Isuzu Problems! - Page 2
Results 21 to 40 of 53
Thread: Isuzu Problems!
  1. #21
    Vanderbijlpark
    Model:KB 300LX DC
    Year:2005
    Mileage:195000
    Problem: Engine management light comes on after about 100km/h, noise from wheels when driving, like keys dangling.
    Cause of problem(if known):GM Vanderbijlpark could not fix the problem after four visits and 195000km service
    Specifics of repair work carried out: Plugged in the clutch connector but problem still persists with management light. They say it is my calipars cause the rattle (suspicious) and qouted me R4500 for that repair.
    Cost of repair:R3600 for 19500km service and R280 for resetting service light(which did not work) and use of computers.
    Who did the repair:GM Vanderbijlpark (Imeprial)
    Vehicle under warranty, Y/N:N
    Was damage covered by warranty:N/A
  2. #22
    Wellington
    Default Rear end of vehicle hanging 25mm to left
    Model: KB 300 LX DC 4x4
    Year: 2011
    Mileage: 41000
    Problem: Rear end hanging 25mm to the left
    Cause of problem(if known): Leaf springs sagged
    Specifics of repair work carried out: Replace both sets of leaf springs but after the replacement still 10mm hanging to left
    Cost of repair: R0
    Who did the repair: Thorpe Paarl
    Vehicle under warranty, Y/N: Y
    Was damage covered by warranty: Y
    Last edited by BMW1200GS; 2013/04/03 at 01:50 PM. Reason: still found the tail hanging by 10mm
  3. #23
    JHB
    Model: KB300 4x4
    Year:2011
    Mileage:75000
    Problem: So far.... Rear Diff seized ( factory fault), loading bay loose/knocking , loading bay has to be
    refitted ( retunred 3 times)
    in a new way in accordance to GM...All apparently factory faults.....
    Drivers seat loose ( taken back 3 times comes loose sooner or later)
    Knocking sound from front of car, can be felt on breaks or clutch.. Comes and goes.
    Missing seal near inter cooler ... ( had to take the car back around 5 times)
    Loading bay rubber mounts had to all be changed
    ( My car goes off road once or twice a year when I go away , but not serious
    4x4ing)
    Cause of problem(if known): Factory fault .. So they say
    Specifics of repair work carried out: Eagle canyons JHB ( never again( Pleased with them 0% of the time) The rest at Tommy Martin ( Pleased with them 90% of the time)
    Cost of repair: zero
    Who did the repair: Tommy Martin
    This will be my last Isuzu after having 4 in my family .. Hello Toyota or Ford
    __________________
  4. The Following User Says Thank You to AcHrOaTiC For This Useful Post:
  5. #24
    Howick
    Model:KB 300 LX Double Cab 4x4
    Year:2008
    Mileage:62000
    Problem:Airbag warning light comes on occasionally
    Cause of problem(if known):Unknown (not the connector plugs under the seat or dash)
    Specifics of repair work carried out: Diagnostic test
    Cost of repair:R0
    Who did the repair:Bullimore Motors
  6. #25
    Fourways
    Model: D-Teq 250 D/C 4x2
    Year:2009
    Mileage:13700
    Problem:Battery,Handbrake/Brake Fluid & Diff Lock lights on dashboard permanently on.
    Cause of problem(if known): Apparently Alternator
    Specifics of repair work carried out: Replace Alternator
    Cost of repair: R13000 without labour, parts only
    Who did the repair: Agents in Johannesburg
  7. #26
    Thanked: 167
    Model:KB 320 LX 4x4 Frontier
    Year:2001
    Mileage:250000km
    Problem: Random power loss on pull away and cursing speed at 120
    Cause of problem(if known): O2 sensor faulty, Keeps reading 610v and should be moving between 0 and 999
