Page 4 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 ... LastLast
Results 61 to 80 of 207
  1. #61
    Model: 3.2 DiD GLS LWB
    Year: 2008
    Mileage: 2008
    Problem: Rattles, Rear bumper cheap plastic to low
    Cause of problem(if known): Bad departure angle
    Specifics of repair work carried out: Panelbeater - refit/align and paint rear bumper
    Cost of repair:
    Who did the repair: Not done yet
    Vehicle under warranty, Y/N:
    Was damage covered by warranty:
    Pajero 3.2 GLS
    Echo 4
    KTM950 Adv
  2. #62
    Jun 2007
    Somewhere
    Thanked: 137
    Model: 3.5 V6 Triton
    Year: 2009
    Mileage: 3450
    Problem: Airbag light came on
    Cause of problem(if known): Faulty seat belt connection
    Specifics of repair work carried out: Replaced seat belt and connector next to seat
    Cost of repair: ?
    Who did the repair: Malmesbury Mitsubishi
    Vehicle under warranty, Y/N: Y
    Was damage covered by warranty: Y
  3. #63
    Model: Pajero Gen3 3.5
    Year: 2001
    Mileage: 197 000
    Problem: Brakes stops working
    Cause of problem(if known): ABS pressure pump
    Specifics of repair work carried out: Repair motor
    Cost of repair: R1500.00
    Who did the repair: Turbonutters
    2004 Land Rover Discovery TD5 Auto
    2000 Alfa GTV 3.2
    2007 Alfa 159 JTDm
    1999 BMW R1100S
  4. #64
    Creighton
    Default Maliyavuza
    Model:- Mitsubishi Pajero Sport
    Year:- Nov.'09
    Mileage:-15000kms
    Problem;- Blocked Radiators and Filthy engine compartment.
    Cause:-Heavy,rural grassland Tour. Bad secondary Zululand roads. No screens.
    Cost of Repair:- An entire Saturday in the Inspection pit, under the car,with air-hose and special long kinked pipe to blow forwards , followed by smelly parrafin/petrol wash, then compressed-air drying.
    Who did the repair:- Kippie.
    Vehicle under warranty:- Yes(and warned not to clean engine compartment with water.)
    Damage covered:- Not applicable.
  5. #65
    JHB
    Model: Colt 3L V6
    Year: 1999
    Mileage: 147 000
    Problem: Engine light came on followed by loss of power and a miss.
    Cause of problem(if known):Faulty spark plugs
    Specifics of repair work carried out: Replaced the spark plugs and oil and oil filter
    Cost of repair: R +- 400
    Who did the repair: I did
    Vehicle under warranty, Y/N: N/A
    Was damage covered by warranty: N/A
  6. #66
    Canberra, Australia
    Thanked: 758
    Model: Triton 2.5
    Year: 2007
    Mileage: 80 000km
    Problem: Noise somewhere at the fan belt
    Cause of problem(if known): Tensioner pulley
    Specifics of repair work carried out: Can't buy pulley seperate. Mitsu charged R989 for complete tensioner unit. I took the bearing out of the pulley and just replaced the bearing (it's a common size bearing, even available from autozone)
    Cost of repair: R30
    Who did the repair: Mysellf
  7. #67
    PWV
    Default Driver's side manifold cracked
    Model: Triton 3.5 v6
    Year: 2007
    Mileage: 150 000km
    Problem: Exhaust Noise at head
    Cause of problem(if known): Driver's side Manifold cracked between cyl 3 and 5
    Specifics of repair work carried out: Removed Manifold, welded Crack refitted.
    Cost of repair: Nothing
    downhill assist = middle pedal
    All truth passes through three phases:
    1. Violently opposed
    2. Horribly ridiculed
    3. Accepted as self evident
  8. #68
    Ballito
    Default gearbox
    Model:colt rodeo 3l 4x4 manual
    Year:2001
    Mileage:197000
    Problem:gearbox beyond repair
    Specifics of repair work carried out:re-con gearbox fitted
    Cost of repair:R20,000
    Who did the repair:local mechanic Leonard 084 929 0025
    Vehicle under warranty, Y/N:n
    Was damage covered by warranty: no but have now urchased an additional warrenty
  9. #69
    Kleinmond
    Model:2.8Tdi Colt Rodeo
    Year:2004Mileage:120000
    Problem: ABS does not work for a wile after the "bakkie" has been in salt water to launch my boat.
    Cause of problem(if known): Electrical shortage??
    Specifics of repair work carried out: Reverse light swich was disconected seem to have solved the problem.
    Cost of repair: +/- 5min of my time
    Who did the repair: Me
  10. #70
    Thanked: 17
    Model: 3.0 V6 Colt Rodeo 4x4
    Year: 1999
    Mileage: 296 000km
    Problem: All of a sudden not starting, ignition lights comes on but not even a click. Feedback on Brake Pedal.
    Cause of problem(if known): Short on the starter
    Specifics of repair work carried out: Rear drums skimmed and new linings fitted
    Cost of repair: R2000
    Who did the repair: Hattingh Motors Centurion
  11. #71
    Thanked: 1061
    Model: Triton 2.5 D/C 4x4
    Year: 2008 model (import)
    Mileage: 75000km
    Problem: Noise from engine bay
    Cause of problem(if known): Tensioner pulley bearing worn out.
    Specifics of repair work carried out: Replaced the whole pulley bracket as apparently the bearing cannot be replaced ( Bull Dust - I've done mine on the Colt after I was told they same story) but this time had it done by the agents.
    Cost of repair: R0.00
    Who did the repair: Mercurius Motors - Polokwane
    Vehicle under warranty, Y/N: Yes
    Was damage covered by warranty: Yes
    Nico Swart
    Triton 2.5DiD D/C with SS
    ZS6NJS
  12. #72
    Model: Colt Rodeo 2.8Tdi 4x4
    Year: 2003
    Mileage: 139476
    Problem: Vibration in drive train. Front suspension / steering showed signs of play
    Cause of problem(if known): Worn ball joints and stabiliser bar bushes. Front shocks leaking oil. Universal joints and centre bearing on prop shaft worn.
    Specifics of repair work carried out: Replace ball joints, bushes and shocks. Overhaul propshaft. Drilled out, retapped and replaced broken bolts on bash plate - I didn't report this as a fault but he saw it needed doing.
    Cost of repair: R 3,955.46
    Who did the repair: Kevern's Garage, Durban
    Vehicle under warranty, Y/N: No
    Was damage covered by warranty: No
  13. #73
    Jan 2009
    Moreletta
    Model: Triton 2.5 D/C 4X4
    Year: 2007
    Mileage: 84031
    Problem: Steering suddenly became very heavy and grinding noise when turning the steering wheel.
    Cause of problem(if known): Pipe on steering rack came loose(!) and spilled all fluids.
    Specifics of repair work carried out: Pipe secured and fluids replaced
    Cost of repair: R 340.20
    Who did the repair: Mitsubishi Brooklyn
    Vehicle under warranty, Y/N: Yes (extended)
    Mitsubishi Triton 2.5 4X4 D/C
    BMW R1150GS
  14. #74
    NC
    Year: 2008
    Mileage: 2008
    Problem: Rattles
    Specifics of repair work carried out: Ek soek nog
    Cost of repair: Kan duur word, want ek is lus om 'n Prado te koop
    Vehicle under warranty, Y/N: Ja
    Land Cruiser 79 D/CAB - OME, ARB, Snorkel, Winch
    150 Prado 4.0 VX
    BMW 135i Coupe BMW Performance Power Kit
  15. #75
    Oct 2008
    Model: Colt 2.8 TD
    Year: 2000
    Mileage: 251000 Now
    Problem: Injectors at 230000 and 4x4 electronics. 251000 Overheating.
    Cause of problem(if known): Faulty water pump (leaking) Creaked head.
    Specifics of repair work carried out: Fitting SPX head..
