Torque curve on new Nissan hardbody 2.5 diesel
Results 1 to 15 of 15
    Germiston
    Default Torque curve on new Nissan hardbody 2.5 diesel
    Hi All,
    hope there is someone who can help me. Bought a new 2.5 D Hardbody DC few weeks ago. Very happy with the vehicle.
    I'm looking for the torque curve and power graph for this engine. Can anybody assist?
    regards
    Buks
    Thanked: 9685
    Default Re: Torque curve on new Nissan hardbody 2.5 diesel
    Quote Originally Posted by BdJ View Post
    Hi All,
    regards
    Buks
    Reenen knows which version of the YD25 was used in the NP300. We'd need that to be able to match the version to a dyno graph.
    There were 5 different tunes/versions.
    Langs die rivier, op n berg
    Thanked: 2435
    98kw, 304 nm engine in 2.5 no300
    Thanked: 9685
    post deleted because some people probeer slim wees
    Thanked: 2435
    Verduidelik daai grafiek asb, ek bietjie dom
    Thanked: 2435
    dankie
    YD25DDTiNissan Navara/Frontier (D22)[6]2001–present2.5 L (2488 cc)89.0 mm100.0 mm18:198 kW (133 PS; 131 hp) @4000 rpm304 N·m (31.0 kg·m; 224 lb·ft) @2000 rpm
    Obviously the two lower readings are standard.
    En is dit die ddti of die dci se kurwe daai? Die ddti van 2001 het n rotary injectorpomp, die dci het common rail. Dink die common rail weergawe het eers in 2005 uitgekom.
    Germiston
    Ek het die 98kw weergawe, so dink nie dis die regte grafiek nie. Dankie in elk geval vir julle moeite!
    Groete
    Buks
    Thanked: 1026
    dankie
    Groete
    Buks
    Ya dis reg. Ek het Jelo se post vir you gefix...
    Germiston
    Dankie! Verstaan ek reg..... Dis KW op die wiele wat ons in die grafiek sien..... So dis 94 op die wiele nadat hy gechip is?
    Ek is n leek op die gebied. Watter lyne op die grafiek se kw en wat is torque?
    Help asb.
    Dankie
    Thanked: 1026
    Help asb.
    Dankie
    Ek moet eerlik se, ek verstaan nie daai Dyno graph nie.
    Thanked: 2435
    Quote Originally Posted by pierre2013 View Post
    So ek is nie alleen nie....
  12. The Following User Says Thank You to Reenen For This Useful Post:
    Thanked: 9685
    hey ouens gaan Google bietjie self, toe?
    sal die post sommer delete
    Thanked: 2435
    Hey, chill. Ek verstaan regtig nie die grafiek nie. Wat is die waardes op die regter kant?
    En is dit vir die rotary pomp, of common rail?
    En kw bietjie laag as ek kyk na standaard as ek dit reg verstaan
  15. The Following 2 Users Say Thank You to Reenen For This Useful Post:
  16. #14
    Thanked: 2435
    Lyk asof n= rpm.
  17. The Following 2 Users Say Thank You to Reenen For This Useful Post:
  18. #15
    Thanked: 2435
    Neem aan dit is n torque kurwe sonder syfers wat saam met die kw geprojekteer is.
  19. The Following 2 Users Say Thank You to Reenen For This Useful Post:
