AmadaXtreme Frankenstein "Jeep" Build
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 53
    Pretoorsdorp (Centurion)
    Thanked: 148
    Default AmadaXtreme Frankenstein "Jeep" Build
    After a long upstairs debate I have sold my JK Rubicon......
    So got myself a real project Frankenstein "jeep" to rebuild and play with...
    Chassis: It is based on a Nissan Safari
    Front Suspension: Leaf Springs
    Rear Suspension: Leaf Springs
    Steering: Steering box with old school link system
    Diffs: Open Diffs - std Safari
    Motor: Lexus V8 1UZ
    Gearbox: Auto
    Body: LWB CJ Fibre glass body
    Wiring: A real mess
    Tyres: 33 x 12.5 x 15
    Many ideas at this stage... but lets see where this is going to take us....
ID:	456021   Click image for larger version.
ID:	456022   Click image for larger version.
ID:	456023   Click image for larger version.
ID:	456024   Click image for larger version.
ID:	456025   Click image for larger version.
    WWW.AMADAXTREME.CO.ZA
    203 Edison Crescent, Weca 4x4, Hennopspark, Centurion, GPS: 25°52’19.0”S 28°09’59.3”
    Cobus Böhmer CEL: 071 641 7947 Email: cobus@amadaxtreme.co.za
    May 2015
    Bethlehem
    Thanked: 72
    Default Re: AmadaXtreme Frankenstein "Jeep" Build
    Sterkte, begin deur om iets aan daai grill te doen asseblief
    2012 JK Rubicon (PANDA) ..... because jeep......
    2011 V9X Pathfinder...... because Baby to be onboard
    EX 2009 Jimny , tricked to the teeh....
  3. The Following User Says Thank You to Su-SWYS-ki For This Useful Post:
    KEMPTON PARK
    Thanked: 304
    Looks familiar , if its the same one , previous owner had lots of overheating problems in Moz , Cobus if I am not mistaken that used to belong to your cousin ?
    05 TJ SAHARA
    08 3.8 JK ULTD RUBICON
    Apr 2015
    Thanked: 61
    I have a JK body and chassis available, much nicer to build a toy.
    JK CRD
    Willys CJ2a
    Yamaha YZ250
    Thanked: 148
    Quote Originally Posted by NEON DEON View Post
    Yip, was his... now its mine, plan is to rebuild and change a few things - cooling system is going to be one of the items and maybe the motor as well, Im not n huge Lexus fan
    Quote Originally Posted by TheFlash657 View Post
    Already got this.... and big plans.. You not selling the body? 2dr or 4dr?
    Randvaal, Gauteng
    Thanked: 40
    [QUOTE=Navigator;3649458]After a long upstairs debate I have sold my JK Rubicon......
    Motor: Lexus V8 1UZ
    Gearbox: Auto
    Wiring: A real mess
    Consider moving this to either the Nissan or Toyota subsection before Apoc sees this thread.
    Walter Kutcher
    Ford Kuga 2.0 TDCI AWD (2013)
    Honda Accord 2.0 (2014)
    Jeep Wrangler (2009)[Sadly no longer with us]
    Thanked: 148
    That was a problem on where to post this.. as its not really a Jeep... but not a Nissan or Toyota as well...
    Randvaal, Gauteng
    Thanked: 40
    Quote Originally Posted by Navigator View Post
    Well besides the grill and the engine and the chassis it does somehow resemble a JEEP, so I recon it will be welcome here.
    Best of luck with the build and keep the pictures coming.
    As a Web Wheeler, that "Frankenstein" will put me to shame.
    And that I respect.
    Walter Kutcher
  10. The Following User Says Thank You to WalterK For This Useful Post:
    Apr 2015
    Thanked: 61
    Selling 2dr for R25000
    JK CRD
    Willys CJ2a
    Yamaha YZ250
    Thanked: 61
    Please send me photos on 081 twofoursix 9523
  13. #11
    Thanked: 148
    Plan this far as follow...
    • Remove front and rear diffs
    • Remove leaf springs and cut off all brackets for the leaf springs
    • Design long arm suspension for front and rear with preferable coil over suspension
ID:	456066   Click image for larger version.
