Land Rover Problems! - Page 6
Page 6 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 101 to 120 of 188
  1. #101
    Jan 2009
    Default DII V8 head gaskets
    Model: Disco 2 V8 ES A/T
    Year: 2001
    Mileage: 212000km
    Problem: blown head gasket- left- leaking to atmosphere, right- almost blown
    Cause of problem(if known): Not found
    Specifics of repair work carried out: replaced LH and RH head gaskets, valve seals, heads skimmed.
    Cost of repair: R14k
    Who did the repair: Roverland
    Was damage covered by warranty: No damage
    01 Discovery 2 V8 A/T- Sold
    97 LC80 4500 GX Limited
  2. #102
    Oct 2012
    Trichardt
    Model: landrover discovery 3 TDV6 HSE
    Year:2007
    Mileage: 114 785
    Problem: Droning noise coming from left side of the car
    Cause of problem(if known): Left front wheel bearing started to seize
    Specifics of repair work carried out: wheel bearing replaced
    Cost of repair: R 4 900
    Who did the repair: Landyworx, Randburg
    Vehicle under warranty, Y/N: Yes
    Was damage covered by warranty: Not sure yet
  3. #103
    Oct 2012
    Trichardt
    Year:2007
    Mileage: 116 231
    Problem: Smoke coming from the left rear disc!
    Cause of problem(if known): Park-brake brakes not set properly, no warning lights
    Specifics of repair work carried out: Rear disc's, brake pads and park-brake shoes and housing replaced
    Cost of repair: R 7 430
    Who did the repair: Land Rover Bloemfontien, Bloemfontein
  4. #104
    Oct 2012
    Trichardt
    Year:2007
    Mileage: 117 433
    Problem: Winding noise coming from front left, very pronounce in 3rd gear at approx 60km/h driving uphill.
    Cause of problem(if known): Front diff
    Specifics of repair work carried out: Awaiting warranty claim
    Cost of repair: Approx R11 000.00
    Who did the repair: AutoLandy, George
    Was damage covered by warranty: Waiting...
  5. #105
    Apr 2012
    Year:2007
    Mileage: 145 000
    Problem: HDC faulty/ transmission faulty/ EHB faulty error message
    Cause of problem(if known): Faulty Break light switch!!
    Specifics of repair work carried out: Replace switch
    Cost of repair: Approx R770
    Vehicle under warranty, Y/N: No
    Boldly Going Nowhere
  6. #106
    Little Falls
    Model: Defender
    Year: 2007
    Mileage: 92,000
    Problem: Jerk and shudder at high speed as if starved of fuel or air in the line.
    Cause of problem(if known): Initially thought to be the EGR valve but found to be a dirty fuel filter. Not replaced although charged for during 80,000km service.
    Specifics of repair work carried out: Replaced fuel filter by owner.
    Cost of repair: +-R525 for an after market filter.
    Who did the repair: Owner
    Freelander SD4 S
    Defender 90 Puma
    Series II OSV
  7. #107
    Stilbaai
    Exclamation Defender 90 - Front & rear Diffs Busted
    Model: Defender 90
    Year: 2010
    Mileage: 41000km
    Problem: Both front and rear diffs destroyed
    Cause of problem(if known): Parts failure according to Land Rover
    Specifics of repair work carried out: Front and rear diffs replaced
    Cost of repair: Warrantee
    Who did the repair: Land Rover George
    Was damage covered by warranty: Y
ID:	212621   Click image for larger version.
ID:	212622   Click image for larger version.
ID:	212623   Click image for larger version.
ID:	212624   Click image for larger version.
ID:	212625   Click image for larger version.
ID:	212626   Click image for larger version.
