Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 41 to 60 of 69
  1. #41
    Sep 2011
    Model: Scorpio D/Cab 2.2 mHawk 4X4
    Year: 2013
    Mileage: 72,000
    Problem: 4 Wheel drive not engaging
    Cause of problem(if known): Apparently controller faulty ??
    Specifics of repair work carried out: 4x4 control unit to be replaced.
    Cost of repair: 0
    Who did the repair: Mahindra Centurion
    Vehicle under warranty, Y/N: Y
    Was damage covered by warranty: Y
    Vehicle was in for 2 days without Mahindra Centurion being able to source parts. Once parts sourced had to wait for a week to get appointment to repair.
  2. #42
    Sep 2013
    Sasolburg
    Model: Scorpio D/Cab 2.2 mHawk Adventure
    Year: 2013
    Mileage: 26,000
    Problem: Right-front stabiliser arm bracket behind bash-plate came loose and
    Cause of problem(if known): Unknown - Mahindra Vaal claims that the two bolts holding the bracket in place either rattled loose or where scheered off. The latter is absurd as there are no further damage to the vehicle. The bolts were supposedly check during the 25k repair process.
    Specifics of repair work carried out: Replaced two bolts
    Cost of repair: R 256
    Who did the repair: Mahindra Vanderbijlpark
    Was damage covered by warranty: N
  3. #43
    Albertinia
    Default André Louwrens
    Firstly a word of sincere appreciation for so many things the forum has taught me over several years. The honour is mine to be part of an effective team.
    Model: Scorpio 2.6 SUV 4x4 CRDe GLX
    Year: 2007
    Mileage: 151 000
    Problem: Lack of diesel supply, manifesting in bleeding pump on top of diesel filter being sucked in, flat onto the diesel filter mount
    Cause of problem(if known): Diesel feeding line. Collapse of softer rubber pipes?
    Specifics of repair work carried out: Cleaned fuel tank and pipes and replace fuel pipes
    Cost of repair: R50
    Who did the repair: self
    Model: ditto
    Year: 2007
    Mileage: 151 000
    Problem: cracked on top side of diesel tank, overflowing when filled
    Cause of problem(if known): poor quality
    Specifics of repair work carried out: welded it
    Cost of repair: 0
    Model: ditto
    Year: 2007
    Mileage: 151 000
    Problem: auto hubs did not lock
    Cause of problem(if known): wheel bearings lock nut loose
    Specifics of repair work carried out: fixed wheel bearings and replaced auto hubs with mechanically lockable hubs
    Cost of repair: R2 000
    Model: ditto
    Year: 2007
    Mileage: 151 000
    Problem: unstable at rear and swerving when loaded
    Cause of problem(if known): worn bushes
    Specifics of repair work carried out: air helper springs
    Who did the repair: Safari Centre
  4. #44
    Jan 2016
    Boksburg
    Thanked: 151
    Default Re: Mahindra Problems!
    Model: XUV 500 W6
    Year: 2013
    Mileage: 26000km
    Problem: Front suspension bushes worn
    Cause of problem(if known): Inferior material
    Specifics of repair work carried out: Replaced under warranty
    Cost of repair: 0
    Who did the repair: Mahindra Alberton
    Model: XUV 500 W6
    Year: 2013
    Mileage: 31000km
    Problem: Infotainment system (radio etc) blown
    Cause of problem(if known): Don't know
    Cost of repair: 0
    2019 Fortuner 2.4 Auto 4x4
    2006 Jeep 3.7 Limited with 1.5" lift
  5. #45
    Feb 2016
    Villorba
    Thanked: 9
    Model: Scorpio 2.5 crde
    Year: 2008
    Mileage: 60000km
    Problem: Alternator overcharging
    Cause of problem(if known): probably faulty regulator
    Specifics of repair work carried out: Alternator replaced, unabled to find single components (in Italy)
    Cost of repair: 250 USD
    Who did the repair: Myself
  6. #46
    Jul 2010
    Model: Genio
    Year: 2015
    Mileage:103000km
    Problems: 50000km: 1.Center bearing. 2.Prop-shaft
    102000km: 3.Suspension torn off 4.Gearbox unable to select gears
    Cause of problem(if known): Build quality
    Specifics of repair work carried out: Replace item 1 and 2.