    Cost of repair: water pump, thermostat, Head, Glo-plugs and labor. R10100
    Who did the repair: Mits Pro services. In Centurion
    Vehicle under warranty, Y/N: n
  16. #76
    May 2010
    Kommetjie
    Model:Triton 3.2Did 4x4
    Year:2009
    Mileage:+18000
    Problem:loss of power and heavy smoke
    Cause of problem(if known): Apparently blocked air filter and " air mass meter" ??
    Still waiting for the report from dealer
    Specifics of repair work carried out: replaced filter an cleaned the "air mass meter
    Cost of repair:R0.00
    Who did the repair: Nelspruit Mercedes
    Anyone who has had similar problems please contact me
    __________________
  17. #77
    Oct 2008
    Model: Pajero DiD LWB
    Year: 2006
    Mileage: 90000
    Problem: Fuel pump leaking
    Cause of problem (if known): Dealer suspect the Dual battery is too close to the fuel pump and is corroding the pump and pipes.
    Specifics of repair work carried out: Replace fuel pump and pipes
    Cost of repair: R10 000
    Who did the repair: Mitsubishi Tygerberg (Always receive good service from them)
    2006 Pajero GLS DiD LWB
    Compass Offroad boswa
    !!! Ons gaan in Pa se Jero ry !!!!
  18. #78
    De Kelders
    Thanked: 135
    Model:Pajero 3.8 Gls LWB
    Year:2006
    Mileage:65000km
    Problem:Starter motor noisy and slow.
    Cost of repair:R5000.00
    Who did the repair:Replaced starter motor assembly.
    Vehicle under warranty, Y/N:Maintnance plan.
    Was damage covered by warranty:y
    __________________
  19. #79
    Milnerton
    Default Colt 2.8TD 4x4 DC
    First Mager Problem in 1998 - Noizy sound when driving 100km/p/h
    Had diff overhauled. R 5800
    Replaced all shocks R 1800
    Replaced all tyres R 5200
    Problem still there. I found the problem my self. The wheel nuts did not keep the wheel tight. I put a washer behind each nut. Problem solved. Cost me R30.
    Second Mager Problem in 1999 - Clutch palte needed replacing.
    Cost of repair - R7000
    Third Mager Problem now recent. 2010 - Cylender head cracked.
    Cause: - Radiator blocked at bottom section.
    I got a new complete head from Alert engin parts for R4500
    All parts incl. head cost R5700
    Machanic cost R1500
    New Radiator costs R1700 from Silverton.
    I have spend allot of money so far but yet need to say it is better to have a personal mechanic who you know. The previosly services the machanics never picked up there is a problem with the radiator. Even when I told them i am losing water and my bakkie are running at slight higher temp. The last chap said he put in special radiator fix and I would see a difference in a week. Two months later I have a cracked head. I asked the mechanic who is working on my bakkie now to keep the bakkie for another week and check every thing. He is doing the work himself and not the appies.
    I hope I will be happy after this. I bought the bakkie with 120k on the clock. Current reading is 280k
  20. #80
    Pereybere
    Thanked: 27
    Model:Triton 3.5 V6
    Year:2008
    Mileage:+-70 000km
    Problem:Worn Clutch
    Cause of problem(if known):Plenty of off road driving and general abuse
    Specifics of repair work carried out:Replaced Clutch plate and skim flywheel
    Cost of repair:R2999
    Who did the repair : Mitsubishi Brooklyn
    Vehicle under warranty, Y/N Yes
    Was damage covered by warranty:No
  1. Ford/Mazda Problems!
    By Barto in forum Ford & Mazda
    Last Post: 2024/01/20, 07:25 AM
  2. Mitsubishi AGENT's a RIP OFF
    By 4x4 pitbull in forum General 4x4 Discussion
    Last Post: 2018/08/29, 01:10 PM
  3. Hyundai Problems!
    By Barto in forum Hyundai
    Last Post: 2016/08/08, 01:49 PM
  4. Mitsubishi automatic transmission problems
    By desert storm in forum Mitsubishi
    Last Post: 2010/05/27, 10:42 AM
  5. Mitsubishi recall
    By Tony Weaver in forum Mitsubishi
    Last Post: 2008/12/18, 08:46 PM
