Land Rover Problems!
Page 1 of 10 1 2 3 4 5 6 7 8 9 10 LastLast
Results 1 to 20 of 188
    Pune
    Thanked: 60
    Default Land Rover Problems!
    This thread serves at a database of all problems experienced by Land Rover owners. This will give potential buyers or owners of this specific make a database they can go through to see what problems their vehicle could possibly develop.
    To ensure this thread contains only information related to vehicle problems and to keep it easy to read and understand, there are a few very specific rules:
    -Copy the list below in bold into your thread and only provide the information asked for, no more, no less.
    -One list per problem. More than one problem can be posted in the same post, but use seperate lists.
    -No discussions will be allowed in this thread. If you want to discuss a specific problem, contact the poster directly or start a new thread in the relevant section. Copy the post across to the new thread if need be.
    -ANY comments, or posts not conforming to the list below, will be deleted.
    -Only post problems you personally experienced, please no friends' stories or hearsay's.
    Please help to keep this neat and factual.
    Thanks!
    Model:
    Year:
    Mileage:
    Problem:
    Cause of problem(if known):
    Specifics of repair work carried out:
    Cost of repair:
    Who did the repair:
    Vehicle under warranty, Y/N:
    Was damage covered by warranty:
    Thanked: 8
    Modeliscovery Tdi
    Year:1996
    Mileage:174 000
    Problem:Head bolts came loose and broke cam shaft in 2 places + injectors were badly worn
    Cause of problem(if known):Steel bolts overtightened in aluminium head
    Specifics of repair work carried out: fitted complete new head and injectors
    Cost of repair:R13500.00
    Who did the repair:Land Rover specialist workshop
    Vehicle under warranty, Y/N:N
    Was damage covered by warranty:N
    Oct 2007
    Uitenhage
    Thanked: 375
    Model: Defender
    Year: 2008
    Mileage: 10000km
    Problem: Oil Leaking from Vacuum Pump
    Cause of problem(if known): Faulty Pump(Recall)
    Specifics of repair work carried out: Replace Pump
    Cost of repair: R5500.00
    Who did the repair: LR Menlyn(Pretoria)
    Vehicle under warranty, Y/N: Y
    Was damage covered by warranty: Y
    Model: Defender
    Year: 2008
    Mileage: 33000km
    Specifics of repair work carried out: Replace Pump with New Improved One.
    __________________
    2004 Land Rover Discovery 2 Td5 ES
    Dec 2007
    Gordon's Bay
    Model: Defender
    Year: 2005
    Mileage: 56000km
    Problem: Grinding noise from gearbox/front axle
    Cause of problem(if known): Angle from transfer box to front axle too steep, front propshaft grinding in front axle.
    Specifics of repair work carried out: Replace front propshaft with a double cardon one from Disco2
    Cost of repair: R11000.00
    Who did the repair: DaGama Motors (Kommetjie, Cape Town)
    Was damage covered by warranty: N
    Thanked: 19
    Model: Defender Hard Top
    Year:1997
    Mileage:+- 80 000km
    Problem: Loss of clutch fluid
    Specifics of repair work carried out: Replaced rubbers, honed master cylinder
    Cost of repair: Could not remember
    Who did the repair: Naboomspruit Auto Clinic
    Year:1997
    Mileage:150 000km
    Problem: Turbo boost gone
    Cause of problem(if known): Habit of shutting off engine directly after hard work
    Specifics of repair work carried out: Replaced turbo with recon turbo
    Cost of repair: R3500 total (gave old turbo in as part of payment)
    Who did the repair: George in Silverton
    Oct 2008
    Arrow Problems & repairs to land rover
    Model: Discovery TDi
    Year: 1997
    Mileage: 293000
    Problem: Smoking & no power
    Cause of problem(if known): Old age?
    Specifics of repair work carried out: Replacement of injectors & turbo
    Cost of repair: R16000-00
    Who did the repair: Bosch Garage : Alrode South
    Vehicle under warranty, Y/N: Yes
    Was damage covered by warranty: Yes
    Bommie
    __________
    1997 Discovery TDi
    "It only hurts if you survive!"
    Oct 2008
    Year: 1997
    Mileage: 289965
    Problem: No power
    Specifics of repair work carried out: Conversion 1 - free flow exhaust, larger intercooler, move catalytic & fitted snorkel
    Who did the repair: CRD
    Was damage covered by warranty: Not applicable
    Bommie
    __________
    1997 Discovery TDi
    Thanked: 33
    Model: Defender 90 Puma
    Year: 2009
    Mileage: +-60km
    Problem: Vehicle wouldn't start
    Cause of problem(if known): Faulty Battery Cable
    Specifics of repair work carried out: Cable replaced
    Cost of repair: Unknown
    Who did the repair: LR Midrand
    Year: 2009
    Mileage: +-600km
    Problem: Grinding sound coming from brakes
    Cause of problem(if known): Warped front brake disks
    Specifics of repair work carried out: Front brake disks and brake pads replaced
    Stuart
    2006 Toyota Land Cruiser 100 VX 4.7L V8
    Model: td5
    Year: 2002
    Mileage: 155,000km
    Problem: Revs did not go down when foot is taken off accelerator
    Cause of problem(if known): censor on clutch
    Specifics of repair work carried out: cleaned sensor
    Cost of repair: R50
    Who did the repair: Willie Smit
    Was damage covered by warranty: N/A
    Toyota Prado 4.0l Petrol
    OME Suspension
    B'rakhah Ingonyama Offroad Camper
    Previously2002 Disco TD5
    Thanked: 140
    Model: Discovery II TD5
    Year: 2002
    Mileage: 220000
    Problem: Front Propshaft Double Cardon Universals Wearing Out After 50Km
    Cause of problem(if known): Worn Centering Brearing Of The Double Cardon
    Specifics of repair work carried out: Replaced The Propshaft The First Time Ordered An New Centering Bearing From The USA And Did The Prop Recon Myself Details On The Link http://www.discovery2.co.uk/propshafts.html
    Cost of repair: Over R8000 For Both Times It Breaked
    Who did the repair: First Time Propshaft Centre Second Time Myself
    Jun 2008
    Joburg
    Thanked: 15
    Model: Defender 90
    Year: 2001
    Mileage: 147 000
    Problem: Cracked head
    Cause of problem(if known): Apparantly a known weakness
    Specifics of repair work carried out: Replaced with reconned head
    Cost of repair: R15 000
    Who did the repair: REM landy repairs
    Vehicle under warranty, Y/N: Motorite
    Was damage covered by warranty: Only R2000
    Model: Defende
    Year: 2001
    Mileage: 147 000
    Problem: belt tensioner bearings
    Specifics of repair work carried out: Replaced with new
    Cost of repair: R1 300
    Defender 90 TD5 with steering guard, Warriorworx rocksliders and diff guard, 33' Bridgestone MT, Warn winch, outback roofrack, frontrunner penthouse RTT and awning.
    African Backbone offroad trailer.
    Thanked: 8
    Model: Defener 110PUMA
    Year: 2008
    Mileage: 15000
    Problem: Clutch plate rattle on Start up
    Cause of problem(if known): Loose springs on plate, pre April 2008 known issue
    Specifics of repair work carried out: Replaced with new clutch kit
    Cost of repair: No idea
    Who did the repair: Waterford LR
    4x4AG GP0104
    Pajero Sport 2013 MT
    2008 Defender 110 PUMA AKA Wiskey - SOLD.
    "If you're only killing time, it'll kill you right back"
    DURBANVILLE
    Model:defender td5
    Year:2004
    Mileage:132000
    Problem:misfiring/poor performance
    Cause of problem(if known):fuel pump pressure
    Specifics of repair work carried out:replacement of diesel pump
    Cost of repair:R3900
    Who did the repair:JABBA 4x4
    Vehicle under warranty, Y/N:n
    Was damage covered by warranty:n
    Model:defender 110 td5
    Year:2002
    Mileage:170000 km's
    Problem:Clunking sound from rear on pullaway
    Cause of problem(if known): worn A-frame ball joint
    Specifics of repair work carried out:replacement of A-frame ball point
    Cost of repair:R350.00
    Who did the repair:Self
    Was damage covered by warranty:N/A
    Thanked: 14
    Model: Td5 Defender 90
    Year: 2006
    Mileage: 99 675
    Problem: White smoke in low range, after about an hour of trail work.