    Cost of repair:R 450 new Bosch part
    Who did the repair: owner
    2010 Toyota Fortuner 2 4x4.
    2001 Isuzu KB320 Frontier 4x4.
    2012 Polo GT White with community sticker.
  8. The Following User Says Thank You to Garreth G For This Useful Post:
  9. #27
    Dec 2014
    Rustenburg
    Model: Isuzu kb300 dteq dc
    Year: 2014
    Mileage: 26000
    Problem: Wrong engine number
    Cause of problem(if known): manufacturer
    Specifics of repair work carried out: n/a
    Cost of repair: n/a
    Who did the repair: n/a
    Was damage covered by warranty: still trying to solve the problem
  10. #28
    Mar 2015
    Model: KB300TDi 4x4 LX DC
    Year: 2006
    Mileage: 197 000
    Problem: 1. Engine Management light comes on after reaching 100km/h, speed related not drive duration
    2. Flat spot in acceleration but only occasionally
    3. occasionally bakkie keeps idling for a few seconds when key has been removed
    4. Airbag light stays on (was told it was my wife putting her handbag under the seat, stopped that and checked connections but no change)
    5. Grinding noise and vibration on rear axle
    Cause of problem(if known): 1. Clutch Release Switch Adjustment
    2. Clutch Release Switch Adjustment
    3. Fuel Cut-off Solenoid - intermittent
    4. Airbag connection plugs under seat
    5. Suspected Diff bearings
    Specifics of repair work carried out: 1. & 2. Clutch Release Switch needed adjustment - issue resolved free of charge by Bryan @ CMH Umlhanga
    3. Detected possible fault on Fuel Cut-off Solenoid when running diagnostics - monitoring issue but intermittent - estimate repair if needed +-R20 000
    4. Cut off all connection plugs and soldered direct. Light no longer comes on - done by Bryan @ CMH Umhlanga
    5. Serviced rear diff and replaced diff & sideshaft bearings - grinding noise and vibration gone
    Cost of repair: 1. & 2. Free of Charge 4. R684 5. R8700
    Who did the repair: 1 - 4 CMH Umhlanga 5.Transaxle cc
    Was damage covered by warranty: N/A
  11. #29
    Default Isuzu Problems
    Model: KB300 D-Teq DC
    Year: 2013
    Mileage: 38000
    Problem: Starter packed up
    Cost of repair:
    Who did the repair: McCarthy Hatfield
    Was damage covered by warranty: Damage covered under warranty
  12. #30
    Thanked: 34
    Model: KB300 D-Teq
    Year: 2008
    Mileage: 135000
    Cause of problem(if known):Starter packed up
    Specifics of repair work carried out:Fitted pirate solenoid
    Cost of repair:Not expensive - done with other work
    Who did the repair: Mario. Cape town
    Was damage covered by warranty: No
    Life starts
    where the comfort-zone ends.
  13. #31
    Model: Frontier KB280 DT 4x4
    Year: 2000
    Mileage: 460000
    Problem: differentials
    Cause of problem(if known): original breather pipe was installed into the lower chassis, when the diff got wet and cooled like when in water it sucked water into the diff, 3 diffs later breather has been extended to almost the roof level
    Cost of repair:
    Who did the repair: CRD and my pet mechanic
    Vehicle under warranty, Y/N: nope
    Was damage covered by warranty: nope
  14. #32
    Pretoria, Hartbeesfontein
    Thanked: 743
    Model: KB 280 4x4 DC
    Year: 1998
    Mileage: 275000
    Problems: leaking power steering box and PS rubber hose
    Cause of the problem: wear and tear of seals
    Specifics of repair work carried out: recon power steering box and obtain new rubber hose with new ends
    Cost of repair: steering box- R2800, hose and fittings- R375
    Who did the repair: SB - West power steering, hose - Quick Hydraulic
    Robert
    '09 VW Caddy Maxi TDi
    '06 Citroen C3 1.4HDi8)
    '97 Isuzu 280 S/C plaasbakkie
  15. The Following User Says Thank You to Tweeling For This Useful Post:
  16. #33
    Jun 2015
    Default GM refuses to honour warranty after agent error
    Update: Following intervention by Pieter van Zyl from Wesbank Klerksdorp (my hero on this case), the vehicle was collected by the seller (Midway Motors) and delivered to Westvaal Klerksdorp - and after some behind the scenes efforts (& fighting), GM provided a new head for the vehicle and Midway/Westvaal both contributed to repair the vehicle. It therefore remains under warranty (one of my conditions) and although all 3 parties still claim their innocence in contributing to my debacle, Pieter clearly did a fine job of squaring all into a corner from where they could not escape.
    (But alas: Upon receiving the vehicle back, it had to be sent in for a serious check-up to tighten a few lose pipes, belts and bolts - so much for the final test drive...) So now the vehicle is in the market - kicking me in the face like they had, GM will not do anymore business with us. And hopefully not with any of my friends, colleagues, contacts, acquaintances, etc. Quite sad, because Isuzu's are good vehicles - the GM risk is just too much.
    Model: 250 Dtech (pre-facelift)
    Year: 2012
    Mileage: 85 000 km (acquired at ~83 400 km)
    Problem: Blown head-gasket (possibly more)
    Cause of problem (if known): Clogged radiator core - never cleaned during services at agent (Westvaal Klerksdorp), as per admission by the workshop manager, in spite of routine requirement in service schedule. (“Radiators are only cleaned when overheating is experienced or if requested by owners” ??!!)
    Specifics of repair work carried out: Repairs not yet done – Radiator core was cleaned by Barloworld GM Centurion – their formal report identified Westvaal Klerksdorp as culprit (GMSA must therefore take responsibility).
    Cost of repair: Barloworld GM Centurion estimation is R30 000+
    Who did the repair: Not done yet
    Vehicle under warranty, Y/N: Y - although GM South Africa refuses responsibility, claiming a bizarre reason (exposed as a lie) to blame the previous owner [WHO MAINTAINED THE FULL SERVICE RECORD WITH THE AGENT (Westvaal Klerksdorp).
    Was damage covered by warranty: GMSA refuses to honour warranty. Case was referred to MIOSA, but progress is very very very slow
  17. #34
    Jan 2016
    roodepoort
    Default Re: Isuzu Problems!
