Results 1 to 12 of 12
Thread: Tata Problems!
    Thanked: 115
    Default Tata Problems!
    This thread serves at a database of all problems experienced by Tata owners. This will give potential buyers or owners of this specific make a database they can go through to see what problems their vehicle could possibly develop.
    To ensure this thread contains only information related to vehicle problems and to keep it easy to read and understand, there are a few very specific rules:
    -Copy the list below in bold into your thread and only provide the information asked for, no more, no less.
    -One list per problem. More than one problem can be posted in the same post, but use seperate lists.
    -No discussions will be allowed in this thread. If you want to discuss a specific problem, contact the poster directly or start a new thread in the relevant section. Copy the post across to the new thread if need be.
    -ANY comments, or posts not conforming to the list below, will be deleted.
    -Only post problems you personally experienced, please no friends' stories or hearsay's.
    Please help to keep this neat and factual.
    Thanks!
    Model:
    Year:
    Mileage:
    Problem:
    Cause of problem(if known):
    Specifics of repair work carried out:
    Cost of repair:
    Who did the repair:
    Vehicle under warranty, Y/N:
    Was damage covered by warranty:
    Default Bad quality and non-existant after-sales-service
    Model: Tata Safari 4x4
    Year: 2009
    Mileage: <5000
    Problem: Alignment of backseats completely out
    Cause of problem(if known): Bent frames, bad quality control
    Specifics of repair work carried out: Tata Diep River sent it to auto trimmers, who tried to fix the problem as best as they could, by inserting extra foam under the leather, but it still looks bad!
    Cost of repair: R0,00
    Who did the repair: It is still not fixed, after 3 tries!
    Vehicle under warranty, Y/N: Yes
    Was damage covered by warranty: Haven't paid anything, so I suppose I should say yes, yet, since the problem isn't fixed, it might cost me still...
    Update: after a long fight with Tata via email, and copying the mail to all the email addresses I could find on the website (SA and India) they have now ordered a new back seat from India, and will replace it. Now just a question of when this is going to happen...
    Default Electrical problems
    Year: 2009
    Mileage: 9000
    Problem: Electrical system has hick-ups: vehicle starts losing power while driving, shudders, the "service" light comes on, and, until I restart, I have to make do with less power, and the revs seem limited to 3500. Also, the battery cuts out sometimes, so I can't start, or worse, can't unlock the vehicle...
    Cause of problem(if known): I wish I knew, so I could tell the fools how to fix it!
    Specifics of repair work carried out: Tata Tokai serviced the vehicle, and tried to find the problem. They found a tear in the earth strap () and have to other a new one from India!
    Who did the repair: It is still not fixed...
    Was damage covered by warranty: Has to be, otherwise I will take them to the ombudsman!
    Thumbs down Problems yet again
    Year: 2009
    Mileage: 15000
    Problem: Problems with the 4x4 option: burning smell when switching, and can't turn properly. Air-con also stuffed.
    Cause of problem(if known): Waiting for the techie to phone me and explain...
    Specifics of repair work carried out: MF Tokai fixed the problem, yet forgot to tell me what was wrong.
    Who did the repair: Multi-Franchise Tokai
    Was damage covered by warranty: Yes
    Jul 2010
    johannesburg
    1. Day two. Torsion bar bolt stripped while raising bar
    2. Day four passenger electric window not working motor replaced/headlamp levelling not working motor replaced (initial problems)
    3. Panel beater friend notices dent in bonnet which you can only see from angle-never resolved.
    4. Wanted to fit roof rack- head office reply says vehicle can’t take roof rack (vehicle comes out fitted overseas)
    5. Trip to Namibia on good sand roads.-bonnet bolts very loose shifting, doors ratting (all 4 nadir pins loose) door hinge to be replaced body panels and main support cross strut tightened during the trip. Protector plate loose.
    6. Headlamp replaced- inner reflector fell off laying inside
    7. Pollen filter replaced – dealer says it doesn’t have a pollen filter (so I took mine out to show them)
    8. Shocks worn out 26000km OME replacements.
    9. Major vibration reported many times- no solution
    10. Leak of some sort un-known, diagnosed as front shaft diff seal leak -6-8 months approx later after loss of ordered parts twice dealership find diesel leak on main rail pipe. This has now become obvious leak. Eventually pipe replaced and...... (No more front shaft seal leak!!)
    11. Told to check driveshaft not covered on warranty. About 46000km balanced and new universal joints
    12. Still vibrating ALL MOUNTS ETC CHECKED
    13. Front suspension- braking and control of vehicle poor- lower control arm rubbers worn plus other small ones- about 50000km
    Steering box adjusted.
    14. Trip to Swazi land - main aircon compressor died about 55000km
    15. Left door central locking not working-intermittent-fixed by owner.
    16. Taken vehicle to dealership for diagnosis on vibration (headoffice came out to check and will send report still waiting (3mo later)
    17. Went again to check same problem- now told clutch....vibration....
    18. Protector plate falls partially off- loss of bolts every time after service- new bolts washers put in and tightened much better rear brackets for plate both broken off.
    19. Front left CV disintegrated-still lots of grease in joint. 57000km
    Thanked: 20097
    odel: Tata Xenon 3.0 DiCOR
    Year: 2011
    Mileage: 75,000
    Problem: Speedo is mental: sometimes reads 0km/h when moving, sometimes just very under real speed
    Cause of problem(if known): Apparently the speed sensor
    Specifics of repair work carried out: None yet
    Who did the repair: N/a
    Vehicle under warranty, Y/N: Partial extended
    Was damage covered by warranty: No.
    Thanked: 20097
    Model: Tata Xenon 3.0 DiCOR
    Year: 2011
    Mileage: 80,000
    Problem: EGR Flange / spigot on exhaust manifold broke
    Cause of problem(if known): Metal fatigue?
    Specifics of repair work carried out: New EGR pipe
    Cost of repair: R2000 (R500 for part, rest for labour)
    Who did the repair: Midrand Imperial
    Was damage covered by warranty: NO!
    Thanked: 20097
    Default Re: Tata Problems!
    Year: 2011
    Mileage: 120,000
    Specifics of repair work carried out: Pipe welded
    Cost of repair: R550
    Who did the repair: Independent
    Vehicle under warranty, Y/N: No
    ​Seems like a recurring issue on this vehicle.
    Thanked: 20097
    Year: 2011
    Mileage: 145,000
    Specifics of repair work carried out: EGR pipe removed and blanking plates installed.
    Cost of repair: R500
    A year later and it broke again. Has now been blanked and removed. Performance is better.
    Oct 2012
    Model: Tata 3.0 Xenon
    Year:2010
    Mileage: 350 000
    Problem: Idling irregular
    Cause of problem(if known): Think fuel rail Pressure sensor
    Specifics of repair work carried out: Replaced Injector
    Cost of repair: R1475-00
    Who did the repair: In-house
    Oct 2012
    Any one?
    Dec 2020
    Kimberley
    Model: 2.2 DICOR TATA XENON
    Year: 2013
    Mileage: 193 000
    Problem: Bakkie does not boost, check engine light comes on for 2 seconds then goes away
    Cause of problem(if known): Still dont know after 7 years
    Specifics of repair work carried out: Replaced fuel filters, air filters, fuel rail sensor, boost sensor, flushed intercooler, replaced intercooler pipes, test and recon injectors, recon turbo x 2, tested injector pump x 2, eliminated EGR, daignostics x 15, auto electrical inspection x 3,
    Cost of repair: R50 000 +
    Who did the repair: TATA Kimberley, VL Diesel, Turbotech, Norchman Diesel, Shaheed Auto Elec, CA Autolek
    Was damage covered by warranty: N/A
  1. Nissan Problems
    By Barto in forum Nissan
    Last Post: 2023/08/21, 09:38 AM
  2. Conqueror Companion: Dream becomes nightmare
    By Alta in forum Camping, Fridges, Accessories
    Last Post: 2012/10/21, 09:54 PM
  3. Discovery 3 CD and Cruise Control problems (incl. bad experience with dealer)
    By ReadySteadyGo in forum Land Rover
    Last Post: 2011/11/09, 07:40 AM
  4. Tata ma… false?
    By Colt4X4 in forum TATA
    Last Post: 2008/04/14, 09:28 PM