    Item 3 and 4 still under review by mahindra warranty department
    Cost of repair: R4850
    Who did the repair: Diff Centre
    Vehicle under warranty, Y/N: Yes
    Was damage covered by warranty: No for item 1 and 2 waiting for response on item 3 and 4
  7. #47
    Jul 2010
    Model: Genio
    Year: 2016
    Mileage: 60000km
    60000km: 3. Rear Diff spiral gears
    Item 3
    Cost of repair: R5800
  8. #48
    Hartbeespoort
    Model: Scorpio Pik-Up D/C 2.2 mHawk 4x4
    Year:
    2014
    Mileage:
    53,000
    Problem:
    Diesel fuel tank failure. About 6 hairline cracks, of about 5cm each, all over the bottom of the tank.
    Inferior materials used in manufacturing (?)
    Replaced the diesel tank. The dealer actuallty had a new diesel tank in stock and it was replaced the next day, after I contacted them.
    Cost of repair:
    Nothing - done under warranty
    Who did the repair:
    Dealer - Mahindra, Brits
    Yes
    Yes
    Martin Knoetze
    2022 Mahindra S11 Adventure SUV
    <!--Session data--><!--Session data-->
  9. #49
    Jul 2017
    Deneysville
    Thanked: 417
    Model: Scorpio 2.5 4x4
    Year: 2012
    Mileage: 118000
    Problem: Electronic gear select malfunction. Gearbox will select or deselect 4H but when switching over to 4L the light on the dash indicates selected but the gearbox does not switch over
    Cause of problem(if known): "inoperative electric coil"
    Specifics of repair work carried out: Gearbox sent to outside repair center
    Cost of repair: Unknown
    Who did the repair: Mahindra Centurion and subcontracted gearbox repair center
  10. #50
    Jul 2017
    Deneysville
    Thanked: 417
    Year: 2012
    Mileage: 120000
    Problem: Veicle struggles to start and sounds like it is running on 3 cylinders
    Cause of problem(if known): Pipe between filters and pump rubbed through on bracket. Discovered by trying to build pressure with tos pump
    Specifics of repair work carried out: Replace pipe
    Cost of repair: Had the spare
    Who did the repair: Me, God gave me hands
    Vehicle under warranty, Y/N: Y But it would cost me more to get the vehicle to them
    Was damage covered by warranty: Could not be bothered
    My Life Loving It
  11. #51
    Feb 2016
    Villorba
    Thanked: 9
    Year: 2008
    Mileage: 70000km
    Problem: Broken front dx JV joint
    Cause of problem(if known): off road abuse
    Specifics of repair work carried out: bought second hand JV, sent to specialist for refurbishing
    Cost of repair: 350 USD plus manpower (new CV is around 1200 USD)
    Who did the repair: mechanic
  12. #52
    Nov 2018
    Model: 4x4 Double Cab Pik-up
    Year: November 2018
    Mileage: 35750
    Problem: various small niggles
    1. Start/Stop function intermittent
    2. Radio controls freeze up until vehicle is switched off and left to reset. This is both on the radio itself and steering controls
    3. Rattling sound from the rear axle when driving off-road
    1. Mahindra has not come back to me on a possible solution
    2. Probably software issues, still to be reported to Mahindra. Problem 1 and 2 are probably related.
    3. No idea, it has done this since new.
    1.
    Mahindra Benoni replaced the sensor but this did not fix the problem.
    2. To be reported
    3. To be reported
    Cost of repair:
    1. Warranty repair
    Who did the repair:
    1. Mahindra Benoni
    Was damage covered by warranty: Yes
  13. #53
    Apr 2014
    delmas
    Goodday. I have a problem with my 2007 Mahindra Scorpio 2.6 TDI glx SUV. It struggle to start in the mornings. What I noticed is that the low pressure pump is loosing pressure overnight and if you pump it, it becomes tight but still if pressing hard it feels that it is passing. I have changed the 2 filters as it was smelling diesel when running and there was plenty of smoke an rough idling and now power. Now there is power after changing the filters. On idling there is blue smoke from the exhaust and driving slowly at about 40 -50 km/h it remains there but driving at 70-90 km/h it disappears. What can be the problem.
  14. #54
    Feb 2019
    Orkney
    Thanked: 12
    2010 Thar 10200 km
    Handbrake not working properly if at all after many attempts to fix, not going on 4x4 tracks because of it.
    Alternator packed up, replaced with Nissan 2.5 diesel alt, only put the old pulley on - perfect fit.
    Replaced seats.
    For the rest, no problems.!
  15. #55
    Constantia Kloof
    Thanked: 4524
    Model: Pik Up S6
    Year: 2019
    Mileage: 57 700km
    Problem: Screeching noise on acceleration. Only when vehicle has reached operating temperature and been stopped for 10 minutes to 2 hours. Not present when started from cold in the morning and when it does happen goes away when driven for more than 3 KM. Very unusual.
