Land Rover Problems! - Page 2
Page 2 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 21 to 40 of 188
  1. #21
    JOHANNESBURG
    Model: Discovery 2 Td5
    Year:2004
    Mileage:150000
    Problem:Lost traction
    Cause of problem(if known):Auto box cooler pipe pulled loose
    Specifics of repair work carried out:New Flexable pipe fitted to cooler connection
    Cost of repair: app R800.00
    Who did the repair:Landrover Bedfordview
    Was damage covered by warranty: N
  2. #22
    JOHANNESBURG
    Modeliscovery 2
    Year:2004
    Mileage:150000
    Problem:Fuel leak above tank
    Cause of problem(if known):Broken high pressure fuel line
    Specifics of repair work carried out:replaced fuel line
    Cost of repair: R400.00
  3. #23
    Uppsala Sweden
    Modeliscovery Tdi
    Year:1996
    Mileage:340000 the engine gave up the ghost
    Cause of problem(if known):The pistons became damaged due to overheating.
    Repairr work carried out: Purchased new engine
    Cost of repair:35000rand
    Who did the repair:Land Rover Witbank
    Vehicle under warranty, Y/N:N
    Was damage covered by warranty:N
    New engine has a one year warranty
  4. #24
    Sandton
    Thanked: 58
    Model: Discovery 1
    Year: 1998
    Mileage: 238565
    Problem 1: Snapped rear half shaft
    Problem 2: Transfer case not engaging CDL or high range / low range
    Cause of problem(if known) 1: Play in transfer case caused it to break
    Cause of problem(if known) 2: High range gear worn, hi - lo selector hub and sleeve worn, shims and thrust washers none existent.
    Specifics of repair work carried out: Overhaul transfer case
    Cost of repair: R9785
    Who did the repair: Brit Auto
    Was damage covered by warranty: Towing yes, damage no unfortunately
    Mike
    Thanks to:
    M&P Fabworx
    Zone Offroad
    TJ Evolution - Jeep Builds - Overland Blog
    "Evolution through carnage, the Jeep will keep what its wants!"
  5. #25
    Model: Disco 1
    Year:1999
    Mileage:184000
    Problem: Rear sunroof leak
    Cause of problem(if known): Sunroof seal which sunroof sits down on perished & possibly shrunk
    Specifics of repair work carried out: 1. Repleaced seal with good 2nd hand seal from Liemers
    Cost of repair: R50
    Who did the repair: Done by me
    Vehicle under warranty, Y/N: no
    Was damage covered by warranty: no
    so chuffed that its fixed!!
    Platkar driver...
    '99 Land Rover Discovery 3.9 V8i - SOLD
    Challenger Bundu Basher - SOLD
    I will drive a Land Rover again...
  6. #26
    Jan 2007
    Eindhoven
    Thanked: 19
    Model: Discovery 2
    Year: 2005
    Mileage: 140000
    Problem 1: Flashing M&S lights
    Problem2: Leaking transfer case seal, leaking front diff oil seal
    Cause of problem(if known) 1: Faulty valve block
    Specifics of repair work carried out: Replace valve block on transmission, Replace front diff oil seal and new oil. Remove transfer case, replace all gaskets and seals.
    Cost of repair: R11 800.00
    Who did the repair: Centurion Gearbox & Diff
    Vehicle under warranty, Y/N: No
    Was damage covered by warranty: No
    Deon Viljoen
    Boyscout
    2012 Land Rover Defender 90 2.2 Tdci S/W Sold
    2005 D2 XS TD5 Auto sold at 189000km
    2003 D2 GS TD5 Auto sold at 165000km
    1999 D2 GS V8 Auto sold at 178000km
  7. #27
    Default Puma
    Model: Defender Puma 110 SW
    Year: 2007
    Mileage: 84 000
    Problem: Occasional loss of power, temp gauge rise to red and back
    Cause of problem(if known): Head Gasket
    Specifics of repair work carried out: Replace gasket
    Cost of repair: ?
    Who did the repair: LR Mokopane (MGM Motors)
    Vehicle under warranty, Y/N: Y
    Was damage covered by warranty: Y
  8. #28
    Model: Disco 4 3.0 TDV6 HSE
    Year: 2009
    Mileage: 23420 km
    Problem: Front suspension squeeks over speed bumps
    Cause of problem(if known): Apparantly Bushes on steering system
    Specifics of repair work carried out: New Bushes
    Cost of repair: ?
    Who did the repair: L R Menlyn
    Vehicle under warranty, Y/N:Y
    Was damage covered by warranty:Y
    Year: 2009
    Mileage: 23420 km
    Problem: Camera system failure as and when
    Cause of problem(if known): apparantly faulty wiring connection in bumper
    Specifics of repair work carried out: They say they fixed connection but its STILL BROKEN
    Cost of repair: ?
    Who did the repair: LR Centurion
    Year: 2009
    Mileage: 23420 km
    Problem: Rattle on FR brakes over gravel road
    Cause of problem(if known): ?
    Specifics of repair work carried out: New brakepads
    Cost of repair: ?
    Who did the repair:
    Year: 2009
    Mileage: 23420 km
    Problem: Diesel consumption reads 11 l/100km but gives actually 15l/100km
    Cause of problem(if known): Menlyn and Centurion says everything is ok
    Specifics of repair work carried out: Nothing - so dont believe stats
    Cost of repair:0
    Who did the repair:Menlyn and Centurion
    Vehicle under warranty, Y/N: y
    Was damage covered by warranty:y
    Year: 2009
    Mileage: 23420 km
    Problem: Black & Blue Smoke from exhaust even when enging is warm
    Cause of problem(if known): Nothing according to LR
    Specifics of repair work carried out:-
    Cost of repair:-
  9. #29
    Jul 2010
    Nylstroom
    Model:Puma
    Year:2009
    Mileage:600km-55000Km
    Problem: Engine turns but don’t start. Power loss in hot weather.
    Cause of problem(if known):?
    Specifics of repair work carried out: Disconect positive on battery and reconnect. Replace harness/cluster
    Cost of repair: ?
    Who did the repair: MGM/Santon/Centurion/Maun
    Model:Puma
    Year:2009
    Mileage: 56000 Km
    Problem: Top gasket
    Specifics of repair work carried out: no
    Cost of repair:
    Who did the repair: Rustenburg
    Model:Puma
    Year:2009
    Mileage: 57 000 km-60 000 km
    Problem: starter disintegrated and alternator failure
    Cause of problem(if known): no
    Specifics of repair work carried out: Replace 3 starts and 2 alternators in one month
    Cost of repair: ?
    Who did the repair: Maun/Centurion
  10. #30
    Jul 2010
    Grahamstown
    Default Defender Puma 130
    Modelefender Puma 130
    Year:2010
    Mileage:4000kms
    Problem:loss of steering fluid
    Cause of problem(if known):loose coupling nut on steering pump hose
    Specifics of repair work carried out:secured nut refill with specific Land rover PAS steering fluid
    Cost of repair:unknown
    Who did the repair:me.
    Was damage covered by warranty: not sure if any damage
    __________________
  11. #31
    Ballito
    Thanked: 16
    Model: Defender 110 TD 5 CSW
    Year: 2001
    Mileage: 234 510
    Problem: No clutch
    Specifics of repair work carried out: Replaced master & slave cylinder
    Cost of repair: R7000
    Who did the repair: Land Rover Constantia Kloof
    Vehicle under warranty, Y/N: Had extended warranty on vehicle
    Was damage covered by warranty: Partially
    2007 Mitsibushi Triton 2.5 Did 4x4 D/cab (Sold)
  12. #32
    Model: Discovery 2 TD5
    Year: 2003
    Mileage: 89 000
    Problem: Steering box, 3 amigos, Fuel cooler leak, leak between gearbox and transfer box, harness issues
    Cause of problem(if known): bad maintenance and lack of interest from dealer
    Specifics of repair work carried out: Harness replaced, Steering box and steering pump replaced. Shuttle valve recon, fuel cooler recon, gasket and o rings replaced
    Cost of repair: Steering R20K (through Dealer), Harness 16K (through Dealer), Balance 14K privately
    Who did the repair: Dealer did some, balance of work by REM Landy
    Vehicle under warranty, Y/N: Yes
    Was damage covered by warranty: 8k towards steering box only!
  13. #33
    Cape Town (Sunningdale)
    Model: Defender 90 TD5
    Year: 2004
    Mileage: 102,000
    Problem:
    1.) Aircon Condencer fan replaced on 99,000km
    2.) Flywheel and clutch kit replaced 102,000km
    3.) All seals and washers replaced in transfer box 102,000km
    1.) not known
    2.) Wear and tear.... probably the previous owner towed his house or something
    3.) not known
    Cost of repair:
    1.) R1,000
    2.) R13,000
    3.) R3600
    Who did the repair:
    1.) Independent Car Radio & Alarm (Centurion)
    2. & 3.) Independent 4x4 (Montana)
    Was damage covered by warranty: R4,000 for the clutch was covered by MBI
    2012 Defender 110 Puma 2.2
    Ex: 2004 Defender 90 TD5
  14. #34
    Aug 2010
    Year: 2004
    Mileage: 95000
    Problem: oil leaks
    Cause of problem(if known): It was designed this way........
    Specifics of repair work carried out: Replaced front crank shaft oil seal and gasket
    Cost of repair: R1900
    Who did the repair: British 4X4
    2012 Land Rover Defender 110 2.2 Puma
    2004 Land Rover Defender 90 td5 (SOLD IT)
  15. #35
    Sep 2010
    Roodekrans
    Year: 2003
    Mileage: 73000
    Problem: Rear Shock mountings broke off
    Cause of problem(if known): Poor design of mountings, and some pilot abuse
    Specifics of repair work carried out: Redesigned and manufactured new mountings
    Cost of repair: R160
    Who did the repair: Me
    EX: Mitsu Man
    Gerhard de Lange
    2014 Isuzu KB 250 DC 4x4
    2013 Isuzu KB 300 Club
    2003 Defender TD5 with everything.(My 4x4)
    2005 Hyundai Getz
    1962 Land Rover Series 11A 109 Inch (My project)
    1962 Land Rover Series 11A 89 Inch (My other project)
  16. #36
    Sep 2010
    Modelefender CSW TD5
    Year:2006
    Mileage:109850
    Problem:Clutch @ 50000km
    Cause of problem(if known):Not Known
    Specifics of repair work carried out:Replaced
    Cost of repair:R8000
    Who did the repair:LR PE
    Was damage covered by warrantyartly = 3/8
    _____
  17. #37
    Model: Defender 90 Td5 (owned for 3 months)
    Year: 1999
    Mileage: 217 000km (No previous work on engine)
    Problem: 1.Oil Cooler 2. Head Gasket 3.Turbo 4. Water Pump 5. Oil Pump
    Cause of problem(if known): Coolant Pipe burst, then everything else went quickly.
    Specifics of repair work carried out: Non as yet.
    Cost of repair: Quote: Td5 Overall = R37k, V8 Conversion: R51k
    Who did the repair: Quotes: Rovertech Mosselbay. Similar from Cape Town.
  18. #38
    Dec 2010
    Florida Park
    Default Hi
    Model: Freelander TD4 HSE 5dr
    Year:2004
    Mileage:117680
    Problem: abs,tc and Hilldecent lights staying on:-( hilldecent doesn't work and ratling, Clanking noise when braking.
    Cause of problem(if known): N/A
    Specifics of repair work carried out: new driveshaft,CV joints,Propshaft, New Brake switch
    Cost of repair: R10000+
    Who did the repair: Rand Rover in Fairland
  19. #39
    Jan 2011
    Smile
    Model: Land Rover Discovery TD5
    Year:2004
    Mileage:103000
    Problem:Rear suspension sagging
    Cause of problem(if known): Air below
    Specifics of repair work carried out: Air below replaced
    Cost of repair: R 3600
    Who did the repair: 3 Lions
    Was damage covered by warranty: n/a
  20. #40
    Jan 2011
    Model:Land Rover Discovery 2 TD5
    Year: 2004
    Mileage: 103000
    Problem: Sluggish performance
    Cause of problem(if known): Software
    Specifics of repair work carried out: Software upgraded
    Cost of repair: R 3500
    Who did the repair: Wayns 4x4
    Vehicle under warranty, Y/N:n
    Was damage covered by warranty:n/a
  1. Jeep Problems
    By Barto in forum Jeep
    Last Post: 2020/02/17, 04:31 PM
  2. Hyundai Problems!
    By Barto in forum Hyundai
    Last Post: 2016/08/08, 01:49 PM
  3. Kia Problems!
    By Barto in forum Kia
    Last Post: 2014/03/21, 10:18 AM
  4. Conqueror Companion: Dream becomes nightmare
    By Alta in forum Camping, Fridges, Accessories
    Last Post: 2012/10/21, 09:54 PM
  5. Discovery 3 CD and Cruise Control problems (incl. bad experience with dealer)
    By ReadySteadyGo in forum Land Rover
    Last Post: 2011/11/09, 07:40 AM
