Prado - problem starting
Results 1 to 7 of 7
    Default Prado - problem starting
    Good morning
    My 2007 Prado 120 4lV6 is battling to start. It swings and tries a couple of times (on its own, only turn the ignition once) and then eventually starts. When she runs, she sounds fine. It did it once or twice, and then gradually became worse. Now she really battles, almost sounds like a starters issue. The warning lights as per the photo stays on.
    Anybody had a similar issue or know what could be wrong?
    Krugersdorp
    Default Re: Prado - problem starting
    I'd start by simply getting the starter battery tested.
    Riaan
    2019 Toyota Land Cruiser 200 GX-R
    2015 Toyota Land Cruiser 76 4.5TD V8
    2017 VW Golf 7.5 R
    2016 Bush Lapa Miskruier (Kampwa)
    Jun 2012
    Fuel pump.
    May 2010
    Ruimsig
    I would go Battery
    Fuel pump
    Starter.
    At around 200 000km on the Prado the starter and fuel pump goes. It is always a toss up which one first.
    Thanks for all the advice.
    It was the stater that was failing. Bought a Bosch starter but had to put the old starter motor on the Bosch solenoid and bendix to get it to fit.
    Jun 2012
    Hi, did the new starter also fix the light on the dash?
    2007 Toyota Land Cruiser Prado 4.0 V6 - OME Suspension
    2018 Metalian Maxi with Alu-Cab Exp 3 RTT and Alu-Cab Shadow-Awn
    Hi
    Yes, the lights came on as a result of the engine not starting the first try. After the starter replacement the lights have not come on again.