    StarShip.Captain - Getting lost happily (",)
  8. #108
    May 2013
    Default Repairs defender 110 Puma
    Modelefender 110 Puma
    Year:2007
    Mileage:Clutch ar 70 000Km and Now air con at 87 000Km
    Problem: As above
    Specifics of repair work carried out: Clutch repalced and air con dont know as yet
    Cost of repair:Clutch R8000-00
    Who did the repair: 3 Lions in Midrand
    Was damage covered by warranty No
  9. #109
    Keurboomstrand
    Thanked: 11
    Model: Freelander 2
    Year: 2008
    Mileage: 98143 kilo's
    Problem: Oil leak/sweat at engine breather/ cover
    Cause of problem(if known): ?
    Specifics of repair work carried out: Replaced cover (LRLR004200) and gaskets (LRLR009412 and LRLE009411)
    Cost of repair: R3 936.67
    Who did the repair: McCarthy Land Rover N1 City
  10. #110
    Jul 2007
    Despatch
    Thanked: 21
    Model: Disco 3
    Year: 2006
    Mileage: 185 000 km
    Problem: knocking suspension, droning noise, slight vibration coming through floorboards and steering
    Cause of problem(if known): Bad designed bushes, age and milage.
    Specifics of repair work carried out: Replaced lower control arms with reconditioned units that have brand new bushes and ball joints on.
    Cost of repair: R5 055.00 (wheel alignment included)
    Who did the repair: Savoy Land Rover indy in PE
    Was damage covered by warranty: ?
    Sent from my GT-P7500 using Tapatalk 2
    Offroad junky
    '97 SsangYong Musso 602 EL exec
    '14 Citroen DS4 2.0 HDI swambo's platkar
    Previously;
    '03 Nissan HB 3.0TD D/C 4x4
    '07 Hilux D4D D/C 4x4
    '16 Ford Ranger 2.2 DC XL Hi-Rider
    '12 Disco 4 SDV6 SE - Beauty
    '06 Disco 3 TDV6 S (De-cat, EGR blanked, remap, Johnson rods suspension rods, 285/65-R17 Kuhmo KL61) - Beast
    '04 Terracan 3.5 V6
    '96 Ssang Yong Musso 602 (non turbo manual)
    '04 Ford Ranger 2.5 TDI D/C 4x4 with Solid front axle and 33" Maxxis
  11. #111
    Feb 2013
    Wellington
    Default Broken starter motor
    Model: Defender 3.5 V8
    Year: 1992
    Mileage: 205 606 km
    Problem: Loud noise from starter and no start
    Cause of problem(if known): Starter casing head broken
    Cost of repair: R2 500
    Who did the repair: Schalk Burger 4x4
  12. #112
    Sandton
    Thanked: 70
    Model: Discovery 3
    Year: 2008
    Mileage: 45000
    Problem: Park Brake screeching
    Cause of problem: Design
    Cost of repair: R800
    Who did the repair: LR Sandton
    Model: Discovery 3
    Year: 2008
    Mileage: 50000
    Problem: Park Brake screeching (again)
    Cause of problem: Poor adjustment the first time
    Model: Discovery 3
    Year: 2008
    Mileage: 64000
    Problem: Turbo actuator
    Cause of problem: ?
    Cost of repair: R37000
    Vehicle under warranty, Y/N: Y – Motorite extended motor plan
    Model: Discovery 3
    Year: 2008
    Mileage: 78000
    Problem: Car suspension sinks overnight
    Cause of problem: Suspension pump
    Cost of repair: R9600
    Vehicle under warranty, Y/N: Y – Motorite extended warrantee
    2013 Discovery 4 SDV6S
    2008 Discovery 3 TDV6S (SWAMBO)
    Imagine Comfortvan
  13. #113
    Thanked: 7
    Default '12 Derfender Puma 130
    Model: Land Rover Defender 2.2 Puma 130 HCPU
    Year:2012
    Mileage: 18 000
    Problem: Blown engine (details will be updated)
    Cause of problem(if known): Assumed to be due to oil cooler failure (will be updated)
    Specifics of repair work carried out: Been told complete new engine (will be updated)
    Cost of repair: R 25 000 so far and counting
    Who did the repair: Land Rover Francistown have been assigned the work by LR RSA
    Was damage covered by warranty: will let you know
    '11 Toyota LC 79 4.0 V6 Meano D/C - current
    '12 Defender 130 Puma 2.2 - 2015
    '06 Defender 130 TD5 - K.I.A.
    V51R
  14. #114
    Jun 2013
    Default Landrover discovery 3 TDV6 HSE
    Model: Landrover discovery 3 TDV6 HSE
    Year:2008
    Mileage: 125 000
    Problem: No power on cold mornings from idle to 1800 RPM, until engine fully warmed up.
    Cause of problem(if known): Stuck EGR valves
    Specifics of repair work carried out: Blanked
    Cost of repair: Approx R10 500 Replaced (Land Rover) or R 2500 to blank)
    Who did the repair: Land Rover Service Center
    Vehicle under warranty, Y/N: Yes (Motorite)
    Year:2008
    Mileage: 130 433
    Problem: Droning noise when driving at speed.
    Cause of problem(if known): Wheel bearing
    Specifics of repair work carried out: New wheel bearing & hub assembly
    Cost of repair: Approx R4400.00
    Who did the repair: Land Rover N1 City
    Was damage covered by warranty: Yes
    Year:2008
    Mileage: 131 000
    Problem: Battery light illuminated.
    Cause of problem(if known): Alternator
    Specifics of repair work carried out: New alternator
    Cost of repair: Approx R6500.00
  15. #115
    Wellington NZ
    2013 110 SWSE 2.2 15000
    300km engine light - MAF sensor and new intake manifold
    840km first visit for kangaroo issue - reload software
    repair leaking windscreen driver side
    2000km new turbo delivery tube upgraded recall on part
    download computer due to kangaroo issue no remedy offered.
    2200km replace new turbo delivery tube rubbed through on pulley
    3800km return as passenger side leaking water reseal window
    download computer due to kangaroo effect no remedy offered.
    Tech comes along for a drive agrees not normal and not drive train slop as suspected.
    5200km download computer and reset fault code activated by kangaroo effect
    7300km hub seal leaking wiped with cloth, both sides of front window leaking.
    8000km hub still leaking after being wiped down with rag surprise surprise window still leaking both sides
    8500km hub seal still leaking new seal approved by JLRNZ window replacement approved
    9200km new hub seals fitted, new window fitted
    9800km hub still leaking new hub ordered.
    11400km new driver side hub fitted passenger side window leaking computer downloaded no codes from computer no cure for kangaroo effect
    12000km passenger side hub leaking oil seal failed trucked to dealer new hub on order.
    13800km engine fails after kangaroo effect engine light on restarts after 4 min limp to garage, suspect MAF sensor
    13900km engine fails after kangaroo effect limp to download no cure JLRNZ instructs to replace MAF sensor and manifold. Test fuel system and pressure
    14300 DPF light stays on, engine light on, kangaroo remains, still leaking water cleared no remedies. Told to stabilise foot on side of car to prevent micro movements fuel pedal sensor very sensitive, change driving style.
    15000 return car for modification that will seal water leak, JLRNZ repair instructions tape black rubish bag over heater module using gaffer tape. Instructions on repair as per document from JLRNZ.
    Lost the plot after seeing the repair and instructions on repair. Contact dealer and MTA advise I would like full refund of vehicle. MTA provides mediator for process, I opted to seek legal advice, solicitor will be present during meeting on monday. Dealership covering the cost of the solicitor, MTA surprised in JLRNZ instructions on repairs and comments, agrees full refund is a reasonable request or replacement car with all extras transferred.
