Page 2 of 11 FirstFirst 1 2 3 4 5 6 7 ... LastLast
Results 21 to 40 of 207
  1. #21
    Groton, Massachusetts
    Thanked: 9
    Model: Colt Pioneer 2.8tdi 4x2
    Year: 2000
    Mileage: 130 000
    Problem: Grrrr Grrrr noise from engine.
    Cause of problem(if known): Stretched timing chain
    Specifics of repair work carried out: Replaced timing chain and tentioner
    Cost of repair: R2 300.00
    Who did the repair: Dealers: Rola Motors - Strand
    Was damage covered by warranty: N
    Nico
    Current: (USA)
    2019 Ford Explorer 3.5 V6 AWD
    2011 Chevrolet Traverse 3.6 V6 AWD
    Ex: (ZA) 2006 Mitsu Pajero 3.2 DiD LWB, 2002 Jeep Grand Cherokee (WJ) 4.7 V8
  2. #22
    Centurion, Pretoria, SA
    Thanked: 1101
    Model: Pajero 3.2 DID SWB
    Year: 2003
    Mileage: 150 000 km
    Problem: Brake shudder
    Cause of problem(if known): Suspect brake discs distorted
    Specifics of repair work carried out: All discs & pads replaced @ 120 000 km. Brake shudder developed. Agents skimmed discs. Applied brakes hard to avoid accident & problem is now back again at 135 000 km. At a much later stage found the rear caliper bolts seized / rusted in clipers. Repaired and shudder gone.
    Cost of repair: open to correction / about R 5 or 6 000.00
    Who did the repair: Mitsibushi Sandton first time. Not again / this 2nd next time.
    Vehicle under warranty, Y/N: no
    Was damage covered by warranty: no
    Last edited by Sneaky Pete; 2015/06/16 at 04:56 PM. Reason: found true cause of problem
  3. #23
    Pretoorsdorp (Centurion)
    Thanked: 176
    Model: Pajero 3.0 V6 SWB
    Year: 1997
    Mileage: 190000km
    Problem: Noisy Tappets
    Specifics of repair work carried out: Replaced all lifters, flushed engine, changed different oil grades & still no improvement. Can hear the tappets with all windows closed even at high speeds.
    Cost of repair: R3000+
    Who did the repair: Centurion Motor Engineering
    Cobus Böhmer
    071-6417947
    [email protected]
  4. #24
    Dec 2006
    Thanked: 20
    Model: Pajero Gen3 GLX
    Year: 2007
    Mileage: 30000km
    Problem: Brakes (Grinding noise under hard braking)
    Cause of problem(if known): Brake pads were apparently "glazed"
    Specifics of repair work carried out: Brake pads replaced and discs skimmed.
    Cost of repair: nil
    Who did the repair: Mitsubishi Umhlanga
    Vehicle under warranty, Y/N: Y
    Was damage covered by warranty: Y
  5. #25
    Dec 2006
    Thanked: 20
    Year: 2007
    Mileage: 37500km
    Problem: Brakes (tapping noise under light braking and shudder when braking from high speed)
    Cause of problem(if known): Brake discs were apparently damaged (ridged) during previous skimming
    Specifics of repair work carried out: All 4 discs were replaced
    Cost of repair: nil
  6. #26
    Oct 2008
    Model: Colt 2800td 4x4
    Year: 2001
    Mileage: 275000km
    Problem: Overheating on Highway at 110km/h
    Cause of problem (if known): Blocked radiator
    Specifics of repair work carried out: Radiator flush + head test
    Cost of repair: R890
    Who did the repair: Thys (private mechanic)
  7. #27
    Model: Triton 3.2D D/c
    Year: 2007
    Mileage: 1st 14000km
    Problem: Surging/starving then later engine light coming on.
