Page 3 of 11 FirstFirst 1 2 3 4 5 6 7 8 ... LastLast
Results 41 to 60 of 207
  1. #41
    sedgefeild
    Thanked: 9
    Model: NH Pajero V6
    Year:1991
    Mileage:220000
    Problem: Missing then engine light on, engine dead, thought it was water in the petrol.
    Cause of problem(if known): water damage to CPU previously repaired by local technician, burnt out wires behind dash.
    Specifics of repair work carried out: new CPU plus rewire.
    Cost of repair: R 18000
    Who did the repair: New Vaal Motors
    Vehicle under warranty, Y/N:N
    Was damage covered by warranty:N
  2. #42
    sedgefeild
    Thanked: 9
    Model: NH Pajero V6
    Year: 1991
    Mileage: 260000
    Problem: Rear wheels getting hot, brakes binding
    Cause of problem(if known): Locating pins on rear brake caliper bent, caused by mechanics changing brake pads.
    Specifics of repair work carried out: Replace pins with new ones.
    Cost of repair: R 600
    Who did the repair: Me
    Was damage covered by warranty: N
  3. #43
    sedgefeild
    Thanked: 9
    Model: NH V6 Pajero
    Year: 1991
    Mileage: 215000
    Problem: Gearbox very noisy
    Cause of problem(if known): Previous mechanic replaced bearing and left out spacer on 5th gear - caused too much float - premature failure of bearing
    Specifics of repair work carried out: Replaced bearings in gearbox - difficult to find correct ones, bought off the shelf and modified.
    Cost of repair: R 6000
    Who did the repair: Mechanic in Botswana, Franchesco.
  4. #44
    sedgefeild
    Thanked: 9
    Model: NH V6 Pajero
    Year: 1991
    Mileage: 217000
    Problem: Unable to set wheel alignment
    Cause of problem(if known): Worn ball joint on steering arm
    Specifics of repair work carried out: Replaced all ball joints, idler and steering arm.
    Cost of repair: R 2500
  5. #45
    Kimberley
    Model: Pajero GLS SWB DiD
    Year: 2008
    Mileage: 30000km
    Problem: Rattling cubbyhole
    Specifics of repair work carried out: Will be replaced - on order
    Cost of repair: None
    Who did the repair: The agent
    Vehicle under warranty, Y/N: Y
    Was damage covered by warranty: Yes
  6. #46
    Kimberley
    Year: 2008
    Mileage: 30000km
    Problem: Left front speaker distorts
    Specifics of repair work carried out: Replaved
    Who did the repair: Agent
  7. #47
    Kimberley
    Year: 2008
    Mileage: 30000km
    Problem: Only one hooter works
  8. #48
    My own world
    Model: Trailbuster 2.8D
    Year: 2000
    Mileage: 195000km
    Problem: Dash lights flashing because front diff not disengaging
    Cause of problem(if known):4x4 ECU
    Specifics of repair work carried out: Replaced 4x4 ECU
    Cost of repair: R2600
    Ford F250 v8 37' super swamper boggers ,
    Ford F250 V8 35's Maxxis ,
    Colt 4x4 2.8
  9. #49
    Pereybere
    Thanked: 27
    Model: Triton 3.5
    Year: 2008
    Mileage: 29500km
    Problem:Slight Whine from the rear
    Cause of problem(if known):N/A
    Specifics of repair work carried out: Replace rear diff
    Cost of repair: Warranty
    Who did the repair: Agent Brooklyn
  10. #50
    durbanville
    Thanked: 11
    Model: Triton 2.5 DID
    Year: 2008
    Mileage: 26 500km
    Problem:Knock on steering wheel
    Specifics of repair work carried out: Replace Steering coloum
    Cost of repair: R +- 6 500
    Who did the repair: Agent High Street
  11. #51
    Jun 2008
    Thanked: 230
    Model: Colt 2.4i Trailbuster
    Year: 2001
    Mileage: 160000km
    Problem: front suspension noise, unable to align. Oil leak rear of engine
    Cause of problem(if known): no idea.
    Specifics of repair work carried out: Replaced control and idler arms. Replaced o-ring behind engine (required the engine to be removed)
    Cost of repair: R14000 including service for steering components. R5000 for o-ring replacement.
    Ironman Suspension
    40mm Body lift
    31x10.5x15 Cooper STTs
  12. #52
    4ePikanini Guest
    Model: Pajero 3000 V6 GLS
    Year: 1993
    Mileage: 257'000km
    Problem: piston slap
    Cause of problem(if known): overheated at some stage - I bought it with the problem but it was apparent it overheated badly.
    Specifics of repair work carried out: completely rebuilt the engine
    Cost of repair: R11'000
    Who did the repair: Workshop did machining and I pulled and replaced the engine
  13. #53
    Model : DID 3.2 LWB
    Year : 2004
    Mileage : 128000
    Problem : Engine light came on followed by loss of power and black smoke
    Cause : "Enthusiastic" approach to sand dune in the Namib caused the OME's to bottom out and push the bash plate"sump guard" into the intercooler!!
