Results 1 to 2 of 2
    Gauteng
    Default Diesel pump calibration-ists...
    I remember a post in the old forum where someone had their diesel pump calibated by hand(!) at a place called Delta or Delco or something like that?
    Does anyone remember this?
    I have a 2.2d diesel Renault Laguna that (as much as I hate Renault) absolutely love - it's fast enough, comfortable in the way only Frenchman can achieve, has one electonic part in the entire engine (the diesel cut off solenoid) and does an honest 6 - 7l/100km around town and at 130km'h. I've just had the catalytic converter cut out which looks like it was blocked solid (the vehicle has 200k+ km on it) and now although it is more zippy, it smokes under acceleration. I'd like to make sure that it is not overfueling.
    Dave
    Fortuner 4l Auto - still got the rubber side down...
    Gauteng
    Hmmm - seems that the vehicle is not smoking so much any more - suspect the blocked cat caused soot build up in the manifold and maybe it was blowing that accumulation out?
  1. Advantages of 50ppm diesel
    By Sanman in forum Vehicle & Technical Chat - General
    Last Post: 2015/04/16, 05:11 PM
  2. Advantage of a Diesel vehicle?
    By Krimpie in forum Mitsubishi
    Last Post: 2014/12/26, 12:05 PM
  3. JK CRD leaking diesel pump.
    By JDeV in forum Jeep
    Last Post: 2010/11/08, 11:57 PM
  4. Td5 service and diesel pump
    By Kadila77 in forum Land Rover
    Last Post: 2010/08/31, 01:27 PM
  5. Fuel pump calibration
    By Johnna in forum Mitsubishi
    Last Post: 2010/06/02, 10:39 AM
