Swambo`s New Platkar. - Page 2
Page 2 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 21 to 40 of 237
  1. #21
    Oct 2008
    Faerie Glen Pretoria
    Thanked: 191
    Default Re: Swambo`s New Platkar.
    Quote Originally Posted by carlp View Post
    Ek wil nou die draad derail nie.
    Maar sou mens die 5de rat verander, dan sal dit ook die betroubaarheid om in hierdie rat swaer te sleep beinvloed. Het die ausies n ander ratkas as ons?
    Die Ozzies het 'n ratkas waarvan die 2de rat en 5de rat effens langer is. Dit bring glo die refs van 3000rpm af na ongeveer 2500rpm @120km/h.
    Ek het nou die dag my FJ gery @ 120km/h en 3000rpm (in sy vierde rat). Dis nie 'n lekker rit nie.
    2012 Sport FJ Cruiser "Black&White RiceBowl"
    1986 Hilux DC 4x4 "White RiceBowl"
    Agteros - you should stick to your rice bowls! - HGBosch
  2. #22
    Okahandja, Windhoek
    Thanked: 870
    Dink ek gaan hom FOX
    Cruiser met n pap voor shok ry op sy lekkerste Sal will hoor wat maak die Fox!
    Johan Kriel
  3. #23
    Kathu
    Thanked: 2889
    What do the Cruiser guys do about rims. Looking for a nice set of steel wheels.
    Rims for the Cruisers seems quite scarce.
  4. #24
    Robertson/ Larissa, Greece
    Thanked: 3377
    Christo in your position I'll look around for and only fit the steel rims from the 105 Cruiser SW. They will be expensive, but they look OK, fit properly and are very strong.
  5. #25
    Kathu
    Thanked: 2889
    Francois the Cruiser have 5 lug rims.
  6. #26
    Thanked: 3377
    Yeah I know but it is essentially the same
  7. The Following User Says Thank You to Francois Theron For This Useful Post:
  8. #27
    Kathu
    Thanked: 2889
    Ok so we still have not sold the Volla Bus. Now remember this is Swambo`s favourite of all favourites.
    Kept a close eye on her moves this past week. Seems the Cruiser has become the favourite of all favourites.
    Sy sÍ hy ry so maklik, sy kan selfs in 2de rat weg trek.
    That was one thing I hated about the Volla bus you needed to work that gearlever. Think I have the record in our household for stalling it.
    Yes on paper many smaller diesels beat the 4.5 D4D with power and torque. I also think that very few smaller diesels will beat the 4.5 D4D with idle and off idle torque. My engine torque test is to stick it in fourth gear at idle speed and than accelerate. Very easy with the Yank v8`s. Well the Cruiser past this test.
    Few small things on the Cruiser that bothers me but I will sort that with time. First on my do list were rear wheel spacers, I could not stand that knock knee look. That caught my eye every time I look at the Cruiser.
    I also do not like the unprotected ABS sensors, the low mounted alternator and the position of the oil pressure sensor under the engine. As said earlier in this thread it is not going to see serious off roading but we travel on nasty little twee spoor paadjies from time to time. I have seen what a little driedoring on a middle mannetjie can do to wiring. Plan to protect above mentioned items.
    The following items I felt should have been standard items on the Cruiser. 12v socket at the rear. Towbar as standard. Better center console. Correction of rear wheel tract width. I am sure the narrower rear track is the problem for the jittery feeling at speed on gravel.
    I have included an ONCA front bumper in the deal which will arrive this coming week. O ja and when parked next to the Yank Ranger the Cruiser is a Platkar.
  9. #28
    Vioolsdrift
    Thanked: 140
    Lol, vanooggend dink ek daaraan om jou te se om dan net n mooier bumper op te sit, soos bv n Onca
    daar doen jy dit toe voor ek jou die raad kon gee
  10. The Following User Says Thank You to superhansie For This Useful Post:
  11. #29
    Kathu
    Thanked: 2889
    Quote Originally Posted by superhansie View Post
    Sy bumper het `n merk op die regterhoek. Ek en die handelaar `n goeie vriend van my het mekaar se hande mooi gevat.
    Ek is mos nie `n Toyota Die Hard nie. So jy gaan nie ARB en OME op die Cruiser sien nie.
    So lyk die bumper wat ons bestel het.
  12. The Following User Says Thank You to grips For This Useful Post:
  13. #30
    Wartburg.