    Sent from my iPad using Tapatalk HD
    GLS triton so far so good 47800km and its still going strong. Only mod egr bypass
  16. #116
    Sep 2013
    Langosta
    Default One of many
    Model:110 TD5
    Year:2002
    Mileage:138,000
    Problem:ECU
    Cause of problem(if known):Lightening strike
    Specifics of repair work carried out: New ecu and purchase nanocom By self re-map
    Cost of repair:$1,800.00
    Who did the repair:I did
    Vehicle under warranty, Y/N:No
    Was damage covered by warranty: No act of God
ID:	242880   Click image for larger version.
  17. #117
    Jul 2007
    Despatch
    Thanked: 21
    Model: D3 TDV6 S
    Year:2006
    Mileage:192 000
    Problem: knocking sound when cornering and rear wheels feeling loose......anti-roll bar bushes.
    Cause of problem(if known): age deteriation?
    Specifics of repair work carried out: replace with new bushes
    Cost of repair: R1800
    Who did the repair: Savoy Landrover indy, Port Elizabeth
    Vehicle under warranty, Y/N: Y - Motormend policy
    Was damage covered by warranty: Hope so
    Offroad junky
    Previously;
    '04 Terracan 3.5 V6
  18. #118
    Model: Freelander TDs 4 e
    Year:2010
    Mileage:160000
    Problem: Steer column locked - car not starting
    Cause of problem(if known): not sure
    Specifics of repair work carried out: new battery and new instrument cluster
    Cost of repair:+/- R15000
    Who did the repair: Land rover N1 City
    Was damage covered by warranty:[/QUOTE]No
    Replace battery first on recommendation of LR N1 City.... Two weeks later same problem - Steering column locked car not starting.
    LR N1 City recommended the replacement of the instrument cluster.... 4 Days later same problem...steering column locked - car not starting...
    Car will be towed to LR N1 city on Monday and who knows what the excuse is going to be and how much more money I would need to spend....
    Any boby got any advise on this matter...?
  19. #119
    Thanked: 182
    Model: Discovery 3 TDV6
    Year: 2005
    Mileage: 160100
    Problem: Suspension fault - locked in offroad height.
    Cause of problem(if known): Compressor exhaust valve not releasing.
    Specifics of repair work carried out: Jaco from LMC, Bredell sorted it out in a few minutes, turned out to be a loose connector.
    Cost of repair: None (thank you Jaco)
    Who did the repair: LMC, Bredell
    Was damage covered by warranty: N/A
    Sent from my Atari 2600
    Life's too short to drive boring...
    2011 Disco 4 SDV6 SE (iNyathi)
    2005 Disco 3 TDV6 HSE (Pepper)
    1994 Pajero 3.0 V6 (Ruby)
  20. #120
    Jul 2013
    Krugersdorp
    Model: Discovery 2 Td5 Autobox
    Year:2002
    Mileage:198,000
    Problem: Heavy gearbox clunking on shifts
    Cause of problem(if known): Gearbox shot
    Specifics of repair work carried out: Reconditioned gearbox, new flex plate
    Cost of repair:+/- R15,600 all in
    Who did the repair: Centurion Gearbox & Diff
    Was damage covered by warranty:No
    Centurion was pleasant to deal with, and seemed very professional. Will collect my car next week as I am out of the country right now.
  1. Jeep Problems
    By Barto in forum Jeep
    Last Post: 2020/02/17, 04:31 PM
  2. Hyundai Problems!
    By Barto in forum Hyundai
    Last Post: 2016/08/08, 01:49 PM
  3. Kia Problems!
    By Barto in forum Kia
    Last Post: 2014/03/21, 10:18 AM
  4. Conqueror Companion: Dream becomes nightmare
    By Alta in forum Camping, Fridges, Accessories
    Last Post: 2012/10/21, 09:54 PM
  5. Discovery 3 CD and Cruise Control problems (incl. bad experience with dealer)
    By ReadySteadyGo in forum Land Rover
    Last Post: 2011/11/09, 07:40 AM
