Results 1 to 20 of 22
Thread: Prado 120 mods
    Sep 2012
    Thanked: 33
    Default Prado 120 mods
    Hi. I don't see a thread wrt mods for the Prado 120 so thought I'd start one. I've been meaning to post a few mods on my Prado for ages. Finally took some pictures today so here goes. Please add your mods to the thread.
Name:	Prado rear door closed.jpg
ID:	450389Click image for larger version.
Name:	Prado rear door open.jpg
    This is the view from the back. I made a shelf from plywood. I attached it to the floor of the Prado with the existing holes for the jump seats - just replaced the screws. My suitcase solar panel for my trailer slides under here with all the cables regulator etc as well as a frontrunner shower arm. On the right I have space for 3 bottles of wine and on the left I have 2 poles with led strips as mobile lights. Fridge is tied down onto the plywood base and opens up fully. 4 camp chairs fit on the left of the fridge. The right side has tie downs for ammo boxes etc. Next to this on the right is a small adjustable table held in by the ammo boxes.
Name:	Prado rear door open with table.jpg
    I've also made a drop down table which folds down from the rear door and folds up and away when not in use. There is a braai grid attached here permanently.
Name:	Prado Xtra battery and solar regulator.jpg
ID:	450393Click image for larger version.
Name:	Prado battery and recovery gear.jpg
    There is an auxiliary lead crystal battery in the boot behind the 50l national luna. The regulator for the solar panel on the roof of the vehicle is also here as is my recovery gear and a few additional sockets running off the solar.
Name:	Prado rear view water taps.jpg
    This picture shows the water tank and taps. I've attached a tap to the rear bumper via Rivnuts so its removable. Also have another tap at the top. Depending on what I'm doing I either use the top tap or the bottom one.
Name:	Prado rear light switch board.jpg
    This is a panel I made out of aluminum checker plate and covered the existing hole in the rear to run led lights and work lights to the roof rack. I've put led light strips on each side and the rear of my roof rack as well as 2 work lights on the right and one at the rear. Each of these has a separate switch so I can switch on the required lights. This runs of the main battery.
Name:	Prado rear sockets and radio.jpg
ID:	450398Click image for larger version.
Name:	Prado radio.jpg
ID:	450399Click image for larger version.
Name:	Prado front extra USB sockets.jpg
ID:	450396Click image for larger version.
Name:	Prado front switches and Voltmeter.jpg
    These are extra USB switches I have made in the existing holes in the centre console and at the rear I made a cover for the existing holes. All of these can be removed and changed back to stock if needed - all USB's and cigarette sockets are connected to main battery via the switches in the other picture to charge IPads, phones etc. Other switch is for light bar. Iíve also run the radio aerial from the roof to the rear console.
ID:	450400Click image for larger version.
Name:	Prado roof net and pepper spray.jpg
    This is a net I attached to the roof to store our pillows and any other soft items in.
Name:	Prado torch.jpg
ID:	450402Click image for larger version.
Name:	Prado fire extinguisher.jpg
    Iíve attached a torch and fire extinguisher via the existing screw holes by the rear doors.
Name:	Prado front.jpg
ID:	450404Click image for larger version.
Name:	Prado left side.jpg
ID:	450405Click image for larger version.
Name:	Prado right side.jpg
ID:	450406Click image for larger version.
Name:	Prado rockslider.jpg
    This is a map of Southern and East Africa that has been wrapped on the bonnet in case we need to see where we are going . And a few other pics.
    Please post some mods you have done to your Prado 120. I think itís an awesome vehicle- great compromise between being rugged and capable.
    Karl
  2. The Following 2 Users Say Thank You to KarlG For This Useful Post:
    Sep 2012
    Thanked: 33
    Default Re: Prado 120 mods
    From top. Water tank ,solar panel, maxtrax and fire extinguisher.
    Nigel
    Thanked: 2510
    Very nice and compact.
    Just a tip. I put velcro under my charger, so it just sticks to the carpet.
    Uniglide
    +27 zero eight 2 four 95 9252
    Feb 2013
    Edenglen-Jhb
    Thanked: 30
    Excellent Karl. Agree with you, it's an awesome machine that 120 of yours!!
    2001 Prado 3.4 V6
    2009 Conqueror Conquest
    Sep 2012
    Thanked: 33
    Thanks Henrik. Funny enough I have velcro under there as well. I have a problem wrt overkill, so put the strap as extra support for the bumps😀
    Sep 2012
    Thanked: 33
    Thanks Mario
    Oct 2014
    Thanked: 112
    What a well kitted well thought out rig. Well done.
    Sep 2012
    Thanked: 33
    Thanks Andreas.
    Live : Bethal , Work : Saudi
    Thanked: 279
    One of the best kitted Prado's I have seen
    Stunning
    One life Live it
    Take The Roads less traveled
    Alles in die lewe gebeur met n doel
    Installed a 10L water tank in the place of the dual battery.
    For washing hands and making a cup of coffee when needed.
    I always have 3 small crates in the back of my Prado,
    1 with Compressor and tyre repair kit,
    1 with recovery gear and
    1 with coffee, kettle, mugs and gas burner..
    Me - Prado
    SWAMBO - Audi A4
    Ex Mazda Drifter with a few extras
    Exx Hilux SFA
    Aug 2016
    Nigel
    Thanked: 22
    Looks awesome KarlG!!
    Pradotoria
    Thanked: 48
    Thats one well kitted out 120. I've only seen similar on the Auzzie Pradopoint website. The rear door fold down table is on my to-do-list. I may need to pay you a visit for a cuppa coffee and get some ideas for my rig.
    4x4s
    Sep 2012
    Thanked: 33
    Thanks for the nice comments guys. Anytime Mr MMG.
  15. #14
    Well done charl .
    Please post a pic of the complete engine bay?
    Do you have a 2nd battery fitted?
    Prado 120 v6 2005
    ZS6DEL (70 cm,2m) ORRA X09
  16. #15
    Sep 2012
    Thanked: 33
    Hi bos suzi. The engine bay is stock. I've got the extra battery behind the fridge in the boot. Wasn't keen on having the battery permanently in the hot engine bay. I just switch between solar, alternator and 220v when needed as easy to get to from back seat. I also take it out if we don't have a trip planned for a while.
  17. #16
    Irene
    Hi guys - I'm urgenty looking for a rear bumper for my 120. Where did you get yours Karl?
    Anyone know where Incan get one for a reasonable price?
    Land Rover Defender 90, 2.8i
    Land Rover Discovery 3 - TDV6 HSE
    Polo 1.9Tdi
    Too much aux equipment is never enough.
  18. #17
    Sep 2012
    Thanked: 33
    Hey got mine from Lynx 4x4. I jack knifed the plastic bumper so had to replace with one where they could build up the as well.
  19. #18
    Sep 2012
    Thanked: 33
    Sorry build up the sides. Paid 17k but that included around 3k for the sides if memory serves and fitment
  20. #19
    Irene
    Looking for replacement rear bumper please?
    Polo 1.9Tdi
  21. #20
    Irene
    Thanks - Is Lynx still around Karl?
    Polo 1.9Tdi