    Thanked: 616
    Daai is n baie mooi bumper oom Grips.
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
  14. The Following User Says Thank You to Chris8d For This Useful Post:
  15. #31
    Kathu
    Thanked: 2889
    Find myself playing with gear ratio calculators on more and more occasions.
    Even find some nice speedo correction devices.
    Ratio changes, overdrives, bigger tires.
    You get down to crazy costs per 100 rpm.
    Standard 5th gear rpm at 120 = 2717
    Advance Adaptors Overdrive you will run a cool 1960rpm at 120km/h. At least you will have 10 forward gears in high range R22 000.00 before import duties. Few mods and you can add another R10 000.00
    About R40 000.00 plus to shave off 757 rpm.
    Marks 4x4 Overdrive R82000.00 before duties. Will give you ten speed and a 2024 in 5th gear @120.
    285x75x16 Will keep it happy at 2619rpm a 100rpm gain over stock.
    33X 16 will see you at 2600rpm at 120.
    35x 16 cannot be done without a lift in my humble opinion. 2457 at 120.
    Speedo correction interface R2030.00 before duties.
    Diff ratio change to 3.55 land you with 2473rpm at 120. You will need to fork out R40 000.00.
    Does not matter which way you look it will be costly. In person I would love the Advance Adaptors overdrive as I have a similar unit in the Yank Ranger and you double all your choices.
    But then it will take many many km`s to kill the costs of these conversion with consumption gains alone.
    Maybe 33`s and speedo correction the cheapest and easiest way to go.
  16. #32
    Kathu
    Thanked: 2889
    Hope the ONCA bumper is at the dealer. Would like to fit it today.
  17. #33
    Oct 2008
    Thanked: 191
    Ek sien die refs pla jou ook
    Ek sou al die DC gekoop het as dit nie daarvoor was nie.
  18. #34
    Mar 2017
    Okahandja
    Thanked: 725
    Wie vervaardig die bumper. Baie mooi en prakties
  19. #35
    Vioolsdrift
    Thanked: 140
    Christo , my mater Don ry 35s op sy V8. Hy het freeflow en chip op, loop lekker vir so n swaar kar.
  20. #36
    Kathu
    Thanked: 2889
    Quote Originally Posted by Agteros View Post
    Mens moet eending ook onthou die Cruiser se speedo lees 100% korrek volgens GPS op 120. Dit help nie juis met wat `n mens waarneem nie. Baie ander voertuie "over read" wat `n illusie skep dat revolusies laer loop as aangedui.
    Ek het nie slaapelose nagte daaroor nie en dink dit gaan die Cruiser `n besonderse sleep voertuig maak.
  21. #37
    Kathu
    Thanked: 2889
    Quote Originally Posted by Erwin Schimper View Post
    Hom gister gou opgesit
  22. #38
    Kathu
    Thanked: 2889
    Het hy hom gelig.
  23. #39
    Wartburg.
    Thanked: 616
    Ek persoonlik dink nie dat daar iets voud is met die gear ratios nie, as jy jou Cruiser gebruik waar voor hy gemaak is.
    Die Cruiser is nie n sports kar nie, soos ouens wat 160+ kW en 580n uit n GD6 soek .... ek onthou oom Grips se woorde altyd "n donkie sal nooit n resies perd wees nie"
    Ek onthou die day toe ek n Ford 2.5 WL gery het en toe later n Mazda DC ook in WL. Teen 120 km/Hr (op sy speedo) het jy op 3000 rpm gesit, en dan was dit nie eens n ware 120 km/hr nie, meer na 110 km/hr volgens my GPS
    Daar was duisende 2.5 WL's verkoop en niemand het ooit gekla oor gear ratios nie, almal het hom maar net so gery, en ry hulle nog so.
    Ek is baie gelikig met my Cruiser, hy doen alles wat ek van hom vra baie makliker as my 3.0 D4D of 4.2 1HZ ooit kon doen. As ek op vakansie gaan dan ry ek maar teen 120 km/hr, dit is in elk geval die spoed beperking op meeste paaie, jy is op vakansie, geniet die tyd saam met jou vamielie.
  24. The Following User Says Thank You to Chris8d For This Useful Post:
  25. #40
    Vioolsdrift
    Thanked: 140
    Het hy hom gelig.
    Ja hy het ome heavy duty op. ry sagter as wat ek verwag het.
  26. The Following User Says Thank You to superhansie For This Useful Post:
