Sticky gears Triton 2.5 Super select
Results 1 to 4 of 4
    Oct 2012
    Vrede
    Default Sticky gears Triton 2.5 Super select
    Hi Guys
    Can someone help with the correct gearbox oil for a 2008 2.5 4x4 Triton?
    My gears started to get sticky about 15 000km ago, i changed oil to Caltex MTF (previously easy shift - apparently), But the gears are still sticky (worse when cold). Should i add an additive, or try other oil? Vehicle has just under 240 000km on the clock.
    Any advise from Triton owners will be greatly appreciated.
    Feb 2012
    Thanked: 27
    Default Re: Sticky gears Triton 2.5 Super select
    I also had the same sticky second gear. Replaced with Mitsu GL3 and was the same. Then replaced with easyshift and made no difference.
    Finally replaced with Castrol Syntanse and its been super smooth for 30 000km
    Mitsubishi Triton 3.5V6 d/c 4x4
    Oct 2012
    Vrede
    Dankie Stoetbulkrokkedil (Sjoe, dis n mond vol)
    Ek waardeer dit. Ek weet daai is duur olie, sal kyk waar mens dit die goedkoopste kan kry.
    Feb 2012
    Thanked: 27
    Quote Originally Posted by Sputtie View Post
    Plesier ou maat. Hy is beslis die geld werd
