Van Reenens Pass Back Route
Results 1 to 16 of 16
    Thanked: 39
    Default Van Reenens Pass Back Route
    Which Turn-off do we take from Gauteng side to go down Van Reenens on the old farm road.
    I think we turn left at the filling station & go round the back of the Green Lantern Inn.
    Any ideas?
    Your mind is your strongest weapon.
    Then there's.....POWER TOOLS!
    '94 LC 80 GX
    '00 Frontier 280DT 4X2
    2002 Sprite Surfer Nomad
    Jan 2014
    Ruimsig
    Default Re: Van Reenens Pass Back Route
    Thanked: 39
    Thanks, I saw those from Robbie (Tygrve) on the caravan forum some time back, but they only allow watching the vids for a couple of days, or pay R 200 a year to join the mountain passes forum.
    '94 LC 80 GX
    Jan 2014
    Thanked: 472
    When do you plan to drive the route? I have track logs that I can email to you. Just send me a PM with your email.
    Sep 2012
    Thanked: 76
    Quote Originally Posted by JCMN View Post
    This is brilliant!!!
    I cant figure out where do you turn off the N3 to get onto this pass though.
    Its not about how fast you are but about how quick you get there...
    Jan 2017
    JHB South
    Thanked: 58
    Quote Originally Posted by Die$eL View Post
    The safest is to go through Van Reenen "town" i.e. exit at the garage, and either turn right to go through the town, or continue straight (instead of turning right to the town), and turn right on the gravel road after crossing the railway (few hundred metres on, not far).
    There is another exit left off the N3 on the sharp right bend after the garage and downhill with cameras, but it's not a particularly safe exit. It does however bypass the town and lower income area.
    Jan 2014
    Thanked: 472
    Here is a start for the route. The road is also on Tracks4Africa. I see o the map it looks as if one can get to the road from behind the Caltex past the Van Reenen Railway Station also. I have not driven this section.
    Jan 2017
    JHB South
    Thanked: 58
    Quote Originally Posted by Daniek View Post
    This is the other exit I was referring to. When the highway is busy, it's not ideal to exit here, although you can. Just my opinion.
    Jan 2014
    Thanked: 472
    Agreed. One can only start the route here if you come from Gauteng and you can only exit here if you want to go down to Durban.
    This Streetview image is facing the start from Gauteng side.
    Sep 2012
    Thanked: 76
    Excellent! Thank you all! I will be sure to try it and will post pics once I do.
    Thanked: 39
    Quote Originally Posted by TimK View Post
    Thanks Tim, sorry this is so late, but my main frame computer does, not work the forum any more, so I'm using my laptop every few days.
    From the other answers, it seems quite easy and we'll be going through the town just to see what's there after how many trips rushing through to & from Durbs.
    We leave tomorrow early (Sat. 8th.)
    I'll report back after I return on Tuesday.
    Thanks all!!
    '94 LC 80 GX
    Jan 2017
    JHB South
    Thanked: 58
    Quote Originally Posted by steamer View Post
    Thanks all!!
    Enjoy, it's a beautiful area and the road wasn't bad at all when I last drove it.
    Thanked: 39
    Thanks Danie, I actually meant the above reply to you.
    Sounds quite simple.
    '94 LC 80 GX
    The Wall
    Thanked: 1676
    Are you crazy?
    Stop giving Dirk ideas.....
    "Everything has its limit - iron ore cannot be educated into gold."
    Thanked: 39
    Well, back from our sojourn down the back end of Van Reenen!
    We decided to go round the back of the service station. After getting to a bit a dead end through the town past the inn, we back-tracked and turned right straight after crossing the railway line & went through the township.
    Lovely, scenic drive until the damned google maps told us to turn right, which was in fact a shortcut, cutting out the tunnel etc.
    I had put the town of Besters in as a destination, so we ended the excursion on the Ladysmith road and had to go through 2 tolls to get back onto the N3 towards Estcourt.
    Anyway, I'll certainly do it again and get to see the old railway.
    Thanks for all your inputs.
    '94 LC 80 GX
    Sep 2011
    Potch/Brits
    Thanked: 581
    Do you have some pictures?
