturday.
    Car is here with me now and I am having a battle finding spares. 305 Chevy. V8
    Uniglide
    +27 zero eight 2 four 95 9252
  2. #222
    Midvaal
    Thanked: 2842
    Quote Originally Posted by heatlie View Post
    Please explain what is a dizzy I have no clue at all
    Distributor.
    Modern petrol engines don't use them any more.
    Uniglide
  3. #223
    Apr 2011
    Thanked: 658
    Give Twain from Mcnab Engineering a call - 071 3 5 6 2 0 7 9
    He's known in the Hotrod Scene for rebuilding Chev Motors
    Hou op om almal altyd gelukkig te probeer hou, Jy is nie n braaibroodjie nie
  4. #224
    Midvaal
    Thanked: 2842
    Quote Originally Posted by spicydave View Post
    The dizzy is sorted. The float on the shaft was 1,9mm. I have shimmed it with a copper washer and it is now about 0,1mm. So I am sure it is good. Just waiting for Cargo World in Springs to get back to me on a cap, a rotor, points and a condenser.
    Uniglide
  5. #225
    Feb 2020
    Minneapolis and Las Vegas
    Thanked: 1791
    Nee. Hierdie is fataal. Op die teerpad sal die straps mekaar deur sny. Vergeet nog van grond pad.
    As jy nie in die wiele kan vasmaak nie, dan om die as. Maar ja. Daar word baie geld spandeer op die vering van die nuwe kare. Gebruik dit tot jou voordeel.
    X2
    That’s an accident looking for a place to happen! Those are great tie downs, but here used very incorrectly…
    David Vierra
    Needs palm trees & sun…
    ‘22 Ford F-350 4X4 7.3L
    ‘22 Ford Transit T-350 AWD (Work)
    ‘52 Beech Bonanza
  6. #226
    Kathu
    Thanked: 5108
    Get a low profile electronic dizzy.
    Best mod on any Chevy v8
  7. #227
    Midvaal
    Thanked: 2842
    Problem is that there is literally no space behind the dizzy, to the firewall. The owner brought a very nice fancy dizzy, but it is about 6" in diameter. The stock one is about 4"
    But he wants to stick with the points. I would go with the module that 4x4 direct has on offer.
    Uniglide
  8. #228
    Robertson/ Larissa, Greece
    Thanked: 6859
    Ok thought it was stock
  9. #229
    Dec 2012
    PMB
    Thanked: 930
    Lol, 4Y Toyota's don't travel on trailers.
  10. The Following 2 Users Say Thank You to TOY4X4 For This Useful Post:
  11. #230
    Kathu
    Thanked: 5108
    That is why I say low profile electronic.
    Old dizzies with points is a waste of time.
    This.
    https://www.ebay.com/itm/26357496288...wAAOSwPuFeyFtQ
  12. #231
    Kathu
    Thanked: 5108
    The Chevy Dizzy at the back of the engine is and will always be a challenge.
    Better even fit a trigger wheel and crank sensor and dump the Dizzy
  13. The Following User Says Thank You to grips For This Useful Post:
  14. #232
    Midvaal
    Thanked: 2842
    Busy doing some maint. Checking bearings. Changing some tyres.
    Big trip looming.
    Uniglide
  15. The Following User Says Thank You to Henris For This Useful Post:
  16. #233
    Thanked: 3304
  17. The Following 2 Users Say Thank You to stephenplumb For This Useful Post:
  18. #234
    Nov 2016
    Hillcrest
    Thanked: 335
    Big trip looming.
    Hi Henris, no news on the big trip yet?
    So enjoy your adventures.
  19. #235
    Midvaal
    Thanked: 2842
    Quote Originally Posted by Gavin49 - (Ad Rem) View Post
    Been and back.
    Was a trip for Tuffstuff and there were some serious health issues for the owner as well.
    So I think I will just leave it at that.
    But, it was 5,000km in 8 days. 4 border crossings and a 4hr load exercise in 50deg heat.
    Uniglide
  20. The Following 11 Users Say Thank You to Henris For This Useful Post:
  21. #236
    Nov 2016
    Hillcrest
    Thanked: 335
    Been and back.
    Thanks Henris, respect your confidentiality.
    Pity though as so enjoy your reports.
    Travel safe.
  22. The Following User Says Thank You to Gavin49 - (Ad Rem) For This Useful Post:
  23. #237
    Midvaal
    Thanked: 2842
    Went up to Kgaligadi again. Had to collect a Forward Control LR. 15B Toyota Dyna engine, and the pinion shaft cried enough.
    But, it was 39km from Nossob. In the dunes.
    Towed it out on a snatch strap. Then loaded at Nossob.
    Now the trailer needs some TLC. I have broken the shackles that hold the blades, to many times.
    So some mods and she will be better again.
ID:	659802   Click image for larger version.
ID:	659803   Click image for larger version.
ID:	659804   Click image for larger version.
    Uniglide
  24. The Following 9 Users Say Thank You to Henris For This Useful Post:
  25. #238
    Wartburg.
    Thanked: 940
    Good work Henris.
    Thank you for the updates and pictures, it is always nice to see what you are up to.
    Keep up the good work!
    Toyota Land Cruiser 79 DC V8
    Toyota Land Cruiser 79 SC V8
    Toyota RAV-4 2.2 D4D
    ZS5CL
  26. The Following User Says Thank You to Chris8d For This Useful Post:
  27. #239
    Gaborone, Botswana
    Thanked: 2140
    Die Cruiser kan werk!
    Wat weeg daai Forward Control soos hy daar is?
    Kobus
  28. #240
    Midvaal
    Thanked: 2842
    Omtrent 3,2ton
    Uniglide