    Cause of problem(if known): Turbo bearings failing (reconned part originally fitted by LR 30k kms ago).
    Specifics of repair work carried out: Replaced turbo & flushed intercooler.
    Cost of repair: R12000.
    Who did the repair: LR Umgeni Rd.
    Vehicle under warranty, Y/N: Y - SA Warranties.
    Was damage covered by warranty: R7500 was covered.
    Mike
    Model: Defender 110CSW TD5
    Year: 2005
    Mileage: 132 000 km
    Problem: Engine mis firing
    Cause of problem(if known): Injector wiring harness
    Specifics of repair work carried out: Replaced harness and cleaned plugs on ECU
    Cost of repair: R1600.00
    Who did the repair: Land Rover Nelspruit
    Vehicle under warranty, Y/N: No
    Model: Discovery 3
    Year: 2005
    Mileage:127304km
    Problem: Transmission / Handbrake / HDC warnings active on display no handbrake.
    Cause of problem(if known): Water in battery bay after washing enginge (By the people who sold it to me prior to delivery)
    Specifics of repair work carried out: Replaced Servo ECU (Mounted under Battery)
    Cost of repair: R3100
    Who did the repair: Land Rover Midrand
    His: Land Rover Discovery 3 190 000km
    Hers: Audi A6 Quattro 187 000 Km
    ORRA Radio Call Sign: H26
    Call Sign: ZR6ADR
    http://www.wheeliewierd.blogspot.com
    Fourways
    Model: Discovery 3 TDV6 S
    Year: 2007
    Mileage: 47000km
    Problem: Occasional "Suspension fault, normal mode only" message
    Cause of problem(if known): Faulty brake light switch (who would have guessed)
    Specifics of repair work carried out: Brake light switch replaced
    Cost of repair: R0
    Who did the repair: LR Waterford
    1998 Land Rover Discovery TDi
    1980 Range Rover
    2007 Land Rover Freelander 2 TD4 S (SWAMBO's)
    2005 Jeep Cherokee Renegade CRD
    Model: Disco 2 Td5
    Year: 2001
    Mileage: 205000
    Problem: Short lever completly loose, not engaging high or low. Noisy "ruff' clutch
    Cause of problem(if known): Main shaft broken in transfer case. Clutch fork dry.
    Specifics of repair work carried out: Replaced complete transfer case as the gears were badly grinded. Replaced the noisy "scratching" clutch as well
    Cost of repair: R13 050.00
    Who did the repair: Liebenberg auto
    Was damage covered by warranty: Partially
    Ryan
    ADMIN REMOVED
    Current Drive: Disco 2 Td5 ES
    Previous: Nissan X-Trail 2.2D
    Previous: Nissan Qashqai 1.6 (Now claimed by SWAMBO)
    Jan 2009
    Vereeniging
    Model: Defender 110 TD5 HCPU
    Year:2002
    Mileage:182 561 km
    Problem: 1.Water loss into Exhaust, 2.oil in water.
    Cause of problem(if known): 1. Head gasket failure 2. Oil Cooler leak. 3. Turbo Failure
    Specifics of repair work carried out: 1. Replaced Gasket and new headbolts, 2.new oil cooler made.3. Replaced turbo bearing
    Cost of repair: 1. R2136.00 2. R670.00 3. R580.00
    Who did the repair: Done by me
    Vehicle under warranty, Y/N: no
    Was damage covered by warranty: no
  1. Jeep Problems
    By Barto in forum Jeep
    Last Post: 2020/02/17, 04:31 PM
  2. Hyundai Problems!
    By Barto in forum Hyundai
    Last Post: 2016/08/08, 01:49 PM
  3. Kia Problems!
    By Barto in forum Kia
    Last Post: 2014/03/21, 10:18 AM
  4. Conqueror Companion: Dream becomes nightmare
    By Alta in forum Camping, Fridges, Accessories
    Last Post: 2012/10/21, 09:54 PM
  5. Discovery 3 CD and Cruise Control problems (incl. bad experience with dealer)
    By ReadySteadyGo in forum Land Rover
    Last Post: 2011/11/09, 07:40 AM