    Cause of problem(if known): Leaking exhaust manifold gasket identified.
    Specifics of repair work carried out: Replace gasket, expansion tank, thermostat, details below.
    Cost of repair: R0.00
    Who did the repair: Mahindra West Rand
    Upon workshop inspection of vehicle mechanic also picked up pinhole leak in expansion tank and apparently thermostat is not working properly although the vehicle has not overheated. All will be covered by warranty.
    Brandt Theunissen
    2024 Isuzu D-MAX 3.0 DDI LSE 4X4 A/T E/CAB
    2007 Mercedes Benz ML500 5.5
    1968 VW Beetle 2276
  16. The Following User Says Thank You to Koebelwagen For This Useful Post:
  17. #56
    Benoni, Gauteng
    Thanked: 189
    Model: Thar
    Year: 2018
    Mileage: 108 500
    Problem: Gearbox 5th gear failure
    Cause of problem(if known): Unknown, failed without any warning.
    Specifics of repair work carried out: Full gearbox rebuild after failure of needle bearings on 5th gear shaft.
    Cost of repair: R18k
    Who did the repair: Auto Sphere Benoni (Mahindra Benoni Authorized repair centre)
    Eric
    (ZS6EPL)
    ME_______ - 2018 Mahindra THAR - Hard Top / VHF+UHF Comms / Winch / Safari Center Off Road Camper Trailer
    SWAMBO__ - 2014 Mahindra BOLERO - Feels like an SJ / loads like a truck / tows like a tank!
    RETIRED___ - Zooks Galore ...'08 Jimny / '99 Gen 1 GV / 1.6 Vitara JLX-x2 / SJ413 SWB-x3 / SJ413 LWB-x1 / SJ410-x2.
  18. #57
    Feb 2013
    Melkbosstrand
    Thanked: 9
    Model: Thar
    Year: 2017
    Mileage: 50000
    Problem: Radiator bypass hose burst
    Cause of problem(if known): pipe perished
    Specifics of repair work carried out: Replacement pipe and antifreeze from Mahindra
    Cost of repair: R250.00
    Who did the repair: Self
ID:	634641Click image for larger version.
    Current
    2020 Renault Duster
    2017 Mahindra Thar
    Previous
    2013 Subaru XV
    2012 Juke 2wd
    2010 Terios 4X4
    1999 Mazda DC 4X4
  19. The Following 3 Users Say Thank You to MLOYLO For This Useful Post:
  20. #58
    Jul 2013
    JHB
    Thanked: 37
    Model: Scorpio suv s11
    Year:2021
    Mileage: less than 1500
    Problem: rear diff disintegrate pinion bearing collapse
    Cause of problem(if known): bad bearing or poor assembly
    Specifics of repair work carried out: changed pinion gear ⚙ ring gear ⚙ and pinion bearings
    Cost of repair: 0
    Who did the repair: Mahindra East Rand
    Vehicle under warranty, Y/N: y
    Was damage covered by warranty:y
  21. #59
    Jul 2013
    JHB
    Thanked: 37
    Year:2021
    Problem: rear parking sensor fault after my Bundo Bumper was fitted
    Cause of problem(if known): poor assembly prehaps #### happens
    Specifics of repair work carried out: changed sensor to new
    Cost of repair: 0
  22. #60
    Feb 2013
    Melkbosstrand
    Thanked: 9
    Model: Thar
    Year: 2017
    Mileage: 50000
    Problem: Turbo Pipe burst
    Cause of problem(if known): pipe burst(very soft)
    Specifics of repair work carried out: Replacement pipe from Mahindra
    Cost of repair: R733.00
    Current
    2020 Renault Duster
    2017 Mahindra Thar
    Previous
    2013 Subaru XV
    2012 Juke 2wd
    2010 Terios 4X4
    1999 Mazda DC 4X4
  1. Mahindra clutch problems.
    By cat's in forum Mahindra
    Last Post: 2018/02/16, 08:02 PM
  2. mahindra turbo problems
    By Marius.bigboy in forum Mahindra
    Last Post: 2011/07/18, 09:51 AM
  3. Mahindra Scorpio Problems
    By PJ_Kotze in forum Mahindra
    Last Post: 2011/05/04, 10:50 AM
  4. Mahindra '05 2.6 Enjin problems
    By Exstream in forum Mahindra
    Last Post: 2010/08/16, 08:33 AM
  5. Mahindra Starting problems
    By Duka in forum Mahindra
    Last Post: 2010/01/18, 02:19 PM
