road closed between Crocodile Bridge Gate and Lower Sabie?
Results 1 to 4 of 4
    Oct 2012
    howick
    Default road closed between Crocodile Bridge Gate and Lower Sabie?
    Hi Guys
    Can anyone confirm if the Kruger Park road is indeed closed between Crocodile Bridge Gate and Lower Sabie campsite.
    It is our first time camping in the Kruger with a caravan and we are planning a route from KZN.
    To get to Lower Sabie the easiest access seems to be Crocodile Bridge, but I have now been advised due to flood damage earlier in the year that the intial route that was planned is not doable and should rather go in via Malelane Gate, up via Skukuza and then back down to Lower Sabie... A long detour indeed.
    Thanks in advance.
    Nov 2014
    Thanked: 1584
    Default Re: road closed between Crocodile Bridge Gate and Lower Sabie?
    Quote Originally Posted by twister View Post
    Hi Guys
    Thanks in advance.
    Unless it's happened since early April it's not true. Drove it on 15th April, no sign of issues.
    Love your neighbour. Thatís about it, itíll be the world we want.
  3. The Following User Says Thank You to Gungets Tuft For This Useful Post:
    Thanked: 271
    Not true i just came back from Crocodile Bridge camping and the road to LS is open there are no closures
  5. The Following User Says Thank You to smarty For This Useful Post:
    Oct 2012
    howick
    Perfect, thanks for the replies.
    We can revert back to the original plan.