    Model:250 dtech double cab
    Year:2013
    Mileage:45000km
    Problem: No power when towing my caravan(gypsey 780 kg) When I am doing less that 80 km per hour the vehicle seems to take the load When I got onto the Rustenburg high way traveling to Buffelspoort I only manage to do 110 km per hour in 4th gear ,As soon as I go in to 5th gear I don't have any power .I have the dust tech plug and play with 4 maps loaded ,Even when I unplug the plug and play the vehicle is the same It also started overheating
    Cause of problem(if known)ealer suggested that he will replace the injectors ,,,,,,,
    Specifics of repair work carried out:Injectors to be replaced
    Cost of repair:None
    Who did the repairealer will do it
    Vehicle under warranty, Y/N:Y
    Was damage covered by warranty:so far yes
  18. #35
    Jan 2015
    Greytown
    Model:KB 300 4x4 Extended cab
    Year:2015
    Mileage:15000 km
    Problem:1. Factory fault-When depressing clutch it feels rough
    2. Going from first to second gears grind when cold, generally a rough gear change.
    Cause of problem(if known):Factory fault
    Specifics of repair work carried out:New gearbox
    Cost of repair:NIL
    Was damage covered by warranty:Y
  19. #36
    Dec 2007
    Harties
    Model: kB 300
    Year: 2015
    Mileage: 26000
    Problem: makes me want to have an extended cab as well
    Cause of problem(if known): regret, dreams, ambitions, ideas....
    Specifics of repair work carried out: shrink said i am Fkd
    Cost of repair: R 700 per session, stopped after the first one.
    Who did the repair: me.... when i am dreaming about an extended cab....
    Vehicle under warranty, Y/N: y
    Was damage covered by warranty: nope, the stealer told me they are not romans pizza, its not 2 for the price of one....
    I like anything with 4 or more wheels...
  20. #37
    Thanked: 20
    Model: KB6 3.0 4x4 LX D/C
    Year: 2015
    Mileage: 30 000 Km
    Problem: Clutch Shudder
    Cause of problem(if known): uneven wear on flywheel due to flywheel and pressure plate mating surfaces not being true (Report from Mobiskim Clutch and Brake Specialists, Bellville)
    Specifics of repair work carried out: Flywheel was machined and clutch kit replaced
    Cost of repair: R4000*
    Who did the repair: Williams Hunt Bellville
    Was damage covered by warranty: NO*
    (according to GM head office the clutch is a wear and tear item (I understand that) but it had the problematic clutch since day one...!?! but I had to pay for all the parts and machining from Mobiskim but not any labour)
  21. #38
    Mar 2015
    Southern Suburbs
    Model: KB300, DC, 4x2, Manual
    Year: 2013
    Mileage: 138000
    Problem: 1st - Radiator has a leak, ordered new replacement from agents-waiting for stock.
    2nd - Drove about 140kms average speed approx 115kms, Switched bakkie off to fuel up, engine not turning over when starting again. Waited about 15minutes engine turned over as normal.Spoke to agents, problem to be checked when new radaitor fitted.
    Cause of problem(if known): Problem to be determined by mechanics when bakkie goes in for new radiator.
    Specifics of repair work carried out: Replace radiator. Problem of not starting to be determined.
    Cost of repair: Radiator plus pipes/shroud/labour Approx R5600
    Who did the repair: Bates Port Shepstone
    Was damage covered by warranty: Damage not covered
  22. #39
    Sep 2008
    Thanked: 7
    Year: 2002
    Mileage: 425000
    Cause of problem(if known): Remote stopped working
    Specifics of repair work carried out: new battery fail. Spare remote fine.
    Cost of repair: Nil
    Who did the repair:
  23. #40
    May 2013
    Thanked: 20
    Model: KB 300 4x4
    Year: 2010
    Mileage: 150 000
    Problem: Cruise control not working when lights switched on, first started with cruise control being cancelled by indicating.
    Cause of problem(if known): Some idiot that doesn't know how to insulate wiring. Wires were added to the drivers side brake light and not insulated correctly causing a short.
    Specifics of repair work carried out: Remove wiring added by idiot.
    Cost of repair: mahala
    Who did the repair: kipi
    2003 KB 300 TDI 4x4
    2006 Audi A4 3l TDI
    2013 KTM 450 SXF
  1. Broken Isuzu leaf springs
    By Vlakvarkie in forum Isuzu
    Last Post: 2016/11/15, 02:34 PM
  2. Hiluix 3.0D-4D, DC 4x4 auto (2009) problems
    By AndreLes in forum Toyota
    Last Post: 2015/03/21, 06:40 AM
  3. Isuzu transfer box problems
    By avanclan in forum Isuzu
    Last Post: 2015/03/14, 01:52 PM
  4. Vauxhall Frontera vs Isuzu Frontier
    By Chris_cross in forum Isuzu
    Last Post: 2013/08/23, 10:46 PM
  5. Fortuner -NO handling problems
    By ArrieMeyer in forum Toyota
    Last Post: 2009/03/09, 06:15 PM
