Isuzu Problems! - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 46 of 46
Thread: Isuzu Problems!
  1. #41
    May 2013
    Thanked: 20
    Default Re: Isuzu Problems!
    Model: KB 300 4x4
    Year: 2003
    Mileage: 300k km odd
    Problem: Not drive to front wheels when selecting 4x4
    Cause of problem(if known): Broken wire, due to age.
    Specifics of repair work carried out: Need to add switch and run wires inside cab. I could just reconnect, but lack of space and not wanting to crawl under the vehicle when on a trail again resluts in me adding a permanent fix.
    Cost of repair: Some change for the switch
    Who did the repair: kipi
    Was damage covered by warranty: N
    Thanks Batman driver for helping so quickly. Really appreciate it.
    2003 KB 300 TDI 4x4
    2006 Audi A4 3l TDI
    2013 KTM 450 SXF
  2. #42
    Oct 2017
    Entebbe
    Model: Isuzu 300tdi D/c 4x4
    Year: 2006
    Mileage: 142.000.
    Problem:
    Radiator warning light and sounder goes on. Although thetemperature is normal (below half) the light and alarm will flash / beep forbetween 3 to 6 times. Usually at slow speeds. Radiator is full and top bottlelevels within range.
    Cause of problem(if known): Unknown
    Specifics of repair work carried out: I foundthat the top radiator hose compresses when the motor cools down thinking theproblem was aged radiator cap and hose, Ireplaced both the radiator cap and top hose with OE Isuzu parts. For more thana month she behaved herself. Then over the weekend whilst reversing the alarmsounded (2 beeps and then nothing) Once the motor cooled I found the top hosehad again compressed. I released the radiator cap and the hose decompressed(possible blockage in line to top bottle yet to be confirmed) . I checked thetop up bottle fluids and all is ok.
    Cost of repair: R700
    Who did the repair: Self
  3. #43
    Oct 2017
    Model: KB220LE D/C
    Year: 2001
    Mileage: 315000
    Problem:
    Cost of repair: various
    Who did the repair: various people
    Vehicle under warranty, Y/N: no
    Was damage covered by warranty: no
  4. #44
    May 2017
    Hillcrest
    Model: KB 300Tdi D/C 4x4
    Year: 2005
    Mileage: 174000km
    Problem: Vehicle intermittently cutting out then refusing to start. All dash lights come on, but, the engine would not crank.
    Cause of problem(if known): Dealer diagnosed the positive power strap from the battery to the starter was faulty (part of the wiring loom).
    Specifics of repair work carried out: Replaced the positive power strap from the battery to the starter and alternator.
    Cost of repair: R 5 900.00 incl. VAT - part and labour.
    Who did the repair: Key Motors Pinetown, KZN.
  5. #45
    Mar 2012
    Pierre van Ryneveld
    Thanked: 3613
    Model: KB 250 Dteq SC Fleetside
    Year: 2011
    Mileage: 162'000km
    Problem: Wining noise coming from the gearbox when driving
    Cause of problem(if known): Clutch was replaced by the dealer on 158,000km. New release bearing used was part of a faulty batch. Wining noise started about 2'000km after initial repair
    Specifics of repair work carried out: Clutch replacement + release bearing.
    Cost of repair: R 6'231.71 - parts and labor. (Initial repair)
    Who did the repair: CMH East Rand
    Vehicle under warranty: Y/N: N
    Was damage covered by warranty: Yes. Initial damage was for my own account as clutch is considered to be a wear and tear item. Faulty release bearing was replaced approx. 4'000km later under parts warranty at no additional cost to me.
  6. #46
    Thanked: 163
    Model: KB300 DC 4x4 auto
    Year: 2017
    Mileage: 16500km
    Problem: ABS light on intermittently
    Specifics of repair work carried out: Faulty LHS front ABS Sensor replaced
    Cost of repair: ? Warranty replacement
    Who did the repair: Isuzu Montana
    Vehicle under warranty: Yes
  1. Broken Isuzu leaf springs
    By Vlakvarkie in forum Isuzu
    Last Post: 2016/11/15, 02:34 PM
  2. Hiluix 3.0D-4D, DC 4x4 auto (2009) problems
    By AndreLes in forum Toyota
    Last Post: 2015/03/21, 06:40 AM
  3. Isuzu transfer box problems
    By avanclan in forum Isuzu
    Last Post: 2015/03/14, 01:52 PM
  4. Vauxhall Frontera vs Isuzu Frontier
    By Chris_cross in forum Isuzu
    Last Post: 2013/08/23, 10:46 PM
  5. Fortuner -NO handling problems
    By ArrieMeyer in forum Toyota
    Last Post: 2009/03/09, 06:15 PM
