Page 2 of 2 FirstFirst 1 2
Results 21 to 23 of 23
  1. #21
    Thanked: 1026
    Default Re: Ranger t6 2014 3.2 white smoke cold
    Quote Originally Posted by Capone View Post
    Thank you!
    Jip, I have a fairly large canister high up in the exhaust followed by a smaller one ... according to the workshop manual the larger one is the cat and the smaller one the "exhaust flexible pipe". I see that the DPF is situated much further down the exhaust (sort of underneath the right side back seat) and should be very easy to spot - I definitely do not have a DPF.
    Learned so much again
    Yes then you have a cat.
    Btw, on a petrol you don't need to regen, because there is no soot to burn.
  2. #22
    Mar 2014
    Thanked: 43
    Quote Originally Posted by pierre2013 View Post
    Great, thank you! So ... if I put 2SO in my diesel truck I don't need a cat? (just a joke )
  3. #23
    Jun 2012
    Gordons Bay
    Thanked: 19
    I had the white smoke in the mornings problem. Disappeared after a couple of minutes. The problem was solved by having the injectors re-calibrated. This is done by the dealer using their plug in software. No injector removal or cleaning of anything.
    The big commercial diesels also apparently have their injectors calibrated regularly.
    Ford Ranger 3.2 M/T D/C 4x2 (Pavement Parking in style since July 2012)
  4. The Following 2 Users Say Thank You to VicC For This Useful Post:
