Toyota Problems! - Page 2
Page 2 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 21 to 40 of 151
  1. #21
    Aug 2010
    Swellendam
    Model:FORTUNER
    Year:2010
    Mileage:9000 KM
    Problem: DRIVER SEAT LEATHER WORN/BAD /CRACKED
    Cause of problem(if known): TOYOTA HILLCREST ,KZN SAY THIS IS A PROBLEM WITH ALL TOYOTA LEATHER
    Specifics of repair work carried out: NONE
    Cost of repair: NONE
    Who did the repair: NOBODY STILL WAITING FOR TOYOTA HILLCREST ,KZN
    Vehicle under warranty, Y/N: Y
    Was damage covered by warranty DONT NO ,STILL WAITING FOR TOYOTA HILLCRAST,KZN ,BAD AFTER SALE SERVICE
  2. #22
    Jul 2010
    Boksburg
    Model: 3.0D4D 4X4
    Year: 2005
    Mileage: 163400
    Problem: Where to start: replaced injectors, gear lever, air bag electrical harness on driver side, front suspension, air flow mass meter, slave cylinder for clutch!
    Cause of problem(if known): Previous owner probably abused the vehicle!
    Specifics of repair work carried out: all repairs above undertaken
    Cost of repair: Estimate of all repairs currently at R40 000.00
    Who did the repair: Toyota East rand
    Vehicle under warranty, Y/N: extended warranty only
    Was damage covered by warranty: the injectors was an exclusion on the warranty R15000.00 later.
    The sad thing is that the vehicle was bought from a certified used vehicle Toyota dealership.
  3. #23
    Harrismith
    Model: 3.0 D4D D/C 4x2
    Year: 2007
    Mileage: 77000
    Problem: Right front bearing
    Specifics of repair work carried out: Raplace whole hub
    Cost of repair: R1250
    Who did the repair: Riaan's Service Centre in Harrismith
    Was damage covered by warranty: No
    Year: 2007
    Mileage: 80000
    Problem: Airbag light keeps comming on
    Specifics of repair work carried out: Replace spiral cable
    Cost of repair: R1500
    Who did the repair: Not repaired yet
  4. #24
    Mar 2011
    Saldanha
    Model: Raider 3.0 D4D D/C 4x2
    Year: 2007
    Mileage: 120 000
    Problem: Gearbox Wining
    Cause of problem(if known): Bought it like that from Dealer,
    Sounds like Comon D4D Issue
    Specifics of repair work carried out: Replace all Bearings and Synchromesh Gears
    Cost of repair: R12 000
    Was damage covered by warranty: Y (After Runaround)
    Year: 2007
    Mileage: 120 000
    Problem: Clutch problems
    Specifics of repair work carried out: Replaced complete clutch kit
    Cost of repair: R7000
    Was damage covered by warranty: Y (Again after Runaround)
  5. #25
    Gauteng
    Default Prado unuasual overheating
    Model: Prado 4.0 V6
    Year: 2004
    Mileage: 195000km
    Problem: This is a curious case of overheating. Overheating only occurs after long distance driving (140km/h +) for a period of 300km or more. Whilst driving the engine stays cool, only once i slow down in a town or road block does the heat gauge rise. once i take off again or keep the vehicle in neutral at 2000rpm or more does the heat gauge stabilize. The problem occurred at 178000km, this does not happen during local driving. After long distance it takes liquid in the radiator, but the water bottle stays full. in actual fact the water bottle kicks out liquid through the overflow pipe. Toyota has replaced the radiator and thermostat and the problem still occurs. Toyota has checked the viscous fan and water pump and somehow no one can find the cause of the problem. Again, during local driving the engine stays normal.
    Cost of repair:
    Who did the repair:
  6. #26
    Mar 2011
    Model: Hilux4x4 3.0d4d DC
    Year: 2008
    Mileage:: 87600km
    Problem: Clutch very hard and thrust bearing screeching
    Cause of problem: Don't Know
    Specifics of repair carried out: Complete overhaul
    Cost of repair: R6100
    Who did the repair: Toyota Umhlanga
    Vehicle under warranty: Have motorite policy 5yr 999 0000km
  7. #27
    Year: 2008
    Mileage:: 76000km
    Problem: Crack in chassis under firewall
    Specifics of repair carried out: Additional welding
    Cost of repair: Unknown
    Who did the repair: Toyota Durban Road
    Vehicle under warranty: Y
    Year: 2008
    Mileage:: 87000km
    Problem: Left rear bearing packed up. Whining started and after 300km's over 3days of driving the bearing was finished. (Driving at ave. 40km/h)
    Specifics of repair carried out: Replaced bearing
    Cost of repair: R2000
    Who did the repair: Buffalo Toyota
    Vehicle under warranty: Yes, Motorite
    Was damage covered by warranty: claim in; waiting on payment but will not recieve full amount back.
  8. #28
    Jan 2009
    witbank
    Model:Landcruiser 100 VX
    Year:2007
    Mileage:113 000
    Problem: transfer case stuck - cannot engage Low range
    Cause of problem(if known): According to Toyota "hub and flange seized"
    Specifics of repair work carried out: Have extended warranty with Motorite, and are awaitng their response (my dealings with them thus far have been less than pleasant)
    Cost of repair: R 28000
    Who did the repair: Awaiting authorization from Motorite
    Vehicle under warranty, Y/N: Y-extended full maintenance plan
    Was damage covered by warranty: Still to determine
    __________________
  9. #29
    Durban - Umhlanga
    Model: Fortuner4X4 3.0D4d
    Year: 2009
    Milage: 42000
    Problem:Whining Gearbox 1st,2nd,3rd+5th gear
    Cause of problem:Unknown
    Specifics of repair carried out: Gearbox bearings replaced,after box replaced 3 times having problems with clutch shudder
    Cost of repair: +/-R18000
    Who did repair: Toyota Umhlanga - Durban, going for 2nd week now still not fixed
  10. #30
    Centurion - RSA / Freetown - Sierra Leone
    Default Amazing 1989 Toyota Hilux DC
    Model: Hilux SFA DC
    Year:1989
    Milage: Much more than 400 000
    Problem:No power for uphills while carrying about one tonne load and passengers
    Cause of problem:Slightly abused and/or mistreated engine
    Specifics of repair carried out: Fitted a new 4y engine upgraded with EFI, radiator and recon gearbox
    Cost of repair: +/-R18 000
    Who did repair: Louis Zanoli 4x4 Megaworld. (He's a champ with these luxes)
    Vehicle under warranty: Not sure (N)
    Was damage covered by warranty: Definitely not
Name:	Nuut & Oud.jpg
ID:	103551   Click image for larger version.
Name:	Al die ou goete aan.jpg
ID:	103552   Click image for larger version.
ID:	103553   Click image for larger version.
ID:	103554   Click image for larger version.
  11. #31
    brakenfell hights
    Model:105 landcruiser
    Year:97-99
    Mileage:140000
    Problem:center lock not dis ingaging
    Cause of problem(if known):Pc bord center console
    Specifics of repair work carried out:Replace pc board
    Cost of repair:3000
    Who did the repair:Jb'sauto
    Vehicle under warranty, Y/N:n
    Was damage covered by warranty: n
    WITPIT
    LOOP WAAR HY WIL
  12. #32
    Thanked: 7
    Default Gearbox
    Model: 3.0 D4D Fortuner 4X2
    Year: 2009
    Mileage: Currently 157657
    Problem: Release bearing noisy (Whiny)
    Cause of problem(if known): Not Known
    Specifics of repair work carried out: 4th time now going for replacement
    Cost of repair: N/A
    Who did the repair: Witbank Toyota/ Edenvale Toyota
    Was damage covered by warranty: Y The problem first occured at about 60000km. It was reported and the clutch was replaced. From there on, everything went downhill. Release bearing started whining. Replaced. After +- 2 months, same thing.
    Took vehicle to another dealership and it was replaced again. After +- 2 months, Replaced again. I notced that it has now started again. Since the clutch was replaced, I complained about the clutch pedal not feeling "smooth" - almost like kneecaps without catlidge?? Anyway, still waiting for the latest from the Service manager.
  13. #33
    Aug 2010
    Queenstown
    Thanked: 7
    Model: Fortuner 3.0 D4D 4X4
    Year: 2009(Pre-Facelift)
    Mileage: 71000
    Problem: Passanger air bag cover on dash rattled
    Specifics of repair work carried out: Replaced material behind cover
    Cost of repair:
    Who did the repair: Weir's Toyota
    Mileage: 91000
    Problem: Clutch had to be pumped in the morning and cold weather to work.