    Specifics of repair work : New Intercooler.
    Cost : R10200
    Who did the repairs : Agents in Pretoria
    Vehicle under warranty : No...ouch!!
    P.S.Make sure your after market sump guard has sufficient clearance to flex (or be strong enough not to) before touching your intercooler!
    Jonathan Balladon
    '04 Pajero LWB DI-D A/T (Now with Emu, ARB bar, RTT, Engel, Drawers, 2nd spare wheel, winch and overdraft)
    BMW 320d
    www.flickr.com/photos/jdballadon
    Diesel Rules!!
  14. #54
    Richardsbay, KZN
    Thanked: 17212
    Model: Clubcab 2.8 Tdi
    Year:2003
    Mileage:210000 km ( now)
    Problem: Cracked cyl head. 4 times!!!
    Cause of problem(if known): Apparent factory fault
    Specifics of repair work carried out: After fourth failiure decided to fit import motor.
    Cost of repair: Around 100K in total. Yes I know I am stupid.
    Who did the repair: Kleiner Engineering in Empangeni who sued me when I refused to pay after the fourth head failiure.
    Vehicle under warranty, Y/N: First head went at 70000 km a month after I bought the vehicle second hand, but due to my work ( rep at the time travelling long distances) went over the service interval. So no, I had to cough.
    Was damage covered by warranty: No
    __________________
  15. #55
    Jun 2007
    Harrismith
    Model: Rodeo 2.8 Tdi Doublecab 4x4
    Year:2006
    Mileage:126000 km
    Problem: Cracked Manifold
    Cause of problem(if known): Unknown
    Specifics of repair work carried out: Replace manifold (after failed welding attemp)
    Cost of repair: R6200
    Who did the repair: de Beer Motors in Warden
    Was damage covered by warranty: N/A
    LIVE LIFE TO THE FULLEST
  16. #56
    Pereybere
    Thanked: 27
    Model: Triton D/C 3.5 V6 (import)
    Year: 2008
    Mileage:43 000
    Problem: Ceased Alternator
    Specifics of repair work carried out: New Alternator
    Cost of repair: R1500
    Who did the repair: Brooklyn
    Vehicle under warranty, Y/N:Y
    Was damage covered by warranty:Y
  17. #57
    Krugersdorp
    Year:2001
    Mileage:201000 km
    Problem: Cracked Head
    Cause of problem(if known): Faulty radiator cap, Fan blade broken
    Specifics of repair work carried out: Replaced head, replaced gaskets, New glow plugs, New injectors, new radiator cap, Radiator send in to be serviced and cleaned, new Fan blade.
    Cost of repair: R13000
    Who did the repair: Hill Side Motors
  18. #58
    Thanked: 115
    Model: 3.2 4x4 Triton Clubcab
    Year: 2008
    Mileage: 32000
    Problem: Diff lock light flashes when turning right.
    Cause of problem(if known): First they thought it was the ABS sensors which they replaced, but then found a problem in the diff. Diff lock mechanism bolts came loose and damaged some components. Determined to be a factory fault.
    Specifics of repair work carried out: Whole rear diff third member replaced.
    Cost of repair: Unknown
    Who did the repair: Maritime Motors PE
    Vehicle under warranty, Y/N: Yes
  19. #59
    Thanked: 115
    Year: 2008
    Mileage: 38000
    Problem: Knocking noise at the right front CV. Heard it first when I got the bakkie as demo in January 2009. Problem slowly got worse until I asked them to check it at the 30K service. They told me it was a stone behind the dust cover, but at 38K is was clear there is a problem and it's getting worse.
    Cause of problem(if known): CV more than likely damaged while it was a demo car and it slowly got worse.
    Specifics of repair work carried out: Front drive shaft replaced
  20. #60
    Thanked: 115
    Year: 2008
    Mileage: 41000
    Problem: Right front CV at the hub popped on an easy sandy hill on a Mitsubishi approved training track. Shaft had to be removed right there as the CV completely disintegrated. The drive shaft was only 3000km old at the time.
    Cause of problem(if known): Unsure, should not have broken on such an easy sandy hill.
    Specifics of repair work carried out: Front drive shaft replaced. Had to wait almost 3 weeks for the new shaft as it's not kept in stock in South Africa.
  1. Ford/Mazda Problems!
    By Barto in forum Ford & Mazda
    Last Post: 2024/01/20, 07:25 AM
  2. Mitsubishi AGENT's a RIP OFF
    By 4x4 pitbull in forum General 4x4 Discussion
    Last Post: 2018/08/29, 01:10 PM
  3. Hyundai Problems!
    By Barto in forum Hyundai
    Last Post: 2016/08/08, 01:49 PM
  4. Mitsubishi automatic transmission problems
    By desert storm in forum Mitsubishi
    Last Post: 2010/05/27, 10:42 AM
  5. Mitsubishi recall
    By Tony Weaver in forum Mitsubishi
    Last Post: 2008/12/18, 08:46 PM
