Results 1 to 14 of 14
    Jul 2010
    Default 2000 Pajero Gen3 Vibration problem help needed
    Hi all. Have been searching threads for solution to this hope there is someone who can help.
    2000 Gen3 pajero 3.5 v6 has a constant vibration throughout the body above 100kmph, changes slightly when you accelerate or leave the gas pedal but never stops the vibration. Only changes the resonating it cuases.
    Wheel alignment and balancing has beed done. Swapped out tyres, Complete new propshaft front and back.
    Only options left I can think of are Engine and gearbox mounts. Maybe wheel bearings or cv's
    Any help or advice would be appreciated
    Thanked: 176
    Default Re: 2000 Pajero Gen3 Vibration problem help needed
    Hi Boerop
    Had exactly that same issue for years. Replaced everything including diff etc. Turned out to be the rear diff mounting bushes that it hangs on.
    The other thing that also add to that is the rear trailing arm bush that is in the hub.
    Start there first. Let us know the outcome.
    Sep 2014
    Kuilsrivier
    Thanked: 130
    Hi,
    This mounting, whatever it might be called, i thing a prop-shaft noise damper, also play a mayor role. Mine was bended and it caused a terrible vibration at any speed. Once pressed back into original shape, the vibration is gone.
    Johan
    Johan
    Live Life!
    Jul 2010
    I will remove the vbration damper first.
    I also have all the mountings on order 3 weeks waiting period.
    If it is tge damper, I will kick myself
    Thanked: 176
    I played with the dampners and it made no difference. But then again mine were not damaged.
    Texas
    Thanked: 522
    What tires are you running? Heal-toe wear also have a nasty vibration.
    2005 Pajero 3.2D LWB Auto
    1999 Pajero 3.5V6 LWB Manual - Deceased
    Jul 2010
    I replaced old tyres, repaired my front suspension and played with the damper. Made no difference.
    Oil seems to be coming from the gearbox.
    Mechanic gave me an option to change engine and gearbox to a lexus 4.0L.
    Gave me a price I can't refuse.
    Now I have to choose between VVTI wiyh 5 speed box or the non VVTI with 4 speed gearbox.
    Thanked: 20097
    Quote Originally Posted by Boerop View Post
    you're CRAZY
    get a second opinion on a gearbox rebuild
    If that guy can do a decent Lexus V8 conversion for under R80k then I'd be VERY surprised.
    Jul 2010
    Jul 2010
    He has done about 40 conversions.
    I have spomen to people who did it with him, no one had any complaints.
    Took my gearbox to a gearbox centre. They want R2000 for the diagnosis. They did tell me from what I told them about the vibration it might be the torque converter. (R12000 plus) My motor is also using about 0.5l of oil a week.
    He will charge me R45000 for the conversion, but keep my current engine and gearbox
    Texas
    Thanked: 522
    How much is "a price I can't refuse"?
    I am one for keeping things original. Lexus V8's are nice IF done correctly by a experienced guy - but they dont come cheap. A friend of mine sold his fairly new Mazda bakkie at a loss, just to get rid of it after having a Lexus V8 conversion done. They butchered his bakkie, I cant believe nobody has assaulted that mechanic. Think carefully.
    You pay peanuts, you get monkeys.
    Call Mitsi Tech - I have seen only good things about them - dnt know them and never used them before, but they seem above board.
    https://www.facebook.com/pg/Mitsi-Te...0550191/about/
    Thanked: 632
    And does he guarantee that the vibration will be gone?
    It is a very expensive, road of no return that you want to try AND your car will be worth nothing with an engine transplant.
    Rather get your car to a Pajero specialist(like Arnold) who know these cars back to front.
    Si vis pacem, para bellum
    Thanked: 3645
    R45k?
    Sell yours as parts or scrap and add R45k to buy another pajero in working order.
    1993 3.0 V6 Pajero - SOLD : 2001 3.2 Di-D Pajero - SOLD
    2005 Touareg R5 2.5 TDi - SOLD : 2007 Pajero LWB 3.2 Di-D
    My YouTube channel
    Touareg Manuals Google Drive Folder : Pajero Manuals Google Drive Folder
    The clever ones are being outbred & overruled by the not so clever ones. Pair that with unchecked selfishness. We are heading for a fall!
    May 2012
    Thanked: 45
    Hi,
    Give my dad a call. He recently did some major work for a Pajero GEN3 (shorty) for another forum member in Pretoria. Chances are it's not as expensive as your first suggestion. He's an old school qualified mechanic, have done many engine rebuild, gearbox rebuilds and also customizations like Lexus Conversions.
    His number is 073 853 7317 and it's close to you
