Results 1 to 3 of 3
    Mar 2013
    Default Help please: Need to replace headlight lamp
    Hi there.
    I urgently need your advice. I need to replace the headlight lamp of my Tunland, the one that looks like a xenon light.
    1. What is the spec of the lamp?
    2. How do I do it? My hand is to big to get into the space to take it out. Do I take off the complete light unit?
    Thank you very much. I will really appreciate some help. This is the first time I have to do this. Fog lamp also failed and have to replace this as well.
    Deon
    Thanked: 311
    Default Re: Help please: Need to replace headlight lamp
    Mine as well.......same lamp..... Remove the complete air filter housing then it is easy....
    PRETORIA
    Thanked: 42
    H1. Best is to remove battery and air filter box, but replacing is possible with out removing both. Just a tight fit.
    FOTON TUNLAND 4X4 LUX