    Cause of problem(if known): Unknown
    Specifics of repair work carried out: I told them that it was Clutch master cylinder, they replaced the release bearing and bushes on clutch paddle arm. I then took it back(4th time) and through toys out of cot, they replaced master cylinder. Problem solved
    Cost of repair: M/Cylinder R3500
    Vehicle under warranty, Y/N: Y, Extended (6 years/210 000)
    Still the best
    Brian Taylor
    Land Cruiser 79 V6 SC (AKA ZULU )
    Old Man emu, Kilber Bumper, Winch with Plasma rope, Dual Battery, Navigation system
  14. #34
    Mar 2011
    Model: Fortuner 3.0 D4D 4x4
    Year: 2009
    Mileage: 150 000 km
    Problem: High pitch whistle noise after driving long distance (Pret to Jo'burg) & high speed (100-120 km/h). NO noise if car is cold/driving to work (18 km)
    Cause of problem(if known): (Finally after months!) Transfer case grease seal was dry
    Specifics of repair work carried out: Replaced seal
    Cost of repair: Not sure (was done during 150k service)
    Who did the repair: Oranje Toyota Bothaville
    Vehicle under warranty, Y/N: Nope
    Pieter
    2003 Land Rover Defender 90 TD5
  15. #35
    Rustenburg
    Default Prado 90 3.4 auto gearbox
    Model: Prado 90
    Year: 1999
    Mileage: 285443
    Problem: gearbox slipping
    Cause of problem(if known): unknown
    Specifics of repair work carried out: recon whole gearbox
    Cost of repair: R28 842.00
    Who did the repair: Williams Gearbox & Diff Repairs
    Was damage covered by warranty: Partially to the amount of R10 000
  16. #36
    Feb 2012
    Model: LAND CRUISRE 4LTR PETROL
    Year:2010
    Mileage: 24000
    Problem: FUEL CONSUMPTION
    Cause of problem(if known):??
    Specifics of repair work carried out: Reset ecu by agents twice
    Cost of repair: 0
    Who did the repair: Pongola toyota , Huneydew toyota
    Vehicle under warranty, Y/N: y
    Was damage covered by warranty: y
    Still fffffffffffff havy on fuel 3 km / ltr
    please help
  17. #37
    Thanked: 8
    Model: Fortuner 4.0L
    Year: 2012
    Mileage: 8000
    Problem:Shudder from gearbox between 1st and 2nd gear at low speed.
    Specifics of repair work carried out: Replaced propshaft.
    Cost of repair: R0.
    Who did the repair: Barlow World Toyota Centurion
    Was damage covered by warranty: Yes
    Problem not solved...sold vehicle.
  18. #38
    Aug 2010
    boksburg
    Year: 2011
    Milage: 27000
    Cause of problem:Apparently Toyota used Asian bearings according to the service manager
    Cost of repair: not sure
    Who did repair: Toyota Boksburg
  19. #39
    Feb 2012
    Model:Landcruiser 79 series 4l v6 p/u
    Year:2010
    Mileage:33000
    Problem:gearbox
    Specifics of repair work carried out: Replaced sincro's 2nd 3rd at 10000 km & replaced 2nd, 3rd gears,bearings and seals on 30000km again
    Cost of repair:none just inconveniance not having my vehicle for 4 weeks.
    Who did the repair: first repair done by Pongola Toyota,Second repair done by Randstadium Toyota
    Vehicle under warranty, Y/N:y
  20. #40
    Paarl
    Model: Hilux 2.5 SRX D/C
    Year: 2005
    Mileage: 158000km
    Problem: Rear seat rattles
    Cause of problem(if known): common problem with the brackets and toyota has got a anti rattle kit for it. Part no SUJ71D9400 cost of about R360 plus labour.
    Specifics of repair work carried out: I repaired it myself with insulation tape, remove seat , put tape around steel U-bracket at back against the cab.
    Cost of repair: None, had the tape
    Who did the repair: myself
  1. Replies: 29
    Last Post: 2011/07/04, 10:33 AM
  2. Replies: 2
    Last Post: 2011/05/29, 07:43 PM
  3. Worst in SA!!
    By mvcoller in forum The 4x4 Pub
    Last Post: 2010/08/17, 08:03 AM
  4. Toyota SA can't provide CV Boot Rubber
    By Pype in forum Toyota
    Last Post: 2009/12/11, 06:42 AM
  5. Toyota snorkel very special offer
    By Spike in forum Toyota
    Last Post: 2009/10/25, 07:20 PM
