Patio gas braai
Results 1 to 6 of 6
Thread: Patio gas braai
    Jun 2016
    Bredasdorp
    Default Patio gas braai
    I usually get my best advice here. Which grid material is best. Something else I must check? Thks Dankie peter with a 1x4 tjor.
    Sep 2016
    Thanked: 28
    Default Re: Patio gas braai
    Got both Cast iron and stainless grids. I prefer cast, easy to clean (burn + brush = braai). I spend hours cleaning stainless, it also stains / discolour - not looking good. Now only use stainless for pizza's.
  3. The Following User Says Thank You to Theuns SJ For This Useful Post:
    Oct 2006
    Thanked: 78
    Cast iron, before first use brush on sunflower oil and set burners to highest setting and burn in grids for about 10 minutes, seals them and makes them a lot easier to clean in future.
    Aug 2014
    Simons Town
    Thanked: 968
    Have both cast iron and stainless steel braai grids...don't smark the rust buildup on the cast iron which requires a bit of elbow grease to get rid of along with spray n cook...more inclined to use my homemade stainless grid...
    Sep 2016
    Thanked: 28
    If rust, braai more often
    Oct 2006
    Thanked: 78
    Quote Originally Posted by Finn McCool View Post
    If you burn in the grid properly from new and you braai often you should not have a rust problem.
  8. The Following 2 Users Say Thank You to zebras For This Useful Post:
