Swambo`s New Platkar. - Page 5
Page 5 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 81 to 100 of 237
  1. #81
    Kathu
    Thanked: 2889
    Default Re: Swambo`s New Platkar.
    Trevor ek is nog besig met huiswerk. Jy kry `n groter cooler wat op die plek van die oorspronklike inbout.
    Dan kry jy `n front mount cooler. Coolers onder die enjin kap het `n heat soak probleem met stadige 4x4 werk.
    So ja front mount lyk na `n wenner maar ek is nog besig met navorsing.
  2. The Following User Says Thank You to grips For This Useful Post:
  3. #82
    Kathu
    Thanked: 2889
    En dan is ek en Toyota klaar besig om skouers te skuur oor die clutch. Daar is n` buletten uit. So hulle gaan hom upgrade anders
    raak die Cruiser `n baie duur projek. Fantastiese voertuig met `n paar ernstige ontwerps probleme.
  4. #83
    Thanked: 101
    Dankie dat jy laat weet het van die "buletten" ek sal die manne hier ook se.
    Moenie leef met die droom "ek gaan dit doen as ek eendag aftree" want dit mag dalk nie gebeur.
    2019 SYM Citycom S300i
    2019 BMW 1250 GS
    2018 Toyota Hilux 2.8 4x4 Raider.
    2018 Mercedes-Benz V-Class 250d Avantgarde
    2012 Dethleffs Esprit Motor-home.
  5. #84
    Kathu
    Thanked: 2889
    Had the opportunity to test the Cruiser fully load with a double rooftop tent on a dirt road again this past weekend.
    Cannot believe the difference with the rear spacers fitted. Very satisfied with ia gravel travel abilities now.
  6. The Following User Says Thank You to grips For This Useful Post:
  7. #85
    Pretoria / Motopi Village, Northern Botswana
    Thanked: 272
    Yip...i don't carw what anyone says, the spacers DEFINATELY make a difference!!
    2014 Land Cruiser 76 SW with extras
    2019 Jaguar Inkwe 4 Offroad Caravan
  8. The Following User Says Thank You to Trevor_Mathews For This Useful Post:
  9. #86
    Kathu
    Thanked: 2889
    So we took the Cruiser to Whooopa. Did the Waterford route on Tuesday. With the lockers in it was able to crawl most of the dunes on the route. The v8 have nice torque permit you does not ask serious torque below 1500rpm. As I am used to the Yank Ranger I stalled it a few times when labouring below 1000rpm. I need to adjust my driving style. Did a few pull aways halfway up dunes that really impressed.
    The Ranger had a failed wheel bearing so I decided to go back home to source parts early Wednesday morning. Left Boegoeberg at 4:30 arrived in Kathu 6:50. Load some tools and left BMG at 8.30 back in Boegoe at 11:45 with two quick stops n Groblershoop.
    Covered about 580km in and out. Traveling mostly gravel I could test the Cruisers gravel travel at good speed.
    It took the bad gravel road quite well and I am satisfied with its handling. Only thing I did not like was the way ABS kicked in.
    This again can be contributed to my driving style. I like to touch the brakes before a sharp turn to loosen the tail a little to take corners at speed. Every time I tried this the ABS kicked in.
    The run to Kathu and back with the Waterford route included turned out 5.5km/l. With Swambo at the wheel at a steady 80 to 100 on the dirt we saw 7.3 on Monday.
    Cruiser is solid with no rattles even on the worst corrugated sections. We bought the Cruiser to do gravel travel as its main function as our gravel roads are getting worst by the day.
    Will soon start with some mods and will keep you updated.
    Yes the Cruiser even qualified me for Dos Sete Diablos up against the Long dune.
  10. #87
    Sep 2011
    Potch/Brits
    Thanked: 583
    Lekker Oom Christo.
    ABS...well dont like it either, you can always bypass the ABS with the handbrake just before the turn...
  11. #88
    Thanked: 354
    "Got some real nice dune crawl clips."
    Christo, so gaan jy ons nou net terg, of moet ons nou nog lank wag?
    2011 Fortuner 3.0 D-4D 4x4
    2008 Lexus IS250 V6
    Jaco
  12. The Following User Says Thank You to JacoE For This Useful Post:
  13. #89
    Kathu
    Thanked: 2889
    Jaco sal hul post.