    Cause of problem(if known): Don't think Mitsubishi knows what finally fixed the problem
    Specifics of repair work carried out: Swapped R65k worth of parts (everything between head gasket to fuel pump) with "problem free" Triton - problem much, much worse. Later found that manifild gasket leaked (on Colt's you could re-use them, not on Tritons). This made major improvement but back to square one. Replaced square-ended fuel pump nozzle with tapered/rounded nozzle. Problem improved not gone. Widened air intake as it is the same as 2.5d intake. Whole repair took 13 visits in 12 months. When finally requested replacement vehicle they put car on computer to show all paramater readings and car has been perfect since this!!!! The engine light came on. Casue: Blocked barometric pressure sensor hose - same as 2.5d elsewhere in this section.
    Cost of repair: R0
    Who did the repair: Mitsubishi Tyger Valley, Mitsubishi Paarden Island
  8. #28
    Sep 2008
    Cape Town, Nothern Subs
    Model: Colt Clubcab 2.8TDi 4x4
    Year: 2003
    Mileage: 96k
    Problem: wouldn't engage 4x4 or diff lock, light wouldn't even come on
    Cause of problem(if known): general w/t I'm told
    Specifics of repair work carried out: 4x4 switches on transfer case replace, auto locking hub switches replaced
    Cost of repair: R2800
    Who did the repair: Mitsubishi Paarden Island
  9. #29
    desoto62 Guest
    Year: 2001
    Mileage: 237000
    Problem: Seized motor
    Cause of problem(if known): overfueling
    Specifics of repair work carried out: New head, new turbo, complete engine rebuild, reset computer, rebuild pump and calibrate
    Cost of repair: R69000.00
    Who did the repair: SAC
    Vehicle under warranty, Y/N: Yes (SA Warrantee)
    Was damage covered by warranty: Partly (R12500)
  10. #30
    1 Die Hoek street, Langebaan, Westcoast
    Model: Pajero SWB 3l V6 4x4
    Year: 1999
    Mileage: 170 000...now183000
    Problem: Noisy engine & clutch and was using excessive oil (1l to 500km) ...no oil usage...engine quiet
    Cause of problem(if known): worn rings & cylinder sleeves, hydraulic lifters kaput, clutch worn.
    Specifics of repair work carried out: Complete engine rebuilt (as in new)
    Cost of repair: R28000
    Who did the repair: Goch & Coopers Cape Town
  11. #31
    Model: Pajero LWB 3,5 V6 4x4
    Year: 1997
    Mileage: 240 000
    Problem: Noisy lifters
    Cause of problem(if known): worn lifters.
    Specifics of repair work carried out: Replace lifters
    Cost of repair: R5 000
    Who did the repair: Self
    Disco 3 wee-uit.....looking for 18".
    Defender 110 wee-uit......wiff tyres.
  12. #32
    Paarl
    Model: Pajero 2.8tdi
    Year: 1996
    Mileage: 184 011
    Problem: Car would start easily and then come to a spluttering death about 30 seconds later. Difficult to start when at normal operating temperature.
    Cause of problem(if known): Problems carried over from engine failure and rebuild 1. Replaced glowplugs (twice) , 2. Replace fuel filter
    Actual cause was worn diesel pump, leaking primer pump and damaged fuel lines. The replacement unit I bought was also badly worn.
    Specifics of repair work carried out: Reconned and calibrated diesel pump, replaced primer pump, replaced fuel feeder lines, cleaned diesel tank, fuel pick-ups and all the lines. Checked and reset injectors. Complete test hot and cold start and running. To be dyno'ed next week (Got it offered free so why not).
    Cost of repair: Complete diesel pump rebuild - R2 950
    Primer pump (new from Mitsu) R665
    All the rest - R 1 400 (luckily I could trade in my 2nd pump for R1000)
    Who did the repair: SP Dieseltech, Paarl
    Vehicle under warranty, Y/N: No
    Johann Bredell
  13. #33
    PWV
    Post gearbox
    Model: Triton 3.5 MPI
    Year: 07
    Mileage: 98500
    Problem: cluster shaft in gearbox noisy
    Cause of problem(if known): don't want to know
    Specifics of repair work carried out: R+R Gearbox, fitted 1x brand new one.
