Page 3 of 3 FirstFirst 1 2 3
Results 41 to 58 of 58
Thread: 6x6 Frontier
    May 2017
    Thanked: 1653
    Default Re: 6x6 Frontier
    If you are going to go into fully independent....
    then 6 wheel steer will be the way to go! or just go the whole hog and build an 8 wheeler!
    Attachment 451472
    Exactly where I was going with this too...
    Flying Spaghetti Monster
    ZS1ETphonehome
  2. #42
    Dec 2009
    Gordon's Bay
    Thanked: 4378
    Quote Originally Posted by Sakkie View Post
    NOT okay on the other side of 80. And they wear like crazy
    you are only 56! you should be fine!
    Would love to see the local cops trying to decide why it's illegal
    If you've got live axle front end, you need live axle rear end. Independent would be fine for a long arm independent front end...
    2 live diffs with rear cover plates
    get busy on CAD and design a new back plate to carry a second pinion to create and output from the crown wheel.
    then you have a 1:1 reversed output out the back of the middle diff.
    flip the second diff to correct the drive, and put a sliding prop shaft between them.
    Lower trailing arms on each diff with a panhard rod.
    bleed the brakes, bolt on the wheels and sort out the body work...
  3. #43
    Dec 2009
    Gordon's Bay
    Thanked: 4378
    this little okie also had 6 wheel drive....
    https://www.facebook.com/JimButton.F...type=3&theater
    (or at least, the South African version had 6 Wheel drive, the Germans could only manage 2 wheel drive )
  4. #44
    Dec 2006
    Thanked: 870
    Aikona...6x4
    Sakkie Coetzee
    Some people say I have a "short temper"....I see it as swift and assertive reaction to Bull!
  5. #45
    Dec 2009
    Gordon's Bay
    Thanked: 4378
    Aikona...6x4
    we actually ran a chain to the front axle too as it needed to make it's way across the dunes.
    I have to say, it did better than a Porra in a Fortuner!
  6. #46
    Apr 2009
    Bellville
    Thanked: 727
    Quote Originally Posted by Ricoffy View Post
    It will be more manly than Chuck Norris Johan Slabbert walking around with his member in his hand saying: " Is this a stick-up"
    Phixed !!!
  7. #47
    Aug 2007
    Out of Town
    Thanked: 883
    Best is to keep both rear axles independent. Run direct off your current TC into another that has been "inverted" and the low range removed to simply split the drive to the rear. Maybe look at the rear diff with an offset pumpkin to line up better to your "splitter", but not crucial due to the length of your second propshaft, and the route it is going to take to. Run the second propshaft over the the center diff with a carrier bearing mounted direct to the center diff.
    Center diff you do NO steering, but the rear diff you can steer at a ratio to the front wheels to enable the vehicle to pivot around the center wheels a little. You can do this by taking a pushrod setup direct off your steering knuckle to the steering knuckle on the rear diff. 8 wheel trucks "push" the second axle this way, or you can get fancy with an hydraulic setup.
    Biggest challenge I see is keeping the vehicle length reasonable, and then, how is the weight going to line up legally with your registration/license docs.
  8. #48
    Dec 2009
    Gordon's Bay
    Thanked: 4378
    the problem with running a prop over the centre axle, is that you lose travel on the rear diffs - the centre one can't go up into the rear one's prop, and the rear diff can't drop down as the prop will hit the centre diff....
    or you have to lift the motors and boxes, tilt the diff so the pinion is up and run a 90 degree drive into it. but then you've got a high COG with low clearance...
  9. #49
    Aug 2007
    Out of Town
    Thanked: 883
    Um yes, but it does not to "interfere"...
  10. #50
    Dec 2009
    Gordon's Bay
    Thanked: 4378
    Eish.
    That prop would need more than a centre bearing. It would need joints each side of a fixed bearing and 2 sliders.
    It also starts to get kind of long with the extra box and propshaft in between...
    but yes, it would work....
  11. #51
    Thanked: 18050
    The rear axle cannot possibly have enough range of motion to cause the over-the-top prop from the middle axle transfer case to engage with anything
    The Australian Perentie Defenders with the Foley 4x4 system work exactly like this and have had no issues.
  12. #52
    Dec 2009
    Gordon's Bay
    Thanked: 4378
    no, that is not as Peter drew/described.
    that adaptor is bolted to the front of the middle diff and moves up and down with that diff.
  13. #53
    Thanked: 18050
    Peter?
    BfreeSani is David. But you can call him Arthur or Peter if you wish.
  14. #54
    Dec 2009
    Gordon's Bay
    Thanked: 4378
    Peter?
    haha, confusion reigns !
    Apologies David!
    Is it time for beer yet?
  15. #55
    Aug 2007
    Out of Town
    Thanked: 883
    Apologies David!
    Evidently went beer o clock about an hour ago in our office. But I'm not a participant
  16. #56
    Dec 2009
    Gordon's Bay
    Thanked: 4378
    okay.
    you convinced me.
    BEER TIME!
  17. #57
    Aug 2007
    Out of Town
    Thanked: 883
    okay.
    you convinced me.
    BEER TIME!
    If you are anything like those kids of mine, you need very little convincing . Thats my daughter who just got back from the mines, and had a tough morning with the guys out there wanting all kinds of stuff she knows nothing about.
  18. #58
    Apr 2009
    I know you guys like to reinvent te wheel , but I see some nice conversions from the guys down under.
    http://www.jmacx.com.au/jmacx-6wheeler.html
    Pat
    Hilux 3.0 D4D 4x4