ID:	456067   Click image for larger version.
  14. The Following User Says Thank You to Navigator For This Useful Post:
  15. #12
    Thanked: 148
    Busy with the rear suspension... decided to go for a A-Frame Link Suspension on the back... some google pics to show what the plan is with some progress pictures of the Links we are busy with.
    Only small hick-up, for the A-frame the mounting point needs to be in the middle of the axle but this rear axle the pampoen is not in the middle, plan to manufacture a bracket to mount the A-frame on top and in the middle of the axle,
ID:	456241   Click image for larger version.
ID:	456242   Click image for larger version.
ID:	456243   Click image for larger version.
ID:	456244   Click image for larger version.
ID:	456245   Click image for larger version.
  16. #13
    Oct 2006
    Thanked: 21
    Goodluck with the venture looking forward at the end result!
    '86 SFA Hilux V6
    Sponsors:
  17. The Following User Says Thank You to NicoP For This Useful Post:
  18. #14
    Kathu
    Thanked: 2440
    In Afrikaans het ons die gesegde die " Beste struurman staan op die wal"
    Please do not see this as negative comment. With all the trouble in manufacturing the A-frame I would have opted for a four link suspension. A frames tend to snap the attachment to the diff with side way forces.
    The little Patrol have the same suspension layout as your Jeep, You will be surprised in the level of flex we have achieved with leafs, traction bar and SOA setup. I will stick my neck out and say that that level of flex can only be surpassed with long arms and coil overs.
    Just my humble opinion.
  19. #15
    Thanked: 148
    Thanks for the comments, I like getting as much as possible ideas from different areas,
    I agree with you, there is nothing wrong with leaf spring's flex if done correctly. The old leaf springs are bend and beyond repair and wanted to build something different.
    We going to give the A-frame some extra support, didnt want to go the 4 -link system as there are many such systems out there - and have done that before,
  20. #16
    Thanked: 148
    Some progress fotos.... took the body off, easier to get to the suspension parts to be welded on the chassis
ID:	457975   Click image for larger version.
ID:	457976   Click image for larger version.
ID:	457977   Click image for larger version.
ID:	457978   Click image for larger version.
ID:	457979   Click image for larger version.
  21. #17
    Oct 2006
    Thanked: 21
    Any progress?
    '86 SFA Hilux V6
    Sponsors:
  22. #18
    Jan 2016
    Pretoria East
    Thanked: 18
    Whats your plan with the electrics Cobus? New fusebox, harnass?
    et ubi sum ego non sum
    -Use your seat belts!-
  23. #19
    Thanked: 148
    Quote Originally Posted by NicoP View Post
    Any progress?
    Sorry has being a bit busy, please see below... some pics
    Quote Originally Posted by MikeTheSpike View Post
    All wiring already removed! Need to redo everything
Name:	IMG-20170801-WA0007 (800x450).jpg
ID:	460198   Click image for larger version.
Name:	IMG-20170801-WA0006 (800x450).jpg
ID:	460199   Click image for larger version.
Name:	20170801_100202 (600x800).jpg
ID:	460200   Click image for larger version.
Name:	20170731_133041 (800x600).jpg
ID:	460201   Click image for larger version.
Name:	20170802_091643 (800x600) (2).jpg
ID:	460202   Click image for larger version.
Name:	20170802_091653 (600x800).jpg
ID:	460203   Click image for larger version.
Name:	20170802_163635 (800x600).jpg
ID:	460204   Click image for larger version.
Name:	20170821_102059 (600x800).jpg
  24. #20
    Jan 2016
    Pretoria East
    Thanked: 18
    Now thats how I like to see, you busy.
    Nice build. Please just do something about that grill...
    Let me know what you looking at for the electrics, as I have to redo mine entirely also and there's some nice harnassing kit on ebay that could suit you.
    BTW> I got my steering stabilizer sorted with a bracket I welded up and it works quite nicely.
    Last edited by MikeTheSpike; 2017/09/09 at 08:05 PM. Reason: That grill is not mounted right!