    Cost of repair: 0
    Who did the repair: New Vaal Motors
    Vehicle under warranty, Y/N: Y (Just)
    Was damage covered by warranty: yip
    downhill assist = middle pedal
    All truth passes through three phases:
    1. Violently opposed
    2. Horribly ridiculed
    3. Accepted as self evident
  14. #34
    PWV
    Default thai piping
    Year:07
    Mileage: 4700
    Problem: The steel pipe for the clutch actuator burst on the flared joint
    Cause of problem(if known): dont have the foggiest
    Specifics of repair work carried out: R+R Pipe assy.
    Cost of repair: 0
  15. #35
    PWV
    Default shocks
    Year:07
    Mileage: 49000
    Problem: Rear shocks poked
    Cause of problem(if known): bad from start
    Specifics of repair work carried out: R+R Rear Shocks
    Cost of repair: 0
  16. #36
    Pereybere
    Thanked: 27
    Model:Triton 3.5mpi
    Year:2008
    Mileage:
    24000
    Problem:
    clutch taking high.
    worn clutch plate
    New clutch and pressure plate
    Cost of repair:
    Who did the repair:
    Brooklyn
    Vehicle under warranty, Y/N:Yes
    Was damage covered by warranty:Yes
  17. #37
    Thanked: 4513
    Model: 3l v6 lwb
    Year:1995
    Mileage:280000
    Problem:Blown cyl head gasget
    Cause of problem(if known):Broken Thermostat allowing engine to overheat and eventually busting a water pipe on heater
    Specifics of repair work carried out: Opened heads to find rocker shafts badly worn and heads warped beyond repair. Cost of spares in excess of R15k. Replaced engine with Jap import, replaced all rubber hoses, fitted new cambelt ,oil & waterpump. New clutch assembly. Fitted 2 electrical std by fans as well as oil pres & water temp gauges.
    Cost of repair:R 11.5k
    Who did the repair:Myself
    Vehicle under warranty, Y/N:N
    Was damage covered by warranty:N
    Henk
    Follow us on Facebook
  18. #38
    Melkbosstrand, Cape Town
    Model: Pajero (CK) SWB, 3200 DiD, Manual
    Year: 2000
    Mileage: 160000
    Problem: Clutch shudder and slip under high torque
    Cause of problem(if known): Warn out clutch and fly wheel
    Specifics of repair work carried out: Replaced clutch and dual mass fly wheel
    Cost of repair: R22 000
    Who did the repair: Dealership
  19. #39
    Year: 2000
    Mileage: 150 000
    Problem: Clutch not released when pedal is depressed. No pressure regained after bleeding the system.
    Cause of problem (if known): Clutch system master cylinder worn out.
    Specifics of repair work carried out: Clutch system master cylinder replaced.
    Cost of repair: R2000
  20. #40
    Year: 2000
    Mileage: 150 000
    Problem: Play on front wheel hubs.
    Cause of problem (if known): Wheel bearings worn out.
    Specifics of repair work carried out: Wheel bearing units (sealed unit, including hub) replaced.
    Cost of repair: R4000
  1. Ford/Mazda Problems!
    By Barto in forum Ford & Mazda
    Last Post: 2024/01/20, 07:25 AM
  2. Mitsubishi AGENT's a RIP OFF
    By 4x4 pitbull in forum General 4x4 Discussion
    Last Post: 2018/08/29, 01:10 PM
  3. Hyundai Problems!
    By Barto in forum Hyundai
    Last Post: 2016/08/08, 01:49 PM
  4. Mitsubishi automatic transmission problems
    By desert storm in forum Mitsubishi
    Last Post: 2010/05/27, 10:42 AM
  5. Mitsubishi recall
    By Tony Weaver in forum Mitsubishi
    Last Post: 2008/12/18, 08:46 PM