  14. The Following User Says Thank You to grips For This Useful Post:
  15. #90
    Kathu
    Thanked: 2889
    Dune Crawl Speel Duin
  16. #91
    Kathu
    Thanked: 2889
    This is Speel Duin other time other Whooopa, to show what Speelduin look from another angle
  17. #92
    Kathu
    Thanked: 2889
    For some time now I want to take off the intercooler to measure the engine intakes as well as intercooler inlet and outlets. Made templates of the engine intakes.
    I believe allot can be done to improve airflow.
    While at it I made a stainless plank for the EGR.
    Plan to install a front mount intercooler. The radiator have about 80mm that it can move closer to the engine.
    Set myself a target to improve power to 180kw and about 550nm without chip tuning.
ID:	465736   Click image for larger version.
  18. #93
    Robertson/ Larissa, Greece
    Thanked: 3377
    I'm waiting with baited breath since a Cruiser V8 is somewhere in my future once back in SA!
  19. #94
    Sep 2011
    Potch/Brits
    Thanked: 583
    Oom Grips, that didnt take you long to get going since the cooler mention on Swart Jans thread.....
  20. #95
    Kathu
    Thanked: 2889
    Want to do the following mods on the Cruiser over then next few months.
    1. Rear bumper with tow bar.
    2. Rock sliders. Maybe design my own stainless one`s that can store water.
    3. Steel Rims and 33" tyres.
    4. Free flow exhaust system.
    5. Intercooler.
    6. Speedo correction after the 33`s.
    The D4D v8 have a very poor intake system with the turbo boost to intercooler a smaller diameter hose than a 2.0l VW TDI engine.
    Also very tiny outlets to engine intake from Intercooler.
    My motive is not more power but better engine efficiency, Which in the end will increase the power.
    I am sure with some hard mechanical mods that you will come very close to a chipped engine.
    Except from power increase an easier breathing engine will score on consumption.
    Still got the Yank Ranger to satisfy my Horse Power urge.
    Post 55. On to it since we own the Cruiser. Think most of the homework done now to start doing things.
  21. #96
    Wartburg.
    Thanked: 616
    Oom Christo, hoekom die blanking plate en nie n EGR delete nie?
    wat is oom se rede agter dit?
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
  22. #97
    Kathu
    Thanked: 2889
    Chris ek het dit vir eers so gedoen vir toets doeleindes. Ek het sover baie oor die onderwerp gelees.
    Daar is voordele en nadele.
    Daar moet ook ingedagte gehou word dat die turbo se vanes vacuum beheer is op die 70 series. Delete kan tot turbo surge ly met deceleration. Op die 200 word die turbo wanes deur die ECU beheer ek sal veiliger voel om `n delete op `n 200 te doen as op `n 70.
    Daarom die blank plaatjie met die 9mm gat. Dit help om dluk the normaliseer met deceleration.
    Maar ek is geen ekspert nie soos gesÍ wil hom eers toets.
  23. #98
    Kathu
    Thanked: 2889
    So the V8 used a little bit of oil, about 500ml per 1000km Started to look at the oil specs. Toyota uses a Toyota branded 10W30 oil. For top ups you need oil from the dealer. According to the Cruiser owners manual it actually needs 15W40 oil in our environment.
    With the Cruiser approaching 40 000km I have decided to do the service myself. All my other engines runs on Dello 400. The Guru`s from the Cruiser Club also recommended Dello 400. Yes I know I kicked the warranty but pay for services with the wrong grade of oil is not inline with my way of doing things.
    Cruisers are really easy to service and you can see it were build with the idea of servicing it in the bush. One of the reasons for buying the Cruiser the no nonsense design. Have covered more than 2000km since the service. The good news no need for oil top up. Still on the mark as serviced. Keeping inmind that we have just completed a West Coast trip with lots of 4x4.
    Really enjoyed the Cruiser on the trip. Love the low down grunt of the diesel v8.
ID:	471768   Click image for larger version.
  24. #99
    Thanked: 228
    Christo het jy al op WR Offroad se site gekyk? Ek sien hulle sit ook 'n groter balance pyp op die uitlaat tussen die twee banks.
  25. The Following User Says Thank You to Wicd For This Useful Post:
  26. #100
    Kathu
    Thanked: 2889
    Thanks Wickus, die manne het mooi goedjies.
