Suspension Pathfinder Suspension and Body Spacers
Results 1 to 3 of 3
    Jan 2007
    Elardus Park
    Default Pathfinder Suspension and Body Spacers
    Morning.
    So last Saturday I decided to quickly replace the front brake pads on my Pathfinder, as I have bought a set about 8 months ago, when replacing the rear pads. There was no need for the front pads to be replaced. Till now. Quickly removed the one wheel and the bolt on the caliper, as well as the old pads.
    When fitting the new pads, I know the protruding caliper pistons might give issues sometimes and where ready for that, but............................................... ........ThE FREAKIN' PAD AT THE REAR DON'T WANT TO SLOT INTO PLACE!!!!!!!!
    Closer investigation and it does look a little different to the old ones, look on the packaging and there it clearly states.........F B/Pads for NISSAN MURANO!
    So if anyone needs new pads for their Murano, contact me, I have a set for the front.
    So back to the topic:
    Suspension:
    As I had the Patty jacked up and one front wheel off, I had a look to see if anything was out of place. There has been a slight metal screeching / squeal sound when the left front suspension moves up and down. Previously had the vehicle at 2 suspension repair shops, they couldn't find anything wrong.
    On inspection now, I found this:
ID:	455701Click image for larger version.
ID:	455702Click image for larger version.
    Seems like the bushes flex and touch the on the outside of the mountings, all on the lower control arm.
    The right hand side has no such marks.
    Body Spacers(?):
    Then just checking on the rest of the bolts and other stuff underneath, my caught this:
ID:	455704Click image for larger version.
    There is gaps between the "washer" and the spacer itself on the front mounts, but not towards the rear (or at least very little).
    Could anyone with experience on these vehicles give me some feedback as to these 2 scenarios, is this normal?
    Did try and get a second opinion from this one, but she wasn't too helpful at 3 months old.
    Thanks in advance,
    Marius
    _____________________________________________
    2013 Nissan Pathfinder 2.5 dCi SE 4X4
    Ex- 2000 Defender 110 Td5 - MUGWUMP.
    Ex- 1998 Range Rover P38 4.6 V8 HSE - Shrek
    Ex- 1997 Jeep Cherokee 4.0 - Thriller
    Ex- 1998 Toyota Hilux 2.4 D/C 4x4 Ltd - Rooiwyn
    Ex- 1998 Jeep Wrangler 4.0 (Manual) - Sputnik
    Ex- 1997 Jeep Grand Cherokee ZJ 4.0 A/T
    Ex- 1995 Suzuki Vitara 1.6 JLX
    Jan 2010
    Almelo, Overijssel
    Thanked: 231
    Default Re: Pathfinder Suspension and Body Spacers
    Those gaps in the last two pics, was that with the vehicle jacked up? If so, that might explain it. Can's comment on the first pics.
    Jan 2007
    Elardus Park
    Quote Originally Posted by Lord Farquart View Post
    Thanks for the reply Lord Farquart.
    The space is still there, even when not jacked up.
